Yellow Aircraft Spitfire Build !!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
1/5 Scale Don Smith's Henschel HS-129B - RTF
Seller:  Dumb Thumb
Details:   $2,750.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> Yellow Aircraft Spitfire Build !!
Page: [1] 2 3 4   next >   >>
Login
Yellow Aircraft Spitfire Build !! - 7/7/2012 1:01 PM
Check6
Score: 105
Last Login: 5/19/2013
Status: offline
I will be building / assembling a Yellow Spitfire for a good friend of mine. He will be doing all the finish and painting I will be doing the construction and get it to the glassing stage. This will be basically a total stock build with some changes along the way. Engine, radio, retracts, installed. Feel free to add your comments.
Fred Menna Check6
Hide Signatures
       Post #: 1
RE: Yellow Aircraft Spitfire Build !! - 7/7/2012 4:56 PM
Check6
Score: 105
Status: offline
I'll be installing the new firewall kit that is manufactured by Leo Spychalla. This is a well made firewall that is 1/2 in. thick and relocates the DA 50 deeper into the fuse allowing the engine to be less noticable. You need 1 1/4 standoffs and 1 1/4 prop extension. I don't have the extension yet so I will fabricate a spacer to use while fitting the engine. First step is to drill out the factory firewall.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Check6)
       Post #: 2
RE: Yellow Aircraft Spitfire Build !! - 7/7/2012 5:33 PM
ccostant
Score: 100
Last Login: 5/20/2013
Status: offline
Hi Fred,
I have a YA Spit kit and was thinking of the same engine combo. What's the plan for the muffler? Take lots of pictures so I can copy your build.
Carl
Hide Signatures
       Post #: 3
RE: Yellow Aircraft Spitfire Build !! - 7/7/2012 6:10 PM
Tony Gag Jr.
Score: 100
Last Login: 5/11/2013
Status: offline
Carl,
Fred is building this Spit for me. It will be using a B&B muffler just like Leo used in the instructions with his firewall kit.
Later,
Tony Gag Jr.
Hide Signatures
(in reply to ccostant)
       Post #: 4
RE: Yellow Aircraft Spitfire Build !! - 7/7/2012 6:15 PM
Check6
Score: 105
Status: offline
Hi Carl,
I'm following Leo's instructions. He uses a Bennett flat muffler. Follow along.
You now have to remove the nice factory firewall. I drilled 7/8 in. holes around the perimeter then break out the firewall with a plier. You then have to remove the glue ridge and firewall remains. I used a 2 in. sanding drum attached to an electric drill. Be careful you don't sand through the fuse. Unfortunately I did in some spots but reglassed it from the inside with cloth and CA. One thing about fiberglass fuses they love CA. Now I'm trial fitting the new firewall.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 5
RE: Yellow Aircraft Spitfire Build !! - 7/9/2012 2:03 AM
Check6
Score: 105
Status: offline
Have to wait to finish the firewall install. Need a machined spacer from Sierra. Guess I'll start on the tail surfaces.
Fred
Hide Signatures
       Post #: 6
RE: Yellow Aircraft Spitfire Build !! - 7/9/2012 5:45 AM
Chad Veich
Score: 265
Status: offline
I got plans for a built up tail if you need them Fred. Saves a few ounces in the tail, gets rid of the oil canned appearance of the glass, and allows for scale recessed hinging. All yours if you want 'em.
Hide Signatures
       Post #: 7
RE: Yellow Aircraft Spitfire Build !! - 7/9/2012 12:14 PM
Check6
Score: 105
Status: offline
Hi Chad,
Thanks for the reply and offer. Tony is OK with the stock setup. I will be changing the ply cores yellow uses to balsa and eliminating some dead weight as you point out in your plans.
Fred
Hide Signatures
(in reply to Chad Veich)
       Post #: 8
RE: Yellow Aircraft Spitfire Build !! - 7/14/2012 7:14 PM
Check6
Score: 105
Status: offline
Laid out the rib lines on the stab blanks, glued in the ribs and Leading edge, tips added and rough sanded hinge holes glued
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 9
RE: Yellow Aircraft Spitfire Build !! - 7/19/2012 5:36 PM
Check6
Score: 105
Status: offline
OK I have the rudder roughed out, I will be drilling lightening holes for the elevators as well.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 10
RE: Yellow Aircraft Spitfire Build !! - 7/19/2012 5:41 PM
Check6
Score: 105
Status: offline
I'm going back to the engine installation. I received the prop extension from Sierra and bolted it on the engine all locktighted in. Now I can set the correct spacing with the spinner backplate and the front of the fuse.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 11
RE: Yellow Aircraft Spitfire Build !! - 7/19/2012 11:56 PM
Tony Gag Jr.
Score: 100
Status: offline
Looking good Fred!
Hide Signatures
       Post #: 12
RE: Yellow Aircraft Spitfire Build !! - 7/20/2012 12:04 AM
Check6
Score: 105
Status: offline
Hey Tony, it's getting there!! Once I have the new firewall mounted , I'll start on the wings and retracts.
Fred
Hide Signatures
(in reply to Tony Gag Jr.)
