RE: Clark electronics TK20    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Tanks >> RE: Clark electronics TK20
Page: <<   < prev  9 10 [11] 12 13 14 15 16 17 18   next >   >>
Login
RE: Clark electronics TK20 - 11/5/2012 1:08 PM
Airbrushler
Score: 112
Last Login: 5/20/2013
Status: offline
I'll be getting my Clark sometime today hopfully according to the tracking number
_____________________________
http://s1009.photobucket.com/user/airbrushler/media/Soviet_Tank_Battle_zps9b2ee783.gif.html
Hide Signatures
(in reply to YHR)
       Post #: 251
RE: Clark electronics TK20 - 11/5/2012 11:46 PM
Airbrushler
Score: 112
Status: offline
does anyone have a picture showing what goes where on there board?
Hide Signatures
(in reply to Airbrushler)
       Post #: 252
RE: Clark electronics TK20 - 11/5/2012 11:51 PM
Rebellion13
Score: 120
Status: offline
AB,
Dont know if this will help, under the TK20 link on the left and you scroll down there is a pic and chart of what goes where
http://www.clark-model.com/eng/index_e.html
Cheers,
Wade
N.E.A.D Member
All my tanks are in the project stage
Hide Signatures
       Post #: 253
RE: Clark electronics TK20 - 11/6/2012 12:06 AM
tomhugill
Score: 118
Status: online
 Try the Clarke site, think there's a fair bit there!
Tamiya:leopard 2a6, king tiger, Porsche king tiger, panther g, jagdpanther. Hooben: elefant, t-55. HL panther f, Jagdpanthe
Hide Signatures
       Post #: 254
RE: Clark electronics TK20 - 11/6/2012 1:06 AM
Airbrushler
Score: 112
Status: offline
quote:
ORIGINAL: Rebellion13
AB,
Cheers,
Wade
quote:
ORIGINAL: tomhugill
thanks i have just a regular DBC how do i go about hooking that up ?
Hide Signatures
(in reply to Rebellion13)
       Post #: 255
RE: Clark electronics TK20 - 11/6/2012 2:58 AM
YHR
Score: 204
Status: online
The Clark unit has its own battle system. You don't need the DBC.
Dan
Battle Armor R C
Hide Signatures
       Post #: 256
RE: Clark electronics TK20 - 11/6/2012 4:29 AM
Airbrushler
Score: 112
Status: offline
ok but i don't know how to hook up the apple from the DBC will it work or do i have to get the HL or Tamiya one for the emmiter i don't have a connector the size for J1
Hide Signatures
(in reply to YHR)
       Post #: 257
RE: Clark electronics TK20 - 11/6/2012 5:09 AM
Airbrushler
Score: 112
Status: offline
got the apple to work need a better connector fro that to just need to hook up the emitter and get a better speaker
Hide Signatures
       Post #: 258
RE: Clark electronics TK20 - 11/6/2012 6:16 AM
YHR
Score: 204
Status: online
The mini connector Clark uses are hard to come by, I just spliced in a larger pin socket to the Clark wiring to get away from those tiny connectors.
Dan
Battle Armor R C
Hide Signatures
       Post #: 259
RE: Clark electronics TK20 - 11/7/2012 12:24 AM
Airbrushler
Score: 112
Status: offline
aaaaaaaaaah found one i had an old remote control/charger for one of those micro helicopters and they use one of those small connectors for the charger plug so i have one now
Hide Signatures
(in reply to YHR)
       Post #: 260
RE: Clark electronics TK20 - 11/7/2012 4:14 AM
Airbrushler
Score: 112
Status: offline
well mine is hooked up need to do some rearranging inside still
http://youtu.be/WzQJmDl7gwM
Hide Signatures
       Post #: 261
RE: Clark electronics TK20 - 11/7/2012 9:42 AM
tomhugill
Score: 118
Status: online
 Would there be any possibity of getting a video of it driving, especially the proportional steering?
Hide Signatures
       Post #: 262
RE: Clark electronics TK20 - 11/13/2012 9:24 PM
Ten41
Score: 100
Status: offline
Airbrushler-
Did you get a chance to test this out?  I liked the video.
Hide Signatures
       Post #: 263
RE: Clark electronics TK20 - 11/14/2012 8:57 PM
wright 971
Score: 105
Last Login: 5/12/2013
Status: offline
Hi Just been dong range tests of a early board(first batch) with the resistor soldered over,I am happy with the range I managed,80ft and ran out of flat ground it could be more.
