RE: New DLE 35    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: New DLE 35 Page: <<   < prev  4 5 [6] 7 8 9 10 11 12 13   next >   >>
Login
RE: New DLE 35 - 9/20/2012 6:48 PM
rica1
Score: 100
Last Login: 6/14/2013
Status: offline
Rich information, and I lean in your direction! Slightly rich on the high needle and low needle with good transition I believe he said.
Hide Signatures
(in reply to MTK)
       Post #: 126
RE: New DLE 35 - 9/21/2012 1:47 AM
airborne2.4
Score: 105
Last Login: 6/16/2013
Status: offline
quote:
ORIGINAL: Condor060
Hey ya fellas, I caught your thread on the DLE 35 and wanted to show you the newest project Troy Built has me working on. I have one of their 71 inch Mustangs with the DLE 35. We flite metaled the stang, installed a Keleo custom exhaust and are using a 17 inch 4 bladder.  We also installed a Dynamic Balsa Cockpit kit. Thought I might share a few pics and some results once we get her breathing some fire.
Is there a reason why the exit of the exhaust (4th picture) is pointing towards the carb?
_____________________________
If you think you can or think you can''''t, you''''re right.
Hide Signatures
(in reply to Condor060)
       Post #: 127
RE: New DLE 35 - 9/21/2012 2:03 AM
rcguy59
Score: 129
Last Login: 6/19/2013
Status: offline
In order to attach to the scale exhaust stacks.
Jet Central Superbee & Rabbit
12Z Fasst for everything I fly
Hide Signatures
(in reply to airborne2.4)
       Post #: 128
RE: New DLE 35 - 9/21/2012 2:25 AM
Condor060
Score: 156
Last Login: 6/18/2013
Status: offline
We ran the motor today. 5400 RPM with the 4 bladder and 30 to 1 fuel. We got 24 lbs of thrust and expect the build to come in at 16. This should be fun
Hide Signatures
(in reply to rcguy59)
       Post #: 129
RE: New DLE 35 - 9/21/2012 4:42 AM
WI53072
Score: 100
Status: offline
Guys,
what is the "trick" to getting the spark plug wire hooked onto the spark-plug?? Something sem wrong or?? The wire just wont go on far as I can tell. Maybe I am missing something??
Wonder Rather Than Doubt, Is The Root Of All Knowledge.
Sig Kadet Brotherhood #20
Hide Signatures
(in reply to rica1)
       Post #: 130
RE: New DLE 35 - 9/21/2012 5:53 AM
rmoose
Score: 100
Last Login: 1/31/2013
Status: offline
fits tight just push and give a little twist tt will pop on !  as it is taken on and off will get a little easyer. i use a flat screw drive to remove but you dont waint to force it or break fins in the engine. just new i throught  i was going to break the socket the first time i snaped mine on   p.s  if spring pops out the big end goes in first . use a small pocket screw driver to seat sprig in cap really don't have to have it in there just a ex. ground  ===hope this helps
Hide Signatures
(in reply to WI53072)
       Post #: 131
RE: New DLE 35 - 9/21/2012 4:07 PM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: WI53072
Guys,
what is the ''trick'' to getting the spark plug wire hooked onto the spark-plug?? Something sem wrong or?? The wire just wont go on far as I can tell. Maybe I am missing something??
On the leading end of the boot there is a spring clip that closes the boot once it is on the spark plug. When the spring clip is seated, the boot is closed and you would have a heck of time trying to insert the boot on the plug. You will need to remove the clip, insert the boot and then move the clip down to close the boot.
OR...you can do what I do. I throw the spring clip away and use a piece of silicone rubber o-ring in its place. The rubber "gives" when you insert the boot so installation is no problem, yet it holds the boot firm onto the plug until you want to remove the boot.....
Regards,
MattK
Hide Signatures
       Post #: 132
RE: New DLE 35 - 11/2/2012 9:57 PM
rino
Score: 115
Last Login: 6/15/2013
Status: offline
How does the DLE 35 compare to the OS 33. From the specs it looks like the DLE 35 has even more power. But...specs lie.
Hide Signatures
(in reply to MTK)
       Post #: 133
RE: New DLE 35 - 11/3/2012 4:10 AM
MTK
Score: 203
Status: offline
I don't have a DLE35 and have not seen it run
I have the OS33 GT and that little gassie is something else. It has an appetite for really big loads and turns them with very useful authority throughout the throttle range. It may very well be the best engine OS ever made. I've been around this game for 45 years and I've seen the good, bad and ugly from OS
Mine is piped so it's not a one to one comparison. Mine turns apc 20.5 x 10, 20 x 10.5, 19.5 x 11.5 at over 7K at full revs which I don't have to use, ever, in my type of aerobatics. Any of these props will take my 11 1/4 # pattern plane OOS at half throttle.
