RE: AR-6 Construction Thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pylon Universe - RC Pylon Racing >> Q-40 Racing >> RE: AR-6 Construction Thread
Page: <<   < prev  1 2 3 4 [5] 6 7   next >   >>
Login
RE: AR-6 Construction Thread - 1/7/2013 6:56 PM
sahartman21
Score: 110
Last Login: 6/19/2013
Status: online
quote:
ORIGINAL: s-10promod
Looking nice Scott!!
Now it just needs my trim colors and numbers!!!
That can probably be arranged!
Hide Signatures
(in reply to s-10promod)
       Post #: 101
RE: AR-6 Construction Thread - 1/9/2013 1:40 AM
sahartman21
Score: 110
Status: online
The wing and fuselage had a few areas where the paint surface was dull, due to soaking into the Spackle.
I wet sanded the wing and gave it another coat of color. I wet sanded a few areas on the tail surfaces and fuselage. Those areas were also given another coat.
Hide Signatures
(in reply to sahartman21)
       Post #: 102
RE: AR-6 Construction Thread - 1/11/2013 3:27 AM
sahartman21
Score: 110
Status: online
After a couple days a wet sand (800 to 2000 grit wet-and-dry sandpaper) was done on the finish to remove dirt and bugs.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 103
RE: AR-6 Construction Thread - 1/12/2013 6:18 PM
sahartman21
Score: 110
Status: online
The trim pattern will be similar to that of my AJ-2. Here are some pictures showing the configuration of the trim:
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 104
RE: AR-6 Construction Thread - 1/12/2013 10:03 PM
sahartman21
Score: 110
Status: online
The rest of the model was masked off to keep off in areas not wanted.
I used gloss black Krylon spray paint for trim.
Apply a light coat first. Let dry a few minutes and then spray until the paint covers.
In about 1/2 hour the paint is dry enough to remove the masking paper.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by sahartman21 -- 1/12/2013 10:46 PM >
Hide Signatures
       Post #: 105
RE: AR-6 Construction Thread - 1/13/2013 5:06 PM
masama1107
Score: 100
Last Login: 6/17/2013
Status: offline
Great job as always Scott!!!
Look forward to seeing you at the Basin Q-40 race next month.
_____________________________
Mario Salazar
NMPRA # 18C
Hide Signatures
       Post #: 106
RE: AR-6 Construction Thread - 1/13/2013 9:18 PM
sahartman21
Score: 110
Status: online
quote:
ORIGINAL: masama1107
Thanks!
I'm looking forward to the race.
Hide Signatures
(in reply to masama1107)
       Post #: 107
RE: AR-6 Construction Thread - 1/13/2013 9:20 PM
sahartman21
Score: 110
Status: online
I wet sanded using a piece of 2000 wet-and-dry sandpaper and water.
Hopefully there will be some warmer weather for applying the clear coat.
Click for fullsize
Hide Signatures
       Post #: 108
RE: AR-6 Construction Thread - 1/14/2013 8:10 PM
SSAN
Score: 105
Last Login: 4/23/2013
Status: offline
Looking good, Scott!Great work with many building tips and techniques and promoting the sport of Pylon racing in general.The model looks great, except maybe the color red. I prefer mind in yellow or gold color instead. ;-)
Precision Composites Manufacturing
www.Sam-RaiRacing.com
Hide Signatures
       Post #: 109
RE: AR-6 Construction Thread - 1/17/2013 1:41 AM
sahartman21
Score: 110
Status: online
The temperature warmed up from 20 F this weekend to about 50 F today.
I took this opportunity to spray on the clear coat.
A fast hardener was used as the temperature was cold. I thinned out the clear coat using a fast reducer, so it would lay down easier in the cold temperature.
A light coat was applied over the surface. It was let to dry a few minutes and then more coats were applied until the surface was shiny.
I set the parts out of the way to dry.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to SSAN)
       Post #: 110
RE: AR-6 Construction Thread - 1/17/2013 2:24 AM
fizzwater2
Score: 124
Status: offline
Lookin' good, Scott!
No matter where you go, there you are!
