X series Cat    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Nitro Boats >> X series Cat Page: [1] 2 3   next >   >>
Login
X series Cat - 7/2/2012 9:59 PM
F1madness
Score: 135
Last Login: 5/24/2013
Status: online
  I originally designed this hull for twin outboards but have decided to build it and enter it for class A racing aswell the hull is 38" x 13 1/4"
Iv just ordered an ASP 7.50cc nitro engine with genesis tuned pipe and manifold (which may need modding) i shall order the rest of the parts/hardware while i build the 1st hull,also need to build a radiobox but might mould 1 of these aswell for perfect fittment
So far iv built the plug and moulded it so prepping now to lay the 1st hull up
Im hoping to have the 1st done and built for the next race in september
This is how it looks so far but with without the rear upright cowls
The moulds
Proposed setup
Theres enough room to fit 2 x 24oz fuel tanks in the sponsons
3/16 driveline with offset rudder
ASP 7.5cc Nitro engine with tuned pipe (though i did consider 10cc 1st but thought to try it 1st with this setup)
This is where i need some advice as iv never run nitro before
What mixture/% nitro to run
What size off props
And do you tune the length of pipe like the gas engines
I heard good reports on these engines and for the bucks there OK
Any help would be greatfull
Thanks F1
_____________________________
RC Boating enthusiast and designer builder
Hide Signatures
       Post #: 1
RE: X series Cat - 7/3/2012 12:30 AM
rcguy1411
Score: 105
Last Login: 5/19/2013
Status: offline
nice looking hull the ASP 7.5 may leave you wanting more
Hide Signatures
(in reply to F1madness)
       Post #: 2
RE: X series Cat - 7/3/2012 12:48 AM
F1TUNNEL
Score: 100
Last Login: 5/13/2013
Status: offline
You wont need that much fuel Daz, I only run 8-12oz tanks in my 7.5 tunnels. You will love that smell of the nitro fuel in the air Daz!!
Hide Signatures
(in reply to rcguy1411)
       Post #: 3
RE: X series Cat - 7/3/2012 8:30 AM
F1madness
Score: 135
Status: online
Thanks bud
im thinking of building 2 more of these for my boys to have agao at racing with so i can put 10cc nitro in 1 me to play around with
quote:
ORIGINAL: rcguy1411
Hide Signatures
       Post #: 4
RE: X series Cat - 7/3/2012 8:33 AM
F1madness
Score: 135
Status: online
Hey Dion
I need them tanks as the heats are 15 or 20 min long sometimes longer upto 30mins
i had a couple of nitro cars but im going back yrs ago LOL but running them in boats is gonna be different and the engines will be better than the 1 i used to run hopefully
quote:
ORIGINAL: F1TUNNEL
Hide Signatures
(in reply to F1TUNNEL)
       Post #: 5
RE: X series Cat - 7/3/2012 10:43 AM
F1TUNNEL
Score: 100
Status: offline
Wow they are long heats, maybe you will need all of that fuel!! What sort of 10cc are you looking at?
cheers,
dion.
Hide Signatures
       Post #: 6
RE: X series Cat - 7/3/2012 12:35 PM
F1madness
Score: 135
Status: online
ill probably stich with the ASP's reason being there the only 1s i can get all the spares for with in a day or 2 as weve got a stockist here not far from me
iv looked at others but they  sell just the engines and not much spares wise etc
I have looked and the CMB but im not prepared to spend mega money on a nitro engine when some1 in the club running ASP 7.5 and staying with them no probs
Hide Signatures
       Post #: 7
RE: X series Cat - 7/3/2012 1:24 PM
Ron Olson
Score: 1175
Status: offline
To answer a few nitro questions for you; I know that nitro is very expensive in the UK so check to see if the ASP's are made for low or high nitro as some manufacturers build their engines for both. I'd generally run around 45% but you may have to make do with less.
We measure the pipes almost the same way as gas engines except that we use the center of the engine (glow plug) instead of the exhaust flange as a measuring point and on a 7.5cc usually about 10-1/2" (whatever that is in metric I don't know).
Generally, the ASP's suffer from having small sport carbs from planes so they really hurt performance. Yes, CMB's are very expensive even on this side of The Big Pond. Check into Nova Rossi's as the price is lower yet will keep up with the CMB's.
Member, Southwest Michigan Model Boat Club and the IMPBA.
269 Racing Team
Hide Signatures
       Post #: 8
RE: X series Cat - 7/3/2012 7:51 PM
F1madness
Score: 135
Status: online
Hi ron
been doing some research and it seems 20% nitro is recomended
Im not trying for any record speeds more consisitancy as iv decided once setup my 8yr boy will be racing it so should be fast enough for him while i build another 1 up with 10cc engine instead
The problem im having is finding a supplier for marine nitro engines here in the UK with a good back up of spares the only 1 iv found is   http://www.justengines.co.uk/index.html who retails the ASP engines at a reasonable price
can you tune the nitro engines or buy bigger/better carbs ????
