Worn out motor?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> Worn out motor?
Page: [1]
Login
Worn out motor? - 7/10/2012 10:03 AM
nitrosteve22
Score: 100
Last Login: 5/22/2013
Status: offline
Have about 2 1&2 gallons through the stock .18 and during this 90 degree weather it's hard to run no matter how much I richen it. Maybe 2 tanks with the body on then it's so hot it doesn't like to start. Maybe new piston/sleeve?
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1
RE: Worn out motor? - 7/11/2012 3:31 AM
ehroof
Score: 105
Last Login: 5/16/2013
Status: offline
I always found one good test for compression is to hold the car up by the pullstart, if it stays up or slowly falls (grabs and lets go, grabs and lets go) then the compression is good (do this before running it) if the compression is low then it will usually stop running during the first tank of fuel when it warms up. Sounds like you may have an air leak that is causing it to run lean and hot.
_____________________________
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
(in reply to nitrosteve22)
       Post #: 2
RE: Worn out motor? - 7/11/2012 9:13 AM
nitrosteve22
Score: 100
Status: offline
I have already gone through it and sealed it up. Still has decent compression when cold,runs great for quite a while then eventually overheats....
Hide Signatures
(in reply to ehroof)
       Post #: 3
RE: Worn out motor? - 7/11/2012 1:58 PM
ehroof
Score: 105
Status: offline
The overheating sounds like air leak issue, check the o rings on the needles and the front bearing. A worn engine wont just overheat, it will loose compression when it gets warm from the expansion and not run well unless its rich since the excess fuel helps make up for the gap from being worn, if its getting hot it a fuel/air issue.
Hide Signatures
       Post #: 4
RE: Worn out motor? - 7/11/2012 7:15 PM
nitrosteve22
Score: 100
Status: offline
Yeah the compression isnt the greatest when hot so it might be worn out come to think of it. I've been around nitros for many years now and this sh.18 has always been a bit finicky,got better after sealing but still a problem child. Thinking a new O.S 18cvrx would make a good bday present to myself . So far the only problems I've had with this Caldera are the front knuckles (probley the bigger tires and constant crashing) and the engine.
Hide Signatures
       Post #: 5
RE: Worn out motor? - 7/15/2012 3:58 AM
ehroof
Score: 105
Status: offline
you cant go wrong with the cvrx, its a direct fit, easy to tune and has some nice power, i have it in a few of my rc's and very happy with it, only problem I have seen is the one way bearing seems to go bad in them, i have had to replace 3 out of the 4 engines i have, funny since its an external one and they rarely go bad.
Hide Signatures
       Post #: 6
RE: Worn out motor? - 7/16/2012 5:48 AM
nitrosteve22
Score: 100
Status: offline
Stupid question would this SH .18 make more power if I replaced it with a new piston/sleeve combo but P&P it before restoring? More than the O.S.?
Hide Signatures
       Post #: 7
RE: Worn out motor? - 7/17/2012 3:33 AM
ehroof
Score: 105
Status: offline
The sh18 has good power but the cvrx has more for sure.
Hide Signatures
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.188RCU1
