RE: AMSOIL SABER 100:1 PRE MIX SYNTHETIC 2-CYCLE OIL AND AMSOIL QUICK SHOT FUEL ADDITIVE    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: AMSOIL SABER 100:1 PRE MIX SYNTHETIC 2-CYCLE OIL AND AMSOIL QUICK SHOT FUEL ADDITIVE
Page: <<   < prev  1 2 3 4 [5] 6   next >   >>
Login
RE: AMSOIL SABER 100:1 PRE MIX SYNTHETIC 2-CYCLE OIL AN... - 7/17/2012 5:11 PM
NM2K
Score: 161
Last Login: 5/23/2013
Status: offline
quote:
ORIGINAL: matt43
Okay just have to ask... Has anyone looked at ultralights?? 99% of rotax 2 strokes run amsoil at 100:1 they trust there asses to it! And for those that say well they run lower rpm... The engines at cruise turn 5800.... Just a thought if people trust there lives to it, why not our toys... Also call DA or 3w they say there is nothing wrong with it at all..
It is puzzling why some user groups hate Amsoil while other user groups trust their very lives to it.
I've used Amsoil Sabre in my two-stroke lawn equipment for over ten years now and have not had any kind of a problem that I could attribute to using inferior oil.
Ed Cregger
_____________________________
"Practice makes prefect"
Hide Signatures
(in reply to matt43)
       Post #: 101
RE: AMSOIL SABER 100:1 PRE MIX SYNTHETIC 2-CYCLE OIL AN... - 7/17/2012 5:18 PM
Whistling Death
Score: 150
Status: offline
The more oil you use the cooler the engine will run. Oil carries the heat away.
If you use 100:1 you need to cover two basic rules. 1 Proper tuning 2. Proper cooling.
But of course tuning and cooling rule of thumb goes for any engine.
If I remember correctly Ralph Cunningham runs all his race engines at 32:1.
Blake
CORSAIR Brotherhood Lucky #13
Hide Signatures
(in reply to AJsToyz)
       Post #: 102
RE: AMSOIL SABER 100:1 PRE MIX SYNTHETIC 2-CYCLE OIL AN... - 7/17/2012 9:26 PM
Truckracer
Score: 304
Status: online
quote:
ORIGINAL: Whistling Death
I'm not sure that oil that combusts in a gasser carries away heat quite like the excessive amounts of oil that flow through glo engines. It certainly can't hurt anything though and many tests have proven that more oil = more power. 32:1 for me as I just can't see where using less oil accomplishes anything in our engines.
Hide Signatures
(in reply to Whistling Death)
       Post #: 103
RE: AMSOIL SABER 100:1 PRE MIX SYNTHETIC 2-CYCLE OIL AN... - 7/17/2012 9:41 PM
jloftin
Score: 100
Last Login: 12/29/2012
Status: offline
DOMINATOR IS A VERY GOOD OIL ALSO I HAVE USED IT AS WEll     USING AMSOIL DOMINATOR  YOU SHOULD FOLLOW THE MIX RATIOS
IN THE OWNERS MANUALLY   THE SYNTHETIC MAKE UP OF THAT OIL IS DIFFERENT THAN THE AMSOIL SABER 100:1 OIL ALSO CHECK
INTO USING THE QUICK SHOT IT IS THE BEST GAS ADDITIVE THAT I HAVE EVER USED !!!!
THANK YOU        JAY LOFTIN
Jay Loftin
Authorized Amsoil Distributor
Hide Signatures
(in reply to 68goat)
       Post #: 104
RE: AMSOIL SABER 100:1 PRE MIX SYNTHETIC 2-CYCLE OIL AN... - 7/17/2012 10:32 PM
Gixxy
Score: 105
Status: offline
quote:
ORIGINAL: jloftin
YOU TYPE LARGE LETTER YOU ARE MUST BE RELIYBLE SORCE FOR OIL AND VERY INFORMATIVE TO US ALL.......
THAANK YOU
NICK
Hide Signatures
(in reply to jloftin)
       Post #: 105
RE: AMSOIL SABER 100:1 PRE MIX SYNTHETIC 2-CYCLE OIL AN... - 7/17/2012 11:00 PM
JPMacG
Score: 123
Status: offline
ROFLMAO
Hide Signatures
(in reply to Gixxy)
       Post #: 106
RE: AMSOIL SABER 100:1 PRE MIX SYNTHETIC 2-CYCLE OIL AN... - 7/17/2012 11:07 PM
DougB1
Score: 112
Last Login: 5/21/2013
Status: offline
PLEASE someone shoot this forum and lets go argue about something else.