Tested two types of emitter from Mapins CY85g and yh70m here is link for them http://www.maplin.co.uk/high-power-infr ... diode-2253
Spent money buying 5 CY85g and there crap max range was 36 ft so dont even buy these .
Now the good news The YH70m from Maplins was getting hits out to 80ft (could be more ran out of flat ground)This was test was done on a garage site on the bases where 10 garages once stood didnt get the tape out but the garages where the same has mine which is 8ft wide x10 = 80ft so this works out at 24 mtrs with a 4ft target area moved the tanks from side to side it was about 4 ft wide ,Had the emitter held in a clamp so not effected with a barrel or tank movement,or miss alinement of emitter in a tank or barrel shading.(note I only shot at one side of the impact apple for all shots to eliminate apple angle difference and to avoid angle defence and slope defence)
This range is better than i thought I would get I am one happy chappie now can fit these in any tank and if I am not hitting them at range its either me being a bad shot or the other bloke has a bad receiver.
regards pete
Hide Signatures
(in reply to Ten41)
       Post #: 264
RE: Clark electronics TK20 - 11/17/2012 2:53 AM
B.A.D.A.S.S.Force
Score: 103
Status: online
I received my TK20E-T1 boards a couple days ago, a TK20E-RU board today, & just got the chance, along with a couple of Clark's high power IR010 IR LED emitters, to do a quick test.
For the sensors I had a standard Heng Long battle unit (HBU), & luckily for me, I also just got a Tamiya apple (TBU) in from the AAF Tank Museum today (super quick from purchase to door-step, thanks Karen), so I had more than just a Heng Long sensor to test.
I did this quick experiment outside in the dark tonight, using my Panther's lower hull as a target, just perching the connected apples on the rear of the hull by the exhaust, as parallel to the ground as I could get them to sit. My KV1 was used for the shooter, though the IR LED was mounted inside a small tube, 9mm from its opening, & just held in my hand for aiming.
Unfortunately, the ground
I used for testing only has about 50ft of almost perfectly flat cement, then some uneven gound extended beyond the cement. But I was still very happy with the results, & I can't wait to fully install everything into the tanks to do some proper testing, hopefully on an area with well over 90ft of flat ground. Just using the standard HBU sensor I was able to easily get hits at about 50ft with Clark's
IR010 IR LED. Using the TBU sensor, I was marking hits at over 95ft, though I have to say, the real issue I had at getting any hits, using either sensor at any distance greater than the 50ft, was more because I couldn't even see the target at longer ranges with the very low lighting in the area where I did my testing, that along with the more uneven ground I was on at those ranges ... so aiming was extremely difficult. I didn't manage to get any hits with the HBU past the 50ft, but I didn't really try too long either since I already got hits over 95ft using the TBU.
I'm expecting to get some TSAL5100 IR LED emitters within the next few days to test as well,
& those have a higher intensity with the same 20° angle as Clark's IR010 emitters, so even better ranges should be possible. IR range isn't a problem any longer.
~ Craig ~
(¯`·._.·´¯`·._ ★ B.A.D.A.S.S. F⊙rce Club F☮under ★ _.·´¯`·._.·´¯)
Hide Signatures
(in reply to wright 971)
       Post #: 265
RE: Clark electronics TK20 - 11/17/2012 10:37 PM
Airbrushler
Score: 112
Status: offline
quote:
ORIGINAL: Ten41
Airbrushler-
i still haven't programed the board yet but sounds are cool with a better speaker
once i program the board i'll post update
Hide Signatures
(in reply to Ten41)
       Post #: 266
RE: Clark electronics TK20 - 11/18/2012 10:23 PM
gorehound
Score: 100
Last Login: 5/19/2013
Status: online
Hi All
Sorry if I missed this earlier in the thread but has anybody tried the T-55 version yet and if so do they have a video of it running. I have been waiting to see if it was worth getting one for my T-55.
cheers
Gorehound
Hide Signatures
(in reply to gorehound)
       Post #: 267
RE: Clark electronics TK20 - 11/18/2012 10:33 PM
tomhugill
Score: 118
Status: online
 Search tk20 t55 on youtube and youll find the demo video
Hide Signatures
       Post #: 268
RE: Clark electronics TK20 - 11/19/2012 1:03 AM
YHR
Score: 204
Status: online
The T55 is OK, but in my opinion not as nice as the Tiger. It has a very long reloading sound clip that plays, and again just not my kind of thing. Others may find it fantastic.
