Connectors    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric General Discussion >> Connectors
Page: [1]
Login
Connectors - 7/2/2012 3:17 AM
jim4242
Score: 100
Last Login: 8/6/2012
Status: offline
 I am getting into gas  to electric conversion and also building new electric planes and more so than ever I would like to know what make of connectors are the best for performance and ease of connecting and disconnecting. I like the Deans but thy are so difficult to get apart. I have ordered a ICE100 ECS, a Hacker 50 motor and a Watts up to put connectors on that have pretty heavy wires I would like to order the connectors based on suggestions.
Thank you in advance,Jim
Hide Signatures
       Post #: 1
RE: Connectors - 7/2/2012 3:27 AM
goirish
Score: 305
Last Login: 5/21/2013
Status: offline
Most of our club members use the Anderson Power Poles.
_____________________________
DX-7,RDS8000. big Bingo,1/4 Scale Cub, SeaMaster 120, Forget the health food, I need all the preservatives I can get
Hide Signatures
(in reply to jim4242)
       Post #: 2
RE: Connectors - 7/2/2012 1:00 PM
Walt Thyng
Score: 105
Status: offline
Used Power poles exclusively since 92. Prefer to solder rather than crimp 'cause I'm cheap and they can be reused.
Walt
WT in Illinois
Hide Signatures
(in reply to goirish)
       Post #: 3
RE: Connectors - 7/3/2012 2:23 AM
jim4242
Score: 100
Status: offline
 Thanks to both of you, actually after reading your replys I went on ebay and found some at a reasonable price.
As always , thanks for your help.
Jim
Hide Signatures
(in reply to Walt Thyng)
       Post #: 4
RE: Connectors - 7/4/2012 1:14 PM
jbdismukes
Score: 110
Status: offline
quote:
ORIGINAL: Walt Thyng
Walt
DITTO... You can buy a lot of solder for the price of that crimper!
Jack
My Senior Moments have become Senior Momentum
Hide Signatures
       Post #: 5
RE: Connectors - 10/19/2012 11:12 PM
ndelisle
Score: 100
Last Login: 2/9/2013
Status: offline
I use Deans Ultra. The bullet connectors lose tension and conductivity probably.
Here's a way to making Deans easier to use : 1. glue on strips of sandpaper to the halves for gripping. I use CA for that.  2. put a touch of petrolium jelly ( Vaseline ) on the prongs. The jelly is conductive and these fixes work for me.
My biggest motor only pulls 60 amps but the Deans are supposed to be good to 100 Amps.
Nelson DeLisle
Jack DeLisle
Hide Signatures
       Post #: 6
RE: Connectors - 10/20/2012 12:59 PM
eagle33
Score: 100
Last Login: 5/20/2013
Status: offline
Also, sprinkle some powdered graphite on top of the vasoline or mineral oil.
Hide Signatures
(in reply to ndelisle)
       Post #: 7
RE: Connectors - 10/27/2012 11:18 PM
knifemaker
Score: 100
Last Login: 4/15/2013
Status: offline
I use Deans Ultra on most of my planes. When soldering on them, plug the male and female together. This keeps them in alignment if the plastic housing softens from the heat. Also, if one becomes tight, I use di-electric grease. Early on I saw a neat tool in a tips column. It was a spring type clothes pin with 1/16 brass pins glued into holes drilled in the tip end. Matching holes were drilled through the connectors (use care to not hit the conductors). the pins were put into the connector holes, squeeze the clothes pin and the connector was pried open. I keep one of these in my tool box but have not had to use it since learning the soldering trick.
Hide Signatures
(in reply to eagle33)
       Post #: 8
RE: Connectors - 5/6/2013 12:06 AM
Rfabbre
Score: 100
Last Login: 5/12/2013
Status: offline
I am new to electric and am converting an old 45 size 3d plane.
I see Anderson connectors up to 45 amps.  My 50 size motor pulls about 60 amps at WOT.  I have a 100 amp ESC and 5000mah 6s battery.
Will the 45 amp Anderson connectors handle the load?
Does anyone have advice on a spark arrestor wire setup?
Thanx in advance
Hide Signatures
       Post #: 9
RE: Connectors - 5/6/2013 3:58 PM
LesUyeda
Score: 151
Status: offline
"I like the Deans but thy are so difficult to get apart. "
If you get a pair of circlip/snap ring pliers, and drill holes in each connector, you can use the pliers to unplug them easily.
LEs
Hide Signatures
(in reply to Rfabbre)
       Post #: 10
RE: Connectors - 5/6/2013 6:44 PM
Glacier Girl
Score: 122
Status: offline
quote:
ORIGINAL: Rfabbre
Thanx in advance
Not sure I would use a 45 amp rated plug for a 60 amp load...
Have you looked at the EC5 plugs from Hobby King? Rated at 120 amps. And like the Andersons, you solder the wire to the pins, then insert the pins into the housings. They'll handle a 10 gauge wire with ease and an 8 with a little work.
As for the spark arrestor, here's a picture of of one type. Just uses a resistor to connect first, before the main connection. Note Castle says you should not use them on their esc's.
Click to see fullsize image.
Click for fullsize
Missing Man Formation, Looking heavenward you can''t help but shed a tear,mournful, lonesome, a hole that screams out at you
Hide Signatures
       Post #: 11
RE: Connectors - 5/6/2013 7:39 PM
Rfabbre
Score: 100
Status: offline
Thanx for the info.  Do you leave the  spark arrestor connected during flight or unplug it after you connect the main wires?
Hide Signatures
(in reply to Glacier Girl)
       Post #: 12
RE: Connectors - 5/6/2013 8:37 PM
Glacier Girl
Score: 122
Status: offline
Disconnect the arrestor after you've hooked up the main connection. The small wire wouldn't survive the amp draw otherwise.
Hide Signatures
       Post #: 13
RE: Connectors - 5/6/2013 9:57 PM
Rfabbre
Score: 100
Status: offline
Got it.
Thanx
Hide Signatures
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.313RCU1
