RE: Hobby King turbine!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Hobby King turbine!
Page: <<   < prev  2 3 4 5 6 7 [8] 9 10 11   next >   >>
Login
RE: Hobby King turbine! - 7/7/2012 10:20 AM
Henke Torphammar
Score: 100
Last Login: 5/18/2013
Status: offline
quote:
ORIGINAL: Jgwright
Wonder when Bruce will be running the engine. I see he has posted a new review on a small quad rotor heli, so I guess that indicates he is having problems? Maybe no instructions?
John
Yeah, strange with a video not even putting it in the scale or provide any measurements. Maybe he's got strict regulations.
_____________________________
/Henke
www.youtube.com/henke2
Swist F5D, Lambert Kolibri T25 - 310mph 2012
Hide Signatures
(in reply to Jgwright)
       Post #: 176
RE: Hobby King turbine! - 7/7/2012 10:34 AM
Xairflyer
Score: 105
Status: offline
Can't understand why such a big secret over size.
Just noticed in the video the ecu is very like the one supplied with the Evojet turbine
www.letterkennymodelflyingclub.com
www.jmaireland.com
Hide Signatures
(in reply to Henke Torphammar)
       Post #: 177
RE: Hobby King turbine! - 7/7/2012 11:40 AM
Henke Torphammar
Score: 100
Status: offline
quote:
ORIGINAL: Xairflyer
ECU must be the simplest part for HK to manufacture them selves for very little money. Makes no sence to use an existing one thinking money wise
/Henke
Hide Signatures
(in reply to Xairflyer)
       Post #: 178
RE: Hobby King turbine! - 7/7/2012 12:54 PM
Xairflyer
Score: 105
Status: offline
Yes what you say is true, but the ecu is a very important part of the running of a turbine, joe soap can by a gasper fadec off the shelf for €119 how much would HK pay for them if they order 500?
Even If HK can make their own ecu for $20 they would still be better to add the cost difference to the overall price of the turbine and gain first of all an ECU that is guaranteed to work, and second add a bit of credibility to the turbine which will eliminate the one negative of "the ECU will probably go up in smoke like their cheap ESC's".
$50ish on top of the price of the turbine would be worth four times that in how it is looked at in the market.
www.jmaireland.com
Hide Signatures
       Post #: 179
RE: Hobby King turbine! - 7/7/2012 4:20 PM
Henke Torphammar
Score: 100
Status: offline
quote:
ORIGINAL: Xairflyer
Even If HK can make their own ecu for $20 they would still be better to add the cost difference to the overall price of the turbine and gain first of all an ECU that is guaranteed to work, and second add a bit of credibility to the turbine which will eliminate the one negative of ''the ECU will probably go up in smoke like their cheap ESC's''.
Ofcause useing the Gaspar electonics would be easier and probably better for the users used to xicoy, but don't we/they/the world loose some of the point of a HK turbine if in the end it's a MW54 with Gaspar electronics?
(in general HK ESCs work very well if used within spec... spec of the electronics not the manual that is)
/Henke
Hide Signatures
       Post #: 180
RE: Hobby King turbine! - 7/7/2012 6:08 PM
kochj
Score: 143
Last Login: 5/15/2013
Status: offline
If the end product is well w/n spec, then why are the ryobie drill presses have poor runout?
The lathes that come from harbor freight need some know how to run some good parts due to slop?
The tube notchers don't hit center ? These are right out of the box.
I agree on alloy of metals being key though.
Perhaps just do to the composition of metal of the machinery will dictate a outcome of how well it performs.
I unfortunately do not have first had experience with lathes and cnc machines so most of my knowledge is armchair viewing.
I would would really like to give it a go someday though.
Chears....
If you can''''t dazzle em with brilliance,baffle em with BS
Hide Signatures
       Post #: 181
RE: Hobby King turbine! - 7/7/2012 8:52 PM  1 votes
DrV
Score: 105
Status: offline
quote:
ORIGINAL: Seamus OLeprosy
Don't want to go way off track, but what are the requirements of
these turbine wavers
Look Here: http://www.modelaircraft.org/files/510-a.pdf
Hide Signatures
(in reply to Seamus OLeprosy)
       Post #: 182
RE: Hobby King turbine! - 7/8/2012 12:45 AM
Couch Potato
Score: 105
Status: offline
I can't wait to get my hands on one.........................
http://www.youtube.com/watch?feature=endscreen&v=WrAeUf7v49g&NR=1
OMG Health & Safety, did you see the frosted LPG bottle fall over ?
And the flywheel nearly ground off the valve on the compressed air ( I hope it was acetylene) bottle.
CJ2002, I can see some freelance work to be had there.
http://www.youtube.com/watch?v=D9J91Iq52Bk&feature=related
+ 1 minute fat bloke turns up with fire extinguisher
< Message edited by Couch Potato -- 7/8/2012 1:13 AM >
Hide Signatures
(in reply to DrV)
       Post #: 183
RE: Hobby King turbine! - 7/8/2012 10:00 AM
Seamus OLeprosy
Score: 120
Last Login: 3/9/2013
Status: offline
quote:
ORIGINAL: DrV
Cheers doc
Have 5stars with my complements
Hide Signatures
(in reply to DrV)
       Post #: 184
RE: Hobby King turbine! - 7/8/2012 11:51 AM
Xairflyer
Score: 105
Status: offline
quote:
ORIGINAL: DrV
Cheers doc
In Ireland Seamus you need a B cert to fly a turbine model.
www.jmaireland.com
Hide Signatures
       Post #: 185
RE: Hobby King turbine! - 7/9/2012 4:12 PM
rolsen12
Score: 100
Last Login: 5/9/2013
Status: offline
We could make the turbines in the USA, but ask an insurance man or a lawyer how mutch it would cost per year for product insurance.