Not just the DLE but any 30-40cc engine will do very well to match that performance. I can only hope the DLE is close since the rear exhaust config is more convenient for my pattern planes. That goes for the PTE36 also which I am just about ready to try in a new model
Regards,
MattK
Hide Signatures
(in reply to rino)
       Post #: 134
RE: New DLE 35 - 11/3/2012 4:24 AM
rcguy59
Score: 129
Status: offline
I'm intrigued by this as well. My DLE 35RA has less than a gallon through it and is already an ANIMAL. Very impressive. It's about due for another needle-tweak, so the next time I take it out, I'll tach it and post the results. Unfortunately, no one at our field has an OS 33 that I know of. Haven't seen any OS 55's either, come to think of it. Lots of DLE's and DA's, plus a few 3W's, though.
Hide Signatures
(in reply to MTK)
       Post #: 135
RE: New DLE 35 - 11/3/2012 12:45 PM
airborne2.4
Score: 105
Status: offline
Is the DA 35cc on the market yet?
Hide Signatures
       Post #: 136
RE: New DLE 35 - 11/3/2012 12:50 PM
Michel
Score: 123
Status: offline
Hi
It,s been on the market for several months now .
Michel
Hide Signatures
       Post #: 137
RE: New DLE 35 - 11/4/2012 5:02 AM
MTK
Score: 203
Status: offline
I've heard some folks have had some trouble with their OS55. Yet others swear by them
I had a little trouble at first with the OS33. Turned out that the rear cover cracked after only 4 runs...it must have been a factory defect. Hobby Services took care of it after some time waiting for the part from Japan. No trouble since then. Some 11 gallons through it which translates to around 60 hours of operation... I generally use a starter for the first run of the day and after that it is easy to hand start.
I have a DLE55 piped and soft mounted as all my set-ups are, and it really has terrific output and field manners. Simple to hand start from the beginning. The current best prop is a 3 blade 20x12 Mejzlik carbon; supremely quiet set-up (piped, soft mounted and 3 blade, well designed prop). I am certain is will turn the 21x12 3 blade  just as well
Regards,
MattK
Hide Signatures
       Post #: 138
RE: New DLE 35 - 11/4/2012 8:04 AM
Ernie Misner
Score: 130
Last Login: 6/12/2013
Status: offline
Hi Matt, what pipes and headers are you using. Very interesting!
Thanks - Ernie
Hide Signatures
(in reply to MTK)
       Post #: 139
RE: New DLE 35 - 11/9/2012 5:31 AM
bcchi
Score: 650
Last Login: 6/13/2013
Status: offline
quote:
ORIGINAL: ahicks
quote:
ORIGINAL: airraptor
Most guys have to have their engines on the rich side because they dont know how to cool these engines correctly so they have to run the on the rich side to help with cooling.
Use the reason you prefer to do so, but it's not going to change my belief a rich engine is far more likely to be running when it lands than a lean one? My understanding is we're talking about the first flight after ground tuning right? Launching a couple hundred rpm. rich of max rpm?? Not the final adjustment that's resulted from many flights, and potentially a few ''tweaks'' of the adjustment screw?
It's better to be running a little rich and flying then running lean and dyeing.
BCCHI
Hide Signatures
(in reply to ahicks)
       Post #: 140
RE: New DLE 35 - 11/9/2012 6:08 AM
rmoose
Score: 100
Status: offline
AMEN ! a lean engine  proubly will damage the engine . rather than a rich might burable but still have something to ajust. also the tube from the carb inside the plane is the nut .had a engine last mo. ajusted ran good on the ground every time it was flow mid. range sputtered installed tube from carb cover and didn't even have to ajust carb screws run's perfect would have never belives it but trust me it makes all the diff. in the world.
Hide Signatures
(in reply to bcchi)
       Post #: 141
RE: New DLE 35 - 11/10/2012 7:51 AM
DL826
Score: 100
Last Login: 11/10/2012
Status: offline
Hello,guys
i am a representative of the DLE manufacturer ,and this is my first time to come here.
So hope i can learn and share something about DLE in here.
If you have any question,please feel free to ask me. I will try my best to help you.
But i donot know that(because i am also a newer for engines, i am also learning about DLE)
Thanks for your attention and support about DLE.
