Zenoah vs Quadra - Is it comparing apples and apples?
Tower Hobbies
Logged in as Guest
  Printable Version
XYZ-50cc Gas Engine
Seller:  XYZUSA
Details:   $249.00   |  7/3/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> Zenoah vs Quadra - Is it comparing apples and apples?
Page: [1]
Login
Zenoah vs Quadra - Is it comparing apples and apples? - 9/3/2003 10:52:12 PM
splais
Status: offline
I am looking at purchasing an already built warbird. Both planes weigh about the same. One has a Quadra52; the other a Zenoah62. Both have magnito ignition I believe.
Is there anything to choose between these two engines or are they both the same. Things like reliability, ease of starting, power output, etc. Thanks.
       Post #: 1
Zenoah vs Quadra - Is it comparing apples and apples? - 9/4/2003 4:31:28 PM
beepee
Status: offline
Steve,
Some logic involved in this decision --- as you are dealing with used engines the wear and care will have a dramatic affect on both. The Quadra 52 has not been around for a while, so it could be older. It will not produce as much power as the G62, but is a bit easier to start. Both can be had with spring starters making either one easy enough to start.
For me, I would not hesitate to buy either of these engines. The decision would be influenced by the outside issues.
Good luck!
Bedford
(in reply to splais)
       Post #: 2
RE: Zenoah vs Quadra - Is it comparing apples and apples? - 10/11/2005 2:56:20 PM
Capt Jim
Status: offline
I have been told.by a former dealer...that the Zenoah is by far the better built motor. He mentioned the bearings being much more robust in the Zen....apparently the quality is reflected in the pricing...Zenoah is more expensive.
good luck
_____________________________
Captain Jim
(in reply to beepee)
       Post #: 3
RE: Zenoah vs Quadra - Is it comparing apples and apples? - 10/11/2005 4:48:24 PM
JohnnyJ
Status: offline
Buy the G62. It is more powerful than the Q52.
Both start easily and are simple to operate.
Both are well made and will last a long time in normal flight operations.
I own and fly both of them.
John
< Message edited by JohnnyJ -- 10/11/2005 4:50:30 PM >
(in reply to Capt Jim)
       Post #: 4
RE: Zenoah vs Quadra - Is it comparing apples and apples? - 10/11/2005 5:45:25 PM
Bob Laine
Status: offline
All of the replies that you have received have been right on. Both engines have been used in large scale warbirds for a long time with each particular brand having it's supporters. They are both excellent engines for the application you mentioned. The difference in power between the two engines is minimal. I am a fan of both and Fly both engines on a regular baisis.; (Quad 52, and Zenoah 62) I don't think you need concerne yourself about how the two engines are built, since Both engines have proven themselves over the years to to be pretty much "Bullet Proof"
There is one thing you might consider in you choice between the two, if you are like many in this hobby, and like to sell your engines from time to time,The Quadra will not bring as many $$$ on the used market as the Zenoah. Good luck in whichever engine you choose, and Have fun.
"Georgia on my mind"
AMA 8143 "Leader Member"
       Post #: 5
RE: Zenoah vs Quadra - Is it comparing apples and apples? - 10/11/2005 6:54:30 PM
Tired Old Man
Status: offline
Steve,
I agree with the others. The Zenoah has been around longer than the Quadra, with a proven and constantly improving track record. The 62 has numerous mods and upgrades available that take it even farther. Parts availibility is excellent and will remain so while the Quadra may well be a different story. Off the shelf power, and magneto relibility for the 62 is a bit better than the Quadra as well.
Pat
If you can''''t fix it with a hammer, you have an electrical problem.
(in reply to Bob Laine)
       Post #: 6
RE: Zenoah vs Quadra - Is it comparing apples and apples? - 11/25/2005 12:56:49 AM
lewy73
Status: offline
Steve, I have had a quadra 52 for seven years and have never had any trouble. The Bennett muffler comes loose occasionally. It has a spring starter for easy starting. It is currently on a Weeks Solution.
(in reply to Tired Old Man)
       Post #: 7
RE: Zenoah vs Quadra - Is it comparing apples and apples? - 11/25/2005 1:55:40 AM
tkg
Status: online
Just for the future, the G62 upgrade to a computer ignition is $125 the Q 52 would be over $200
TKG
To much power is just about right.
       Post #: 8
RE: Zenoah vs Quadra - Is it comparing apples and apples? - 11/25/2005 4:59:36 AM
Herby 1
Status: offline
Or not
They have both been around for at least 15 years, I converted my first G62 in 1987, Quadras were available about the same time...
The Q52 started out as the Q50, then got updated to 52cc...Same crank and case on both...The G62 has a larger diamter crank so it resists bending and twisting better than the Quadra...The Quadra cylinder can be rotated so the carb is on the other side...
Either on will outlast many airplanes....
Quadras usually run 20 inch props, G62s usually 22 inch...
< Message edited by RCIGN1 -- 11/25/2005 5:05:25 AM >
(in reply to tkg)
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.656RCU1