Hide Signatures
(in reply to David Jackson)
       Post #: 186
RE: Hobby King turbine! - 7/16/2012 3:42 PM
Henke Torphammar
Score: 100
Status: offline
Over two weeks still no more info!?? Even if it does not run properly a weight or size number would be easy to find out
/Henke
Hide Signatures
(in reply to rolsen12)
       Post #: 187
RE: Hobby King turbine! - 7/16/2012 5:56 PM
Xairflyer
Score: 105
Status: offline
maybe it blew up !
www.jmaireland.com
Hide Signatures
       Post #: 188
RE: Hobby King turbine! - 8/12/2012 1:33 PM
gatorbait2
Score: 100
Last Login: 8/25/2012
Status: offline
Seriously. He has had it for a month, but no video of it running. Just a lot of excuses.
Hide Signatures
(in reply to NZjet)
       Post #: 189
RE: Hobby King turbine! - 8/12/2012 1:46 PM
Mike06659
Score: 100
Status: offline
Where is the video of the HK turbine? Anyone know if he got this thing running?
Hide Signatures
(in reply to gatorbait2)
       Post #: 190
RE: Hobby King turbine! - 8/12/2012 3:11 PM
gatorbait2
Score: 100
Status: offline
If he had gotten it running, you can bet he would have posted it everywhere.
Hide Signatures
(in reply to Mike06659)
       Post #: 191
RE: Hobby King turbine! - 8/13/2012 3:24 AM
Justflying1
Score: 105
Status: offline
 I'm not here to say anything bad about this turbine as I don’t know ant thing about it.
I will however say that before you buy this turbine you mite what to think about a few things.
1.  Price compared to other brands.  We all know that Kingtech has have a relatively cheep turbine which is proven, and reliable.
2.  Are parts available.
3.  Where do I get it serviced.  Who is willing to touch it.
4.  Does it run as reliable as other proven turbines.
5.  Can you get support if you have problems.
6.  Are you willing to be the guinea pig until these turbines get a name for them selves.
7.  Well if you are willing to be a guinea pig lets hope that the name they get is a good one for your sake.
Sometimes but not always something cheep ends up being very expensive.
Just my 2cents worth to think about everyone.
If you have to borrow, you cant afford it
Hide Signatures
       Post #: 192
RE: Hobby King turbine! - 8/13/2012 8:14 AM
Seamus OLeprosy
Score: 120
Status: offline
Thanks Justflyin
As an adult I make decisions like that everyday!
And if I make the wrong one I'll bwitch about it and blame everyone
else.
Hide Signatures
(in reply to Justflying1)
       Post #: 193
RE: Hobby King turbine! - 8/13/2012 10:41 AM
1_helihover_1
Score: 100
Status: online
Probably it has a VERY long spool up time
quote:
ORIGINAL: gatorbait2
Hide Signatures
       Post #: 194
RE: Hobby King turbine! - 8/20/2012 4:50 AM
rpm303
Score: 100
Last Login: 5/17/2013
Status: offline
Last reason Bruce said why he hasn't run the engine is that he didn't have any multiplex connectors and the ones he got were junk.
Sound like just another excuse to me. He's had the turbine for over a month now.
With all the anticipation going on, it makes one wonder what the real reasons is why no review yet, problems??????
Hide Signatures
(in reply to 1_helihover_1)
       Post #: 195
RE: Hobby King turbine! - 8/20/2012 6:20 AM
Henke Torphammar
Score: 100
Status: offline
aaaah, dirty fuel(!) but this is a month ago too.
/Henke
Hide Signatures
(in reply to rpm303)
       Post #: 196
RE: Hobby King turbine! - 8/20/2012 7:45 AM
DominicM
Score: 101
Status: offline
Hobbyking_Admin
Posted: 18 Aug 2012 at 9:11am
Turbines in production.
Should hit the shelves within 40 days.
Hide Signatures
       Post #: 197
RE: Hobby King turbine! - 8/20/2012 7:57 AM
jetster81
Score: 106
Status: online
Can't wait, so I wonder what has happened to Bruce and his one?, unless it is a timing ploy for marketing purposes.
Hide Signatures
(in reply to DominicM)
       Post #: 198
RE: Hobby King turbine! - 8/20/2012 11:48 AM
Xairflyer
Score: 105
Status: offline
quote:
ORIGINAL: jetster81
Would'nt think so as bruce was apparently not sent a production turbine just one of their test units. It was also totally different (incl the electronics) to what they first published.
If production has started then obviously they must already be happy with the final unit.
www.jmaireland.com
Hide Signatures
(in reply to jetster81)
       Post #: 199
RE: Hobby King turbine! - 8/20/2012 8:22 PM
Seamus OLeprosy
Score: 120
Status: offline
quote:
ORIGINAL: drdoom
For all of you who cant wait, Their is a host of good used Jetcats and Central jet in the RCU Classified. Some priced very reasonable.
Any with warranties or guaranties?
Hide Signatures
(in reply to drdoom)
       Post #: 200
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.672RCU1
