Earthquake 3.5 differntial    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> Earthquake 3.5 differntial
Page: [1]
Login
Earthquake 3.5 differntial - 7/3/2012 7:15 PM
Shady9503
Score: 100
Last Login: 6/17/2013
Status: offline
 So i had an issue with my earthquake where after about 5 mins of run time, all the power would go to my front wheels, i thought my differntial was done considering i tore the care apart and couldnt find a loose screw anywhere (loctited everything when i got it) so i assumed something in the differential, i picked up a new diff from a local redcat dealer and when im putting the screws in i noticed that the second i tighten them around the diff case the differential stops spinning completely, lossen them and it spins fine, im confused because i dont wanna seal the differential and put it back together and when i go to run the truck see the rear wheels not spin and get stuck taking it apart again,
_____________________________
Tornado S30, Earthquake 3.5, Hurricane XTR
Hide Signatures
       Post #: 1
RE: Earthquake 3.5 differntial - 7/4/2012 7:55 PM
Dads like rc too
Score: 540
Last Login: 6/18/2013
Status: offline
quote:
ORIGINAL: Shady9503
Did you make sure your installing the correct screw in the correct space. I'm not sure but I thought there are at least two different length screws. They're the same thread and pitch. It very easy to put the longer screws into the shorter holes. Doing this will certainly bind the diff.
Caldera 10e : Volcano EPX : Monsoon XTR : Sumo x2 :
Hide Signatures
(in reply to Shady9503)
       Post #: 2
RE: Earthquake 3.5 differntial - 7/5/2012 6:26 PM
Shady9503
Score: 100
Status: offline
 Yeah i took out the screws they are the same length and everything, once i tighten the screws even a little the diff binds and its confusing ive had my truck apart for a week now its frustrating lol
Hide Signatures
(in reply to Dads like rc too)
       Post #: 3
RE: Earthquake 3.5 differntial - 7/5/2012 10:41 PM
kelynsdad1023
Score: 100
Last Login: 6/13/2013
Status: offline
check to make sure there are no like no little nipples and what what not on the ring gear, I had them on a few diffs that I bought for that truck. if there are it won't spin in right in the housing. Just grind it down a tad and it should work.
Hide Signatures
       Post #: 4
RE: Earthquake 3.5 differntial - 7/18/2012 4:04 AM
Shady9503
Score: 100
Status: offline
 So i finally found my problem! after checking grub screws, drive shafts, differentials and everything i possibly could and not finding a problem i sat down and thought "things dont just not work like that. theres a reason somewhere." i took off the rims, and took off the rim hub, the inside of my rim hub was completely stripped out, so the pin that was there would just spin, without giving power at all, rendering the rear end powerless just thought id update incase someone runs into a similar situation!
Hide Signatures
(in reply to kelynsdad1023)
       Post #: 5
RE: Earthquake 3.5 differntial - 7/18/2012 2:44 PM
Valgath
Score: 100
Status: offline
 interesting ive never had any problems with  my EQ 3.5 aside from driver errors or bashing to hard  with things breaking . Iguess im one of the lucky ones .
Hide Signatures
       Post #: 6
RE: Earthquake 3.5 differntial - 7/19/2012 3:44 AM
Shady9503
Score: 100
Status: offline
 Same here, its an amazing truck it holds its tune i put it through hell it only breaks when i screw up sometimes, like hitting a curb :P this one problem confused me though but finally figured it out and had some fun with it today
Hide Signatures
(in reply to Valgath)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.422RCU1