Hide Signatures
(in reply to JPMacG)
       Post #: 107
RE: AMSOIL SABER 100:1 PRE MIX SYNTHETIC 2-CYCLE OIL AN... - 7/17/2012 11:53 PM
jloftin
Score: 100
Status: offline
SAME HERE ED I USE IT IN EVERY 2-STROKE ENGINE I HAVE AND THE QUICK SHOT ALSO !! MOTORS START WRIGHT UP AND MY NEIGHBORS MOTORS  AS WELL .     THEY PULLED ON THERE CORDS TILL THEY TURNED BLUE IN THE FACE
ALSO HERE IS A TECH TIP ....... PRIME YOUR MOTOR GOOD ON CHOKE,,,,,,,,,,,, NOW PULL CORD.................WHEN ENGINE TRY S  TO TURN OVER
PUT CHOKE LEVER IN.... RUN..... POSITION JUST LIKE R/C GAS ENGINES.............. PULL CORD AGAIN ENGINE SHOULD START WRIGHT UP ?????????? TURN YOUR BLOWER OR WEED EATER UPSIDE DOWN AND LIGHTLY GIVE IT GAS WHEN IT FIRST STARTS IT WILL BURN THE CHOKE
GAS THAT YOU FIRST PRIME IN THE ENGINE AND KEEP YOUR MOTOR FROM STALLING YOU KNOW HOW THEY LIKE TO HESITATE WHEN YOU FIRST START THEM  ????????????? UP SIDE DOWN SHOULD HELP IF YOU HAVE THAT PROBLEM
THANX AGAIN ED       JAY LOFTIN
< Message edited by RCKen -- 7/18/2012 1:09 AM >
Jay Loftin
Hide Signatures
(in reply to NM2K)
       Post #: 108
RE: AMSOIL SABER 100:1 PRE MIX SYNTHETIC 2-CYCLE OIL AN... - 7/18/2012 2:40 AM
avidflyguy
Score: 105
Status: offline
I work on powersports toys like cycles, atvs, snowmobiles, outboards and pwc for a living, plus i also fly ultralights and light sport aircraft with the rotax engines like 447s, 503 and 582 engines. i often hear customers complain that their oil is the cause of burning up pistons or crankshafts, 9 times out of 10, its the idiot who is twisting the throttle on the engine and have absolutely no clue on 2 stroke tuning or running. last year i rebuilt a ski doo mxz 700 for a guy, both new jugs,pistons and crankshaft, the sled came back to me within 2 days with damaged pistons on both cylinders because the idiot didn't know enough to warm the engine up thoroughly before hitting the trail, the pistons had cold seized and stuck the rings, he was complaining about the oil being crap when in fact it was his fault for not warming the engine up. And i have personally witnessed numerous engine teardowns on the ultralights from my flying field, 1 guy had an engine seizure over the wisconsin river and he ended up in the drink, he was running the amsoil at 100/1 when it happened and in this case i believe the lack of oil killed this engine from the damaged i have seen on the pistons he had been running 50/1 ratio pennzoil air cooled oil for a couple of years before he switched over to 100/1 ratio amsoil, that engine was on its 2nd tank of 100/1 fuel when that happened. I rebuilt the engine for him with a new crankshaft and he has over 260 trouble free hours so far running pennzoil at 50/1 another flyer had a 503 powered challenger that he built new, this brand new engine had less than 50 hours on it before engine seized on him, (100/1 amsoil again) plane was damaged beyond repair. I have another guy at the field who ran 50/1 klotz oil with castor through his newly freshened up 503 in his flightstar that he had just bought, 25-30 hours later the engine was getting hard to start and he stated it didn't have the power it used to have when new, upon disassembly, the pistons were carboned up so severely it stuck both rings. he freshened the engine up again with new pistons and is running trouble free with the pennzoil 50/1 mix. I have just over 800 hours of flight time behind rotax 2 strokes in 3 different aircraft ( 2 447s with premixed 50/1 pennzoil and oil injected 582 with pennzoil again) amsoil is probably fine at 50/1 ratio but i sure as hell won't trust my life to 100/1 ratio of any brand of oil, it just isn't enough protection
Hide Signatures
       Post #: 109
RE: AMSOIL SABER 100:1 PRE MIX SYNTHETIC 2-CYCLE OIL AN... - 7/18/2012 5:55 AM
Firepower R/C
Score: 110
Last Login: 5/16/2013
Status: offline
Instead of another sales pitch, why don't you explain exactly how Amsoil 2 stroke will show me a significant, tangible advantage over other oils? A side by side engine shootout would go along way to convincing your peers. Maybe we could get R/C Model Review to do it!
