Walbro or Tillotson Carb    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> Walbro or Tillotson Carb
Page: [1]
Login
Walbro or Tillotson Carb - 7/3/2012 3:56 PM
RCdude13
Score: 100
Last Login: 6/17/2013
Status: offline
I recently bought 2 used ZDZ80 Supers. One has a Tillotson carb and the other has a Walbro WJ-71. I want the best combination in the plane I am putting one of the engines in. Which carb should I use? I have a couple older ZDZ 80's with the Walbro WJ-71's and they run pretty good. Has anyone found the Tillotson to be an amazingly good carb? Is it far better than the Walbro?
Hide Signatures
       Post #: 1
RE: Walbro or Tillotson Carb - 7/3/2012 4:03 PM
VIRGINIA MODEL BUILDERS
Score: 105
Last Login: 5/31/2013
Status: offline
Tillotson carbs have been around and used since before 1960 good carbs
_____________________________
VAMODELBUILDERS
http://vamodelbuilders.com/
Hide Signatures
(in reply to RCdude13)
       Post #: 2
RE: Walbro or Tillotson Carb - 7/3/2012 5:27 PM
w8ye
Score: 318
Last Login: 6/19/2013
Status: offline
Tillotson carbs are now made in Ireland. they used to be made in the USA many years ago.
IMHO they are as good as Walbro and Zama but are not as common anymore.
I have a couple chainsaws with Tillotson carbs and I have not had any trouble with them that I would not have had with a Walbro for the last 13 years.
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to VIRGINIA MODEL BUILDERS)
       Post #: 3
RE: Walbro or Tillotson Carb - 7/3/2012 6:02 PM
spaceworm
Score: 143
Status: offline
Are rebuild kits as available as those for Walbro? Thanks.
Hide Signatures
(in reply to w8ye)
       Post #: 4
RE: Walbro or Tillotson Carb - 7/3/2012 7:48 PM
w8ye
Score: 318
Status: offline
I rebuilt one of mine last year and got the repair kit at the local chainsaw dealer. He had it on the shelf.
I see them advetised on the internet all the time by various distributors
Tillotson has a web site with charts like Walbro and Zama that lists all the Tillotson carbs, their setttings, and the pats numbers.
http://www.tillotson.ie/
Original AMA #31261
Hide Signatures
(in reply to spaceworm)
       Post #: 5
RE: Walbro or Tillotson Carb - 7/3/2012 8:00 PM
huck1199
Score: 115
Last Login: 6/18/2013
Status: offline
quote:
ORIGINAL: w8ye
Don't understand what you mean,
Hide Signatures
(in reply to w8ye)
       Post #: 6
RE: Walbro or Tillotson Carb - 7/3/2012 8:53 PM
w8ye
Score: 318
Status: offline
I don't understand what you don't understand?
Original AMA #31261
Hide Signatures
(in reply to huck1199)
       Post #: 7
RE: Walbro or Tillotson Carb - 7/3/2012 8:54 PM
Truckracer
Score: 309
Status: offline
Some people complain that Tillotson carbs are more difficult to adjust than a similar sized Walbro. No first hand experience here with a Tillotson in an airplane but I have worked with several of them in saws many years ago and couldn't see any differences for that application.
Hide Signatures
(in reply to w8ye)
       Post #: 8
RE: Walbro or Tillotson Carb - 7/3/2012 9:29 PM  1 votes
captinjohn
Score: 247
Status: offline
My thought is...the brand of a carburator does not matter.  If you get a good one in any brand...that what counts.  Capt,n
I never met a engine I did not like !
Hide Signatures
(in reply to Truckracer)
       Post #: 9
RE: Walbro or Tillotson Carb - 7/3/2012 9:32 PM  1 votes
huck1199
Score: 115
Status: offline
I am guessing you meant that you had the same problems with both.
Hide Signatures
(in reply to w8ye)
       Post #: 10
RE: Walbro or Tillotson Carb - 7/3/2012 9:34 PM  1 votes
spaceworm
Score: 143
Status: offline
quote:
ORIGINAL: huck1199
quote:
ORIGINAL: w8ye
Could W8YE mean that Walbro and Tillotson (and Zama) share a common sensitivity to dirt, and more importantly, to ethanol in the gasoline? Just my SWAG.
Hide Signatures
       Post #: 11
RE: Walbro or Tillotson Carb - 7/3/2012 9:47 PM
captinjohn
Score: 247
Status: offline
     JUST SAYING WHAT YOU MEAN     NOW
      ANY DAY ANY TIME                             NOW
      JUST MEANING WHAT YOU SAY     NOW
       LA   LA LA LA .....                                 NOW
      OR SOMETHING LIKE THAT !           NOW !