Hide Signatures
       Post #: 111
RE: AR-6 Construction Thread - 1/20/2013 12:46 AM
sahartman21
Score: 110
Status: online
The following pictures show wet sanding and polishing the finish:
Use 2000 grit wet-and-dry sandpaper used wet to remove any dirt and runs.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to fizzwater2)
       Post #: 112
RE: AR-6 Construction Thread - 1/20/2013 12:48 AM
sahartman21
Score: 110
Status: online
I followed with a cleaner polish. This is like the rubbing compound that we used to use. The picture shows a gradual improvement in the finish.
I finished with a liquid wax. The overall finish looks very good from 5 foot, so it's a 5-footer.
I'll have to wait until warmer weather for that super finish.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by sahartman21 -- 1/20/2013 1:17 AM >
Hide Signatures
       Post #: 113
RE: AR-6 Construction Thread - 1/20/2013 9:01 PM
sahartman21
Score: 110
Status: online
I talked to Kevin Matney from Matney's Models about the difficulties when polishing out the wing.
After polishing the wing still had scratch and swirl marks. Kevin suggested going to a new foam bonnet and using a finer compound.
I used the foam bonnet and finer compound and now the wing looks considerably better. The following pictures show what the bonnet looks like:
The foam bonnet is standard equipment provided with a 6" Turtle buffer.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 114
RE: AR-6 Construction Thread - 1/26/2013 1:07 AM
sahartman21
Score: 110
Status: online
The servos were installed using socket head screws.
http://www.microfasteners.com/catalog/products/TWSSHWHMS.cfm
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 115
RE: AR-6 Construction Thread - 1/26/2013 6:20 PM
sahartman21
Score: 110
Status: online
The aileron pushrods were installed and the ailerons were cut free in the following pictures:
The aileron hinge line is freed up by moving the aileron at the hinge line.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 116
RE: AR-6 Construction Thread - 1/26/2013 10:29 PM
MFLOOD3800
Score: 105
Status: online
Looking good Scott, let us know how the flights go!!
Ill see ya at the Basin!!
Race101
Hide Signatures
       Post #: 117
RE: AR-6 Construction Thread - 1/26/2013 11:00 PM
SSAN
Score: 105
Status: offline
Scott, Rather than using nylon clevis, use Hayes Steel Pin Clevis instead. Especially in our pylon racing models. You can purchase the steel pin clevis at Tower Hobby or any other hobby shop that carry Hayes products. Just a thought!
Click for fullsize
Hide Signatures
       Post #: 118
RE: AR-6 Construction Thread - 1/26/2013 11:14 PM
sahartman21
Score: 110
Status: online
I may have to try the Hayes connector at a later date.
Hide Signatures
(in reply to SSAN)
       Post #: 119
RE: AR-6 Construction Thread - 1/26/2013 11:18 PM
sahartman21
Score: 110
Status: online
The following shows the elevator pushrod construction:
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 120
RE: AR-6 Construction Thread - 1/26/2013 11:21 PM
sahartman21
Score: 110
Status: online
More pictures:
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 121
RE: AR-6 Construction Thread - 1/26/2013 11:29 PM
sahartman21
Score: 110
Status: online
Marty,
I'm looking forward to seeing you and others again.
FYI - Those engines you sold me have been running great!
Hide Signatures
       Post #: 122
RE: AR-6 Construction Thread - 1/27/2013 12:55 AM
sahartman21
Score: 110
Status: online
The rudder pushrod is constructed similar to earlier pictures:
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 123
RE: AR-6 Construction Thread - 1/27/2013 3:59 PM
sahartman21
Score: 110
Status: online
The engine kill was installed in this sequence of pictures:
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 124
RE: AR-6 Construction Thread - 1/27/2013 10:56 PM
sahartman21
Score: 110
Status: online
The following pictures shows the installation of the tank:
Initially mount the tank as high is it will go in the fuselage. Mine ended up about 1" above the wing.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by sahartman21 -- 2/11/2013 2:39 AM >
Hide Signatures
       Post #: 125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.078RCU1