Hide Signatures
(in reply to rmoose)
       Post #: 142
RE: New DLE 35 - 11/10/2012 6:04 PM
rmoose
Score: 100
Status: offline
First of all welcome the engines are great. well made and very powerfull .i cain't speak for everybody in this forrm but i work on alot of the engines most being DLE's the biggest proublem iv seen with these engines out of the box is that the timing is off anywere from 2 * to 7* advanced always.! when the timing is set correctly so spark flashes at 28-30 degrees btdc the engine run smoother idle down lower and vibration decreeses in half they run cooler and more relible. one thing else you should install a vent tube to the carb. on the plate were the needle and seat located so one may run a hose into the airframe make the engines run with no burable in the mid. range or top end. once the carb is ajusted correctly! the engine will run the same in the air as it does on the ground.  i just finished a set of dle 55 for a p-38 lighting and iv got one of them running backwards not hard to do. have to mount pickup to 28* atdc put on a pusher prop and boom it will run backwards. really will make that twin engine project realistic plus the plane will fly better trims wont be so far out. and the torque factor balances out because they counter acting each other. in the event that one engine may quit running. may be  able to save the plane. a little about my self i was a mach. for G.M. for 40 years have a masters with G.M. and ase master certified have built race car engines so working on these weed eaters is no proublem .lol. i would like to see the compression ratio increased i think the engines will make more power than they do now. plus will have more torque and will swing bigger props. havent tryed raising  the comp. ratio yet been thinking about it heat will go up and it will put more stress in the engine. but this is just a throught the guys who race these engines would love that . overall you guys make a damm good engine for the dollar $  if you have any questions please let me know there isn't much that i haven't run across
thanks Rob
Hide Signatures
(in reply to DL826)
       Post #: 143
RE: New DLE 35 - 12/11/2012 6:14 PM
djstar39
Score: 100
Status: offline
Folks, I have a H9 P-51 1.50 that has been running a Saito 220. I'm moving away from glow and purchased a DLE-30 several months ago as a replacement (haven't switched them yet). I'm now questioning this choice in light of the DLE-35. For the DLE-30 to work I have to purchase the wrap around pitts muffler (additional cost). I like plenty of power so it sounds like I should go with the DLE-35 and sell the DLE-30 which is NIB. Not sure it will be a dramatic power difference but seems to be a move in the right direction.
Thoughts?
Thanks!!
Dave
Hide Signatures
       Post #: 144
RE: New DLE 35 - 12/11/2012 10:24 PM
Michel
Score: 123
Status: offline
Hi
There is no question ,................................... do the switch , 1 ) more power , 2 ) more power , 3 ) more power , .
BTW ,..................... it will fit much better
Michel
Hide Signatures
(in reply to djstar39)
       Post #: 145
RE: New DLE 35 - 12/11/2012 11:50 PM
Me410
Score: 100
Status: offline
I have a new DLE 30 going into my next project. The little stock can muffler I know is going to be too loud for my field.
The DLE 35RE would be a better fit for my Platt Me109,  but what about the noise, is the stock muffler  much improved over the DLE 30 .
We have to keep our noise under control, like most clubs.  Is the DLE35RE stock muffler going to cut it???
Tom
Hide Signatures
(in reply to Michel)
       Post #: 146
RE: New DLE 35 - 12/12/2012 12:55 AM
djstar39
Score: 100
Status: offline
Michel,
Thanks for the validation! I will always agree with 'more power'! Not sure how much more power the 35 will have over the 30 but I agree it will fit nicer and not require me to buy a wrap around pitts muffler.
ME410, no idea on the loudness. While it's true that we all have to be aware of being offensive sound wise, mine's a warbird so there's an evil part of me that thinks it should be loud.
Dave
Hide Signatures
(in reply to Me410)
       Post #: 147
RE: New DLE 35 - 12/12/2012 1:15 AM
rcguy59
Score: 129
Status: offline
Go with the 35RA. The price of a wrap-around for the 30 brings it to at least the total price of the 35. As far as noise is concerned, only a canister or full-length pipe will be usefully quieter than ANY "muffler", regardless of what you pay for it. As far as the power difference, I can tell you that the 35 will swing at least an extra inch of diameter and even more additional pitch than the 30. I own both, and both are in high-performance scale airplanes, propped for speed. If you want to bring out the full potential, install a Bowman ring and massage the reed-block. In a narrow cowling such as a Mustang, the 35 is the only way to go. In a radial cowling, either are at home. Narrow AND powerful make the 35RA a slam-dunk for a P-51.
Hide Signatures
       Post #: 148
RE: New DLE 35 - 12/12/2012 4:25 AM
djstar39
Score: 100
Status: offline
Thanks RCGuy! Was leaning heavily that way and you folks pushed me over the edge. Any suggestions for prop size for the Mustang? I do have the single hub prop adapter from ValleyView vs the 4 prop bolts. Bought that for the DLE-30 but I'm told it will work with the 35 as well.
Dave
Hide Signatures
       Post #: 149
RE: New DLE 35 - 12/12/2012 5:13 AM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: djstar39
Dave
It's particularly useful if you plane needs some more nose weight. For these small gassies it just makes no sense at all to have a multi bolt prop set-up. The OS33 and SAP180 have a big advantage theresimple prop installations and nothing separate to buy....
Regards,
MattK
Hide Signatures
       Post #: 150
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.953RCU1