What we want here are hard facts sans the smoke blowing (another pun, whoopee!).
Firepower R/C
Saving un-loved R/C airplanes around the world
Hide Signatures
       Post #: 110
RE: AMSOIL SABER 100:1 PRE MIX SYNTHETIC 2-CYCLE OIL AN... - 7/18/2012 7:07 AM
NM2K
Score: 161
Status: offline
To be completely honest with you, it would be a cold day in Hell before you will see me trusting my posterior to any two-stroke engine, regardless of brand or type of oil.
I'm not the kind of guy that invests thousands of dollars in two-stroke engines of any kind. They are near throw aways when brand new as far as I'm concerned, so I don't expect years and years of service from them, which is why I don't buy the expensive ones. Ring-da-ding-ding-ding.
Ed Cregger
Hide Signatures
(in reply to Firepower R/C)
       Post #: 111
RE: AMSOIL SABER 100:1 PRE MIX SYNTHETIC 2-CYCLE OIL AN... - 7/18/2012 7:14 AM
rangerfredbob
Score: 115
Status: offline
quote:
ORIGINAL: Firepower R/C
And with the caps lock OFF!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
If all your posts weren't a blatant sales pitch (with little or no information, just "Amsoil is the best!") and in all caps, I don't think things would be going this bad for you...
Hide Signatures
       Post #: 112
RE: AMSOIL SABER 100:1 PRE MIX SYNTHETIC 2-CYCLE OIL AN... - 7/18/2012 12:17 PM
Luchnia
Score: 193
Last Login: 5/22/2013
Status: offline
This would be a good test and the scenario must have the same engines and all conditions much match as close as possible. Engine test, unless done in a controlled environment, are difficult to pull off with decent measurable results. I remember back in the day dyno testing some engines and there was a marked difference in testing on rainy days verses dry days with dust blowing all around. Some of those dusty days resulted in some light scored engines when pulled down. So even hard facts might not include all the variables without a proper test bed. I still would like to see results from a solid test.
Also there is a huge difference in engines. High quality two stroke engines have better material in the bores, better bearings, etc. and that alone changes how well an engine will do on various oils. Throw some cheap oil in a cheap crapo two stroke and it should show you quickly just how bad it is. This is one reason it is hard to trust anything anybody states on these forums unless you have first hand knowledge of what they are using. There are certainly folks that have used Amsoil successfully in two strokes for years with excellent results.
Let's see what JLoft COMES UP WITH - SALES PITCH ARE HARD FACTS?
Hide Signatures
       Post #: 113
RE: AMSOIL SABER 100:1 PRE MIX SYNTHETIC 2-CYCLE OIL AN... - 7/18/2012 1:33 PM
Brian Smith
Score: 120
Last Login: 4/14/2013
Status: offline
Those look like Pennzoil ducks. Do they belong on an AMSOIL commercial??
quote:
ORIGINAL: AJsToyz
Quack!
Brian P. Smith Bismith2@hotmail.com
AMA 1044 IMAA 21141 W4BPS <><
Hide Signatures
       Post #: 114
RE: AMSOIL SABER 100:1 PRE MIX SYNTHETIC 2-CYCLE OIL AN... - 7/18/2012 2:47 PM
Whistling Death
Score: 150
Status: offline
jloftin, I wouldn't buy anything from you. You are obnoxious, you can't spell and you are skirting the forum rules to sell your product.
I vote for admins to lock this thread.
Blake
Hide Signatures
(in reply to Brian Smith)
       Post #: 115
RE: AMSOIL SABER 100:1 PRE MIX SYNTHETIC 2-CYCLE OIL AN... - 7/18/2012 2:55 PM
bigstick60
Score: 110
Last Login: 5/13/2013
Status: offline
these oil war forums are pure bs, it is always my brand is best, your brand is junk.just use what you want and be done with it, if it works for you fine. it is a 50/50 argument, always was and always will be. if you are new to gas, call the manufacture and ask what he suggests. 32-1 and you won't go wrong, regardless of what brand r/c engine you are using. whenever a motor is fried there are to many unknown variables we never hear about, and it is always blamed on the oil.