Hide Signatures
       Post #: 12
RE: Walbro or Tillotson Carb - 7/3/2012 9:50 PM
spaceworm
Score: 143
Status: offline
quote:
ORIGINAL: captinjohn
"Don't understand what you mean, "
Hide Signatures
(in reply to captinjohn)
       Post #: 13
RE: Walbro or Tillotson Carb - 7/4/2012 5:47 AM
2walla
Score: 100
Last Login: 6/12/2013
Status: offline
Tilotson carbs are fine.. Way way back a couple of manufacturers converting chainsaw motors were using the tillitson carbs that came with the powerheads they were buying.. These carbs had the RPM limiter circut start to kick in inflight and make the motor run erratic.. Once they figured out what was happening they started buying walbros cause they were cheaper instead of buying the correct Tilotson carb for what they were trying to do... This seemed to start some myth that walbros are better...
Hide Signatures
       Post #: 14
RE: Walbro or Tillotson Carb - 7/4/2012 2:17 PM
matt43
Score: 100
Last Login: 6/11/2013
Status: offline
Have had 2 friends one with a 3w 106 and one with a ZDZ 80 both had terrible starting issues an tuning issues once running using a starter it would tune and run great... Shut it down it wont restart with out adjusting the tilitson carbs... Both got fed up bought a walbrough and none have had an issue since
Hide Signatures
(in reply to 2walla)
       Post #: 15
RE: Walbro or Tillotson Carb - 7/4/2012 2:45 PM
captinjohn
Score: 247
Status: offline
quote:
ORIGINAL: matt43
I wonder....did the equipment the tilitson carbs do the same thing.  I think NOT!   There is more to this story...now where is Paul Harvey ?
Hide Signatures
(in reply to matt43)
       Post #: 16
RE: Walbro or Tillotson Carb - 7/4/2012 4:20 PM
w8ye
Score: 318
Status: offline
Besides the Dolmar chainsaws with Tillotson carbs, I have a couple Stihl chainsaws with Tillotson carbs that I have never worked on.
Original AMA #31261
Hide Signatures
       Post #: 17
RE: Walbro or Tillotson Carb - 7/4/2012 5:21 PM
Truckracer
Score: 309
Status: offline
quote:
ORIGINAL: w8ye
w8ye, your knowledge base seems extensive and you often refer to chainsaws you own. Are you a saw collector? Or do you just use them often enough to need / want a variety? Just curious. I have often thought of collecting them myself.
Hide Signatures
(in reply to w8ye)
       Post #: 18
RE: Walbro or Tillotson Carb - 7/4/2012 5:23 PM
Truckracer
Score: 309
Status: offline
quote:
ORIGINAL: matt43
The various forums are full of stories similar to the above.
Hide Signatures
       Post #: 19
RE: Walbro or Tillotson Carb - 7/4/2012 6:21 PM
w8ye
Score: 318
Status: offline
quote:
ORIGINAL: Truckracer
quote:
ORIGINAL: w8ye
I have a good many more popular professional chainsaws from the late 90's up to the present but no strato versions of anything.
Original AMA #31261
Hide Signatures
       Post #: 20
RE: Walbro or Tillotson Carb - 7/4/2012 7:07 PM  1 votes
chris923
Score: 130
Status: offline
quote:
ORIGINAL: spaceworm
quote:
ORIGINAL: huck1199
quote:
ORIGINAL: w8ye
I have both carb, and use 10% enthanol 89 oct with lawnboy ashless........NEVER had a problem with either.
Chris
Chris923
(Capt. Cluck) Screamin'' Chicken Squadron
The Flying Electrons
Meno. Falls, Wisconsin
Hide Signatures
       Post #: 21
RE: Walbro or Tillotson Carb - 7/4/2012 8:02 PM  1 votes
raydar
Score: 142
Status: offline
Sometimes the best carb for your engine is not the one supplied by the manufacturer, sometimes there is nothing wrong with the carb or make,  but simply the venturi size does not suit the engines design.
I have swapped "bad carbs" onto another brand engine and ended up with a great running engine and more rpm than what was supplied by the manufacturer.
I find its worth experimenting with diferent carb/engine set ups as the carb can make a huge difference to power output and how a motor runs.
Hide Signatures
(in reply to chris923)
       Post #: 22
RE: Walbro or Tillotson Carb - 7/4/2012 8:19 PM
captinjohn
Score: 247
Status: offline
I think it may be a good Idea sometime to start a new thread.  Subject...Good Carb swaps !
Hide Signatures
(in reply to raydar)
       Post #: 23
RE: Walbro or Tillotson Carb - 7/4/2012 9:23 PM
ggraham500
Score: 108
Status: offline
+1
With airplanes, keep the pointy end going forward as much as possible.
Hide Signatures
       Post #: 24
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> Walbro or Tillotson Carb
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.797RCU1