Hide Signatures
(in reply to Ron Olson)
       Post #: 9
RE: X series Cat - 7/4/2012 9:04 AM
Hesco Racing
Score: 110
Status: offline
Hi,
When you say class-A in what series is this? And how light is the boat. We run the Go .28 motor in our Proboat thundercats and they are way over powered for the m-style course we run. I might have to see if I can buy a hull from you as a 38" hull sounds more like the size I need. What width is the tunnel part?
Cobus
Hide Signatures
       Post #: 10
RE: X series Cat - 7/4/2012 8:54 PM
F1madness
Score: 135
Status: online
HI Cobus long time no speak
Class A is with the BMPRS http://www.bmprs.co.uk/rules2012.html#boatspec
Once moulded the 1st  ll know a weight of the hull and let you know
ill have to measure the tunnel width as iv not got it too hand and cant remember of the top off my head haha
Hope your well bud
Rgds F1
Hide Signatures
(in reply to Hesco Racing)
       Post #: 11
RE: X series Cat - 7/8/2012 2:25 PM
F1madness
Score: 135
Status: online
Hi guys slight change of plan Iv just ordered new 10cc ASP engine for this cat so will now be entered in the B class
Iv got something a little bit more special for the A class new thread coming soon
Hide Signatures
       Post #: 12
RE: X series Cat - 7/8/2012 11:36 PM
HendricX
Score: 115
Last Login: 5/22/2013
Status: offline
You had better asked me ... good as new CMB-Evo_20** for 120€ .
And all the spares you need at Dave or Ian.
Hide Signatures
       Post #: 13
RE: X series Cat - 7/8/2012 11:45 PM
F1madness
Score: 135
Status: online
will email you
Hide Signatures
(in reply to HendricX)
       Post #: 14
RE: X series Cat - 7/10/2012 9:29 PM
F1madness
Score: 135
Status: online
Update
wetsanded the moulded halfs working through the grades from 320-1200g and lots of polishing to a shine
All thats left to do now is a good clean down and start the coats of release wax ready for making the 1st moulded hull
Hide Signatures
       Post #: 15
RE: X series Cat - 7/16/2012 9:57 AM
F1madness
Score: 135
Status: online
just starting the many coats of release wax,hoping to layup the 1st hull tomorrow to break the moulds in
Will post pics once done
Hide Signatures
       Post #: 16
RE: X series Cat - 7/16/2012 10:02 AM
F1TUNNEL
Score: 100
Status: offline
Look forward to the pics Daz. Cant wait to see how many different moulds you have in 12 months time!! I am sure the first one will turn out real nice like everything else!! Good luck tomorrow mate!!
Cheers,
Dion.
Hide Signatures
       Post #: 17
RE: X series Cat - 7/16/2012 10:22 AM
F1madness
Score: 135
Status: online
LOL cheers bud
ill have a few im starting back on the F1's this week aswell and got some some more ideas for this cat aswell so will start that soon once the 1st 1 done
Its all go LOL
Hide Signatures
       Post #: 18
RE: X series Cat - 7/22/2012 2:08 PM
F1madness
Score: 135
Status: online
1st attempt at moulding 1 of my designs
Here we go bit the bullet and layed up the 1st topdeck and trimmed ready for experimental join
couple of brisltes and bloody wind blew some small particles into the lay up but this 1 is just practise to see how it goes and also break the moulds in
The lower is layed up just waiting for it to cure abit more before trimming the edges
Hopefully join the 2 halves either later today of tomorrow then leave in the moulds for a couple of days before seeing the 1st ever hull iv moulded
Hide Signatures
       Post #: 19
RE: X series Cat - 7/22/2012 4:31 PM
rcguy1411
Score: 105
Status: offline
good luck on your first pull molds look nice
Hide Signatures
       Post #: 20
RE: X series Cat - 7/22/2012 11:20 PM
F1madness
Score: 135
Status: online
Cheers bud
and here it is
The 1st out the moulds
abit premature but its a practise 1 and a thin layup to break the moulds in but as you see it its straight out the moulds so not come out too bad at all
Hide Signatures
       Post #: 21
RE: X series Cat - 7/24/2012 5:34 PM
F1madness
Score: 135
Status: online
Just been playing around it
theres alot of ways this hull can be run
I placed in 7.5cc nitro engine but could even fit a 10cc
24oz fuel tank fits in the sponsons nicely aswell
couple of it floating LOL
Even inboard FE
Motor used is a leopard 4074,gives you some idea how much room there actually is
single setup
or twin setup
and the twin OB off course either FE or Nitro that it was designed for no pic of them yet as only have 1 LOL
Hide Signatures
       Post #: 22
RE: X series Cat - 7/25/2012 9:09 AM
Hesco Racing
Score: 110
Status: offline
Nice looking. What is the tunnel width? Looks narrow.
Cobus
Hide Signatures
       Post #: 23
RE: X series Cat - 7/25/2012 9:54 AM
F1madness
Score: 135
Status: online
Cheers Cobus
Sorry bud forgot you asked about the tunnel width
the width is 160mm or  just over 6 1/4 "
should be perfect for the length hull and the depth of the tunnel
Hide Signatures
       Post #: 24
RE: X series Cat - 7/25/2012 10:24 AM
madphil
Score: 105
Status: offline
Well Done Daz thats a great job , Keep up the good work
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.609RCU1