Hide Signatures
       Post #: 116
RE: AMSOIL SABER 100:1 PRE MIX SYNTHETIC 2-CYCLE OIL AN... - 7/18/2012 3:08 PM
bigstick60
Score: 110
Status: offline
quote:
ORIGINAL: jloftin
and another thing , whever a new product/mfg. appears and claims it is the best thing since sliced bread and will work wonders (BEWARE) imho there are a few good additives around but most are just snake oils or feel good remedies
Hide Signatures
       Post #: 117
RE: AMSOIL SABER 100:1 PRE MIX SYNTHETIC 2-CYCLE OIL AN... - 7/18/2012 5:02 PM
Luchnia
Score: 193
Status: offline
Life would be much too easy if you did not have snake oil salesmen
Hide Signatures
(in reply to bigstick60)
       Post #: 118
RE: AMSOIL SABER 100:1 PRE MIX SYNTHETIC 2-CYCLE OIL AN... - 7/18/2012 5:04 PM
eddieC
Score: 249
Status: offline
Absolutely untrue, amsoilj/jloftin. Everyone I know with a 2-stroke ultralight uses :  Pennzoil for Aircooled, Stihl HP, anything other than!
What do engine shops call Amsoil users?
Customers !
I might not be very good, but I am fun to watch!
Hide Signatures
       Post #: 119
RE: AMSOIL SABER 100:1 PRE MIX SYNTHETIC 2-CYCLE OIL AN... - 7/18/2012 5:30 PM
Taz_Hobbies
Score: 201
Last Login: 9/21/2012
Status: offline
Who in their right mind would run an air cooled 2-smoke at 100:1 ?
That's just silly no matter what the manufacturer claims. Silly...
Taz Hobbies
Hide Signatures
       Post #: 120
RE: AMSOIL SABER 100:1 PRE MIX SYNTHETIC 2-CYCLE OIL AN... - 7/18/2012 5:49 PM
AJsToyz
Score: 304
Status: offline
I think the ducks are rogue ducks and they just do what they want!
Amsoil guy did say one several accounts gas is the problem here. I think gas is way over rated, something we could do with out. If you just sit back and look at your plane it will never crash or fail. If you did this you could sit back with any kind of beverage you want and never have a problem. Heck, you wouldn't even need to waste the time or money for good batteries, why even use an engine? The plane would just be pretty as a picture if you left that dirty old gas out of her. Think of the many hours of conversation of what could have been? All the enjoyment of how nice this plane is and how many years it's been around with not even one crash? No hazards or obstacles, no brown out issues, or receivers heating up, no wondering about what caused what? A thing of beauty I tell you!
That's it, don't need no stinking additives or 100:1, just don't do it! Gas is the enemy my friends, stay clear!!
If this don't work for you I suggest Coleman fuel with lawn boy @ 32:1
Ok, I think that fits in with this thread just fine.
www.Deathbychina.com
Hide Signatures
       Post #: 121
RE: AMSOIL SABER 100:1 PRE MIX SYNTHETIC 2-CYCLE OIL AN... - 7/18/2012 8:06 PM
Gixxy
Score: 105
Status: offline
So how about those electric planes ????
Hide Signatures
       Post #: 122
RE: AMSOIL SABER 100:1 PRE MIX SYNTHETIC 2-CYCLE OIL AN... - 7/18/2012 8:22 PM
DougB1
Score: 112
Status: offline
quote:
ORIGINAL: Gixxy
You mean the silent slicers We have had 3 guys in our club get cut up VERY badly with electrics. You don't usually have that much trouble with a glow or gas, at least you can see and HEAR them running.
DougB1
Hide Signatures
(in reply to Gixxy)
       Post #: 123
RE: AMSOIL SABER 100:1 PRE MIX SYNTHETIC 2-CYCLE OIL AN... - 7/18/2012 8:34 PM
Luchnia
Score: 193
Status: offline
quote:
ORIGINAL: Gixxy
Just make sure you run AMSOIL QUACK SHOT @ $743.00 a gallon in your electric planes and your are good-to-go!
Hide Signatures
(in reply to Gixxy)
       Post #: 124
RE: AMSOIL SABER 100:1 PRE MIX SYNTHETIC 2-CYCLE OIL AN... - 7/18/2012 9:11 PM
Firepower R/C
Score: 110
Status: offline
New and improved "Lighning Bolt" battery dip! Now you only have to charge your batteries once a year.
Firepower R/C
Hide Signatures
(in reply to Luchnia)
       Post #: 125
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: AMSOIL SABER 100:1 PRE MIX SYNTHETIC 2-CYCLE OIL AND AMSOIL QUICK SHOT FUEL ADDITIVE
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.641RCU1
