1987 Seaplane    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Seaplanes >> 1987 Seaplane Page: [1]
Login
1987 Seaplane - 7/5/2012 5:47 PM
billd76
Score: 327
Last Login: 5/20/2013
Status: offline
Good day all. I friend of mine at work gave me a seaplane. It has the words mermaid on the side. The bottom is plastic, and there's is a decal on the horizonatl stab that says copyright 1987, Japan.
It has a 60.5 inch dihedral wing and a nitro engine mount. It is in great shape, but needs a little TLC. Need you input as too engine size, manufacturer, CG, etc....
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
SSGT USMC 75,83 Son Brian USMC Intel/Excelon Energy Corp, Son Matt USMC Air Traffic Control/Penn State
Hide Signatures
       Post #: 1
RE: 1987 Seaplane - 7/5/2012 7:20 PM
scale only 4 me
Score: 314
Status: offline
"EZ" was the line,, by "OK Models"
You have a rare find there
Hide Signatures
(in reply to billd76)
       Post #: 2
RE: 1987 Seaplane - 7/5/2012 7:25 PM
Charlie P.
Score: 192
Status: offline
US flags are backwards (blue field always points in the direction of forward travel - shoulders, fuselages, etc.) but otherwise a good looking ARF.
Charlie P. (NY) "Gravity is weak but persistant".
AMA 747089/IMAA 30723
Hide Signatures
(in reply to scale only 4 me)
       Post #: 3
RE: 1987 Seaplane - 7/6/2012 12:30 AM
JimCasey
Score: 115
Status: offline
The E-Z models were popular for a while.  The covering is a structural laminate of foam, paper, and film,  Really pretty but hard to repair.
Bless you for your service in The Corps.  I have a nephew flying V22s.  His dad flew Cobras and in HMX-1  Semper-Fi.
Jim Casey/Seaplane Nerd
http://www.smilesandwags.com/Floats.html
Hide Signatures
(in reply to Charlie P.)
       Post #: 4
RE: 1987 Seaplane - 7/6/2012 2:50 AM
billd76
Score: 327
Status: offline
Thanks all. There is a pontoon missing from one wing. but honestly it looks like one was never there. But I assume there was. I might just have to install landing gear on this one. I'm thinking a OS 55AX should power it nicely. Motor mount is already installed. I would love to try it from the water, but not sure about the missing pontoon. SemperFI Jim. All of us are finally civilians. well at least we're trying to be. Nothing like the Corps and we all miss it. There's just no discpline out here in the civilian world. It is an extremely sad state of affairs. Tell your Nephew thanks for serving. I actually was involved with alot of testing on the V22. I was always impressed with the professionalism of the flight crews. They were top notch!!!
Hide Signatures
(in reply to JimCasey)
       Post #: 5
RE: 1987 Seaplane - 7/6/2012 3:24 AM
scale only 4 me
Score: 314
Status: offline
A .46 or a 70 4-stroke would be perfect IMO, but the 55 will work, try to keep it lite as possible, it would be pretty easy to fabricate a pontoon out of foam/glass/paint. Personally I think it would be a shame not to see it fly off the water.
just find a online CG calculator,, should be pretty easy to figure with that wing shape
http://www.geistware.com/rcmodeling/cg_calc.htm
good luck
Hide Signatures
       Post #: 6
RE: 1987 Seaplane - 7/6/2012 10:27 PM
siddus74
Score: 100
Last Login: 5/18/2013
Status: offline
If the manufacturer has done his job the CG will be about 1/2 an inch infront of the forward most step ....
Also I would be paying much attention to that elevator snake and rod, if you leave it like that Im thinking you'll only see one flight from it!!!
Scott.
siddus74
Hide Signatures
       Post #: 7
RE: 1987 Seaplane - 7/7/2012 12:09 PM
scale only 4 me
Score: 314
Status: offline
Good catch Scott
Hide Signatures
(in reply to siddus74)
       Post #: 8
RE: 1987 Seaplane - 7/7/2012 12:14 PM
billd76
Score: 327
Status: offline
quote:
ORIGINAL: siddus74
Scott.
Scott,
yes I seen the control horns on the elevator, too close to the rudder control horn for my liking.
< Message edited by billd76 -- 7/7/2012 2:32 PM >
Hide Signatures
       Post #: 9
RE: 1987 Seaplane - 7/7/2012 2:33 PM
billd76
Score: 327
Status: offline
quote:
ORIGINAL: billd76
quote:
ORIGINAL: siddus74
Scott.
Scott,
yes I seen the control horns on the elevator, too close to the rudder control horn for my liking. Plan on switching out the control rods as well with some CF or 4/40
Hide Signatures
       Post #: 10
RE: 1987 Seaplane - 7/7/2012 4:16 PM
scale only 4 me
Score: 314
Status: offline
quote:
ORIGINAL: billd76
quote:
ORIGINAL: siddus74
Scott.
Scott,
I'm pretty sure he's talking about how that short piece of all thread is going to kink and fold up on you the first time you put any real G-load on the elevators,, that wire should extend into the tube inside the fuselage.
personlly I don't like the way the they are coupled at the other end either.
I aquaried a nice short time, seriously damaged Midwest AT6 for the same reason
Hide Signatures
       Post #: 11
RE: 1987 Seaplane - 7/7/2012 7:30 PM
JimCasey
Score: 115
Status: offline
Right you are, Scale Only 4 Me!
There is an easy way to make nyrods work very well.   The metal link should be from the anchored end of the Nyrod sheath to the clevis.
If you make the plastic pushrod the same length as the sheath, then they will both grow/shrink the same amount with temperature changes. It's important only to anchor the ends of the sheath and to have a nearly but not exactly straight run.  Growth/shrinkage of the sheath/pushrod  happen together and the pushrod/sheath assembly can flex as it grows or shrinks together..   Guys who tie the sheath down in 16 places don't let it move, but the pushrod still grows/shrinks and the trim changes.  OR they make the unsupported end of the pushrod so it whips in the breeze and has little resistance to buckling.
Hide Signatures
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.391RCU1
