My Engine Conversion Plane (Mitsubishi 33cc)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> My Engine Conversion Plane (Mitsubishi 33cc)
Page: [1]
Login
My Engine Conversion Plane (Mitsubishi 33cc) - 7/10/2012 7:27 PM
oddy
Score: 100
Last Login: 4/12/2013
Status: offline
Hello Everyone,
Just to share some pics of my Weed Trimmer engine conversion plane.
Its kind of a self designed Long John with the wings of an U-CAN-DO 3d 60.
The engine is a converted Mitsubishi TL 33cc with nothing more than baffles taken out of the muffler, its original 10.5 mm Mikuni carb and a prop hub.
I have fly it with different props with the following results
- Master Airscrew 16x8 wood @ 7,400 RPM
- APC 17x6 @ 8,000 RPM
Even though it seems to have a better performance with a 17 inch prop it flies better with the 16 one, maybe I´ll try a 15x10....any comments will be apperciated.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
If I say that the Burra is Prieta is because I have the pelos in my hand.
Hide Signatures
       Post #: 1
RE: My Engine Conversion Plane (Mitsubishi 33cc) - 7/11/2012 12:30 AM  1 votes
av8tor1977
Score: 665
Last Login: 5/25/2013
Status: offline
Your performance numbers are a little low. The carb size is close to being ok, so I wouldn't worry about that for the moment. But you say it is 10.5mm. Where are you measuring it? A carb size is determined by it's smallest diameter in the venturi. What your engine needs is an 11.1 mm venturi carb. The Walbro carbs also have a number cast into them near the choke. The number you want is "28".
The next thing you need to do is add either one large or two somewhat smaller exit tubes to the muffler. If you use two they should be around 11mm i.d. One large tube would also work, and it should be around 19mm i.d.
These changes will help a lot!
By the way, your plane looks very nice. Good job!
Good luck,
AV8TOR
If it is not SCARY, it is NO WHERE NEAR powerful enough!!
Hide Signatures
(in reply to oddy)
       Post #: 2
RE: My Engine Conversion Plane (Mitsubishi 33cc) - 7/11/2012 1:44 AM
w8ye
Score: 318
Status: offline
You should have 7400 rpm with a 18 X 8 as a reference point?
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to av8tor1977)
       Post #: 3
RE: My Engine Conversion Plane (Mitsubishi 33cc) - 7/11/2012 3:19 PM
oddy
Score: 100
Status: offline
Thanks both very much for your comments.
Actually I do have the 2 tubes out of the muffler and and extra hole in it to free the exhaust.,,I already bought a 13.5 mm Walbro Carb but Im still trying to figure out how to mount the throttle.
I forgot to mention that I fly in México city at an altitude of 2,240 metres (7,350 ft)
Considering this altitude numbers, do you think I would need to use a smaller prop to get the optimal power out of this engine? It flies well with the 17x6 and the 16x8 but no doubt it could greatly benefit from a better vertical performace
In my experience with glow engines, here in México City we cannot use similar prop sizes like the ones used by the guys living closer to the sea level, we do really experience a shortage in power given the altitude which we try to complensate with smaller props to gain some RPM´s.
Once again thanks a lot and please any advice will be very much appreciated.
Hide Signatures
(in reply to w8ye)
       Post #: 4
RE: My Engine Conversion Plane (Mitsubishi 33cc) - 7/11/2012 8:15 PM
av8tor1977
Score: 665
Status: offline
Oh yes, the altitude makes a huge difference. You lose about 25% power at your altitude, and possibly more if it is hot out. See how the carb does, and use whatever prop that flies the plane how you like it. If there is any way to increase the compression ratio, (lower the cylinder), that helps, especially at higher altitudes.
AV8TOR
Hide Signatures
(in reply to oddy)
       Post #: 5
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> My Engine Conversion Plane (Mitsubishi 33cc)
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.203RCU1