Dan
Battle Armor R C
Hide Signatures
(in reply to tomhugill)
       Post #: 269
RE: Clark electronics TK20 - 11/19/2012 11:13 PM
gorehound
Score: 100
Status: online
Hi
I agree with you on that one. Not so keen on the engine sound either but realise that may just be from the sound from the clip playing on my computer speakers making it sound a bit off. Think I might just go the Benedini route for the T-55 and will get the Clark for the Tiger.
cheers
Gorehound
Hide Signatures
(in reply to YHR)
       Post #: 270
RE: Clark electronics TK20 - 11/20/2012 2:24 PM
MAUS45
Score: 100
Status: offline
So did you use the HL cable kit for this from Clark? I am going to order the TK20E-RU for my T-34 and want to be sure I get the right cables. I am going to use a Tamiya Apple with it as I have two of them already.
3 Tamiya''s Tiger I, Tiger II, Panther G, 3 HL Stug III G, 1 HL Panzer III M, 1 Jagdpanzer IV L/70, 1 1/8 Tiger II
Hide Signatures
(in reply to B.A.D.A.S.S.Force)
       Post #: 271
RE: Clark electronics TK20 - 11/20/2012 4:13 PM
Green Amphibian
Score: 115
Status: offline
Just got my Clark TK20E US yesterday and have not had a chance to do more than open the envelope as of yet.
Herman
The older I get, the better I was.
Hide Signatures
(in reply to MAUS45)
       Post #: 272
RE: Clark electronics TK20 - 11/21/2012 12:44 AM
YHR
Score: 204
Status: online
Hi Herman
Let me know how that Clark U.S. version sounds.
Dan
Dan
Battle Armor R C
Hide Signatures
(in reply to Green Amphibian)
       Post #: 273
RE: Clark electronics TK20 - 11/21/2012 12:47 AM
Green Amphibian
Score: 115
Status: offline
Will do.
Herman
Hide Signatures
(in reply to YHR)
       Post #: 274
RE: Clark electronics TK20 - 11/26/2012 12:22 AM
reyemmanuel
Score: 100
Status: offline
hello all,
I've shot Clark an email regarding some queries below which some of the good rc tankers here may have thought of as well.
1. Wouldn't it be good if the bergepanzer mode be expanded such it can also reload the ammo loadout of the the vehicle being repaired to its initial ammo level. This would in essence provide a sense of logistical perspective when doing battles (i.e., scenarios) or series of battles (i.e., campaigns).
This paves way to tank company battles, with 3 x tank combatants, 1 HQ vehicle/bergepanzer, and 1 scout (i.e., halftrack),whereby logistics and recon must be factored in not just simply blasting away. Especially with the iDrive project rolling, this I think would really be enjoyable. For instance, scouts may probe the front with MGs and may take out the HQ vehicles, or flanking manuevers to either keep your HQ vehicle (such that repair, resupply and perhaps reinforcement-tank respawn) or destroy enemy HQ to deny these functions.
2. As to the the MG firing function, would the IR10 be used for this purpose and would just be a simple swap to the HL-provided MG led?
3. Variable IR range toggle switch or add-on board to the TK boards to dial down IR range.  For instance, if the max IR range of current technology is about 30 m, then this would be reserved for the modern guns.
 (Option 5, 30 m range) guns with > 105 mm
 (Option 4, 25 m range) for 90 to 105 mm as well as 88 mm L71 on the KT's.
 (Option 3, 20 m range) for 76 mm, 17 pdr, 88 L/56, 75 mm L/70
 (Option 2, 10 m range) for 75 mm
 (Option 1, 5 m range) for guns 37-57 mm
5. Any plans on making the IR hit receiver, such to eliminate inconsistencies of the HBU? A CBU (clark battle unit) with 4 sensors similar to the DBU (david's/darkith battle unit).
http://www.youtube.com/watch?v=gCB4Dg9jOBI&list=UUGPlSi3LD9CKkTcV-l4EEGw&index=4&feature=plcp
TamTiger1,TamTiger2,TamLeo1,HLKT,HLM41,HELeo2,HEM1
www.facebook.com/ArmouredRc
Hide Signatures
       Post #: 275
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.516RCU1