       Post #: 13
RE: Yellow Aircraft Spitfire Build !! - 7/20/2012 3:38 AM
Spychalla Aircraft
Score: 100
Last Login: 5/15/2013
Status: offline
Fred,
Nice job! With this set-up there is one thing you need to do to your DA-50. You must replace the 4 aluminum back crankcase bolts with steel. The prop extension has a tendency to stretch the aluminum bolts and you will blow out the crankcase gasket roughly every 20 flights if you don't do it. I know because I had it happen repeatably twice. The steel bolts will not stretch and it seems to solve the problem. Leo
Hide Signatures
       Post #: 14
RE: Yellow Aircraft Spitfire Build !! - 7/20/2012 11:07 PM
Check6
Score: 105
Status: offline
Hi Leo,
Thanks for the heads up on the screws. Tony will be glad to know about that problem. BTW You make a high quality product, keep up the great work.
Fred
Hide Signatures
(in reply to Spychalla Aircraft)
       Post #: 15
RE: Yellow Aircraft Spitfire Build !! - 7/21/2012 12:19 AM
Tony Gag Jr.
Score: 100
Status: offline
Thanks for the heads up Leo! I will change those bolts out when I get the plane back from Fred.
Tony
Hide Signatures
       Post #: 16
RE: Yellow Aircraft Spitfire Build !! - 7/21/2012 12:57 AM
ccostant
Score: 100
Status: offline
Hi Tony,
Put some lock washers and locktite on the carb bolts too. I had one back out on my P-51. Be careful to not tighten them down too much otherwise you can distort the isolation block.
Carl
Hide Signatures
       Post #: 17
RE: Yellow Aircraft Spitfire Build !! - 7/21/2012 12:47 PM
Tony Gag Jr.
Score: 100
Status: offline
Will do Carl. Thank you!!
Hide Signatures
       Post #: 18
RE: Yellow Aircraft Spitfire Build !! - 7/21/2012 2:06 PM
Check6
Score: 105
Status: offline
Hi Tony and Carl,
Thanks for the tips. Tony I have already installed the steel bolts also added lock washers and threadlocking. You should be good to go.
Stay tuned.
thanks,
Fred
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 19
RE: Yellow Aircraft Spitfire Build !! - 7/22/2012 1:53 PM
Check6
Score: 105
Status: offline
OK Now we fit the engine to the fuse. First you slide the firewall into the fuse. Then clamp the whole engine , spinner backplate assembly to the front of the fuse. place in a 3/32 scrap balsa for proper spinner clearance. Slide the firewall against the mounting standoffs and Thick CA the standoffs to the firewall. This gives you the outline to drill the mounting holes. Remove the whole assembly and then drill the mounting holes for the engine. You can then drill access holes to adjust the needle valves. Reassemble the whole setup again and tack glue the firewall in. When dry remove the engine and run a nice fillet of glues and glass cloth to the front and rear of the firewall.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 20
RE: Yellow Aircraft Spitfire Build !! - 7/22/2012 9:20 PM
Check6
Score: 105
Status: offline
OK guys, I have made an error with the engine installation. I installed the engine vertically when it is suppose to be mounted on an angle to line up with the fiberglass shell that is on the firewall. When you angle the motor it allows the muffler to fit closer without having to cut up the cowl. This was pointed out by Tony Gag Jr. who owns the Spit that I'm working on. Fortunately everything was just tacked glued which allowed me the pop out the firewall with no damage. Had to realign everything but now it fits like it's suppose to.
Thanks for pointing that out to me Tony before I locked everything in.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 21
RE: Yellow Aircraft Spitfire Build !! - 7/24/2012 8:44 PM
Check6
Score: 105
Status: offline
Put the fuse aside for a while and starting on the wings. I'm not a big fan of the fiberglass wingtips supplied in the kit so I fabricated new ones out of 3/4 in. soft balsa blocks. These will be stronger and won't deflect if you grab a wingtip.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 22
RE: Yellow Aircraft Spitfire Build !! - 7/25/2012 2:00 PM
JeffH
Score: 114
Last Login: 5/17/2013
Status: offline
I always thought it strange to have the 'glass wingtips. It is not that much work to carve a chunk of balsa, esp if the outline is alrady cut at the factory. By the time you put a couple of internal ribs in the wingtips to keep them from crushing, do the body work to blend them into the glassed wing, the wood tips would have been quicker and better looking.
Hide Signatures
       Post #: 23
RE: Yellow Aircraft Spitfire Build !! - 7/26/2012 1:25 PM
Brad330l
Score: 140
Status: offline
quote:
ORIGINAL: JeffH
I almost wrecked my glass ones by filling them with expander foam that did not go off properly. They worked out fine in the end and are a great shape but I would not have worried if the kit had balsa blocks as tips.
One thing, I am sooo afraid that I will knock a tip and destroy it in a door or something.
Good luck Check6,
Brad
_____________________________
Visit pilbaraaeromodellers.com
Spitfire Brotherhood # 5
Hide Signatures
(in reply to JeffH)
       Post #: 24
RE: Yellow Aircraft Spitfire Build !! - 7/26/2012 1:36 PM
wphilb
Score: 105
Status: offline
I actually like the glass tips, just glued them on and then ran the .75oz cloth from the center section all the way out and over the tips, just sanded the cloth off on the outline after the resin dried and primed away. It would be a pain to try to feather the cloth into the glass tips so just run the cloth all the way out. Also easier to feather the tips into the balsa sheeting after glassed, but I know others do it first.
You do have to watch that you don't stand the wings on the tips while cleaning, assembling, storing etc they will bow.
Whit
Hide Signatures
(in reply to Brad330l)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.828RCU1
