Need to fix warped rudder and vert stab.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> Need to fix warped rudder and vert stab.
Page: [1]
Login
Need to fix warped rudder and vert stab. - 7/9/2012 5:30 AM
skeeter_ca
Score: 121
Last Login: 3/6/2013
Status: offline
I have a warpage problem with my rudder and vert stab. As you can see in the video i was hoping to epoxy in a carbon fiber rod helping it to stay straight. Do you think this can work or do you have any other ideas that might be better?
skeeter
_____________________________
"It is easier to ask for forgiveness than permission".
Hide Signatures
       Post #: 1
RE: Need to fix warped rudder and vert stab. - 7/9/2012 5:35 AM
tschuy
Score: 111
Last Login: 5/20/2013
Status: offline
 Steam it and then press it on a flat surface with a bunch of weight.  Let it sit for day or so and pull it out.  Should be straight.  Will need to sand smooth again as it will raise the grain a bit when you steam it...
I had the same issue and this worked for me.  Get the wood steamed pretty good.
Tim Schuy
tschuy@comcast.net
Hide Signatures
(in reply to skeeter_ca)
       Post #: 2
RE: Need to fix warped rudder and vert stab. - 7/9/2012 5:40 AM
countilaw
Score: 219
Last Login: 5/22/2013
Status: offline
The carbon fiber rod won't help.       There are two things that will help.     One,    take a hot steam iron and press the  inside curve of the warp with the steam.
The other is,     cut off the warped section and glue a straight piece in it's place.
Frank
It''s a hobby, not a job.
Hide Signatures
       Post #: 3
RE: Need to fix warped rudder and vert stab. - 7/9/2012 3:09 PM
LesUyeda
Score: 151
Status: offline
"Do you think this can work ?"
Yes.
"The carbon fiber rod won't help."
I'll argue that. In the OLD days we used to do the same thing with just another piece of balsa wood the same thickness. Kept things as flat as you would want.
Les
Hide Signatures
(in reply to countilaw)
       Post #: 4
RE: Need to fix warped rudder and vert stab. - 7/9/2012 3:33 PM
Live Wire
Score: 6329
Last Login: 5/23/2013
Status: offline
windex method who needs steam.
Larry K AMA 36417
Sig Kadet Brotherhood # 4 WACO Brotherhood #34 Cub Brotherhood 14
Hide Signatures
(in reply to LesUyeda)
       Post #: 5
RE: Need to fix warped rudder and vert stab. - 7/9/2012 4:17 PM
skeeter_ca
Score: 121
Status: offline
quote:
ORIGINAL: Live Wire
Can you elaborate??
skeeter
Hide Signatures
(in reply to Live Wire)
       Post #: 6
RE: Need to fix warped rudder and vert stab. - 7/9/2012 5:47 PM
Live Wire
Score: 6329
Status: offline
Windex works the same as steam and will moisten the wood , You spray the inner side of the curved wood and it will swell and straigten out . Then weight it down and let it dry. I put paper towels on both sides to absorb the moisture and speed drying. With a scrap peace of sheet balsa spry one side and watch what happens
Larry K
Larry K AMA 36417
Hide Signatures
       Post #: 7
RE: Need to fix warped rudder and vert stab. - 7/9/2012 6:07 PM
Gray Beard
Score: 314
Status: offline
As Frank said, you can just cut out the warp and glue in a new piece, it just looks like 1/4 inch balsa. Your over thinking it. You can glue it on straight using pins, once glued down and set up is should be fine. The little warp in the rudder can be removed with your covering, you bend it straight and use your heat gun on the other side of the warp and the covering will tighten up and hold it straight. I just use ammonia and water {the windex trick} it's the ammonia that softens up the wood. You can try spraying the inside of the warp to remove it.
Or the EASY WAY. Just buy some 1/4 inch balsa and cut new parts if you mess up the warp. Sometimes you can make it worse!
Kit builders should have 1/4, 1/16, 1/32 and 1/8 sheeting on hand in there shop for these little problems. Not a lot but a sheet or two. Hobby People have balsa in stock and Hobby Town but they charge a bunch for it. As a scratch builder I buy it in bulk from National Balsa and it is very cheap that way but you need to buy too much. Kit building friends are always hitting me up for a piece of wood so if you have any builder friends make a phone call, we don't mind helping out.
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
       Post #: 8
RE: Need to fix warped rudder and vert stab. - 7/9/2012 6:28 PM
JRgraham
Score: 105
Status: offline
quote:
ORIGINAL: Gray Beard
JR Graham
D8, AMA 201522
Hide Signatures
(in reply to Gray Beard)
       Post #: 9
RE: Need to fix warped rudder and vert stab. - 7/9/2012 6:30 PM
Edwin
Score: 156
Status: offline
Grey Beard beat me to it. I'd just cut a new ones. And I agree on having standard wood sizes for whatever you want to do for repairs, or scratch building. I buy wood by the box car load. It lasts me a long time and stays good if you store it properly.
Edwin
Hide Signatures
       Post #: 10
RE: Need to fix warped rudder and vert stab. - 7/9/2012 7:56 PM
JollyPopper
Score: 158
Status: offline
What scale box car is that, Edwin?
"In theory, there is no difference between theory and practice; In practice, there is"
Hide Signatures
(in reply to Edwin)
       Post #: 11
RE: Need to fix warped rudder and vert stab. - 7/9/2012 8:50 PM
Edwin
Score: 156
Status: offline
Why full scale, naturally! Just kidding. My wood purchases usually come to $400 to $600. That sets me up for awhile.
Edwin
Hide Signatures
(in reply to JollyPopper)
       Post #: 12
RE: Need to fix warped rudder and vert stab. - 7/10/2012 3:06 PM
LesUyeda
Score: 151
Status: offline
"Kit builders should have 1/4, 1/16, 1/32 and 1/8 "
Good luck finding those sizes. The last Midwest sheet I picked up (in a panic) turned out to be the nearest metric equivalent??, not inches.
Les
Hide Signatures
(in reply to Edwin)
       Post #: 13
RE: Need to fix warped rudder and vert stab. - 7/10/2012 4:46 PM
SeamusG
Score: 199
Last Login: 4/10/2013
Status: offline
Then there's SIG - 3/16 & 5/16 for just about everything.
Hide Signatures
       Post #: 14
RE: Need to fix warped rudder and vert stab. - 7/10/2012 5:41 PM
Live Wire
Score: 6329
Status: offline
Or he could just sand it tappered and have a better flying plane
Larry K AMA 36417
Hide Signatures
(in reply to SeamusG)
       Post #: 15
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.422RCU1
