IS THIS ENGINE TOAST?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> IS THIS ENGINE TOAST?
Page: [1] 2   next >   >>
Login
IS THIS ENGINE TOAST? - 7/13/2012 9:16 PM
TCraft Lover
Score: 100
Last Login: 5/19/2013
Status: offline
Looks like I tapped a bit too hard.  Is this engine toast?
Click to see fullsize image.
Click for fullsize
_____________________________
Ah nuts! I''m gonna need some glue.
Hide Signatures
       Post #: 1
RE: IS THIS ENGINE TOAST? - 7/13/2012 9:27 PM
SeamusG
Score: 199
Last Login: 4/10/2013
Status: offline
The crank case is toast. It can be replaced - but it's the most expense part of the engine.
Hide Signatures
(in reply to TCraft Lover)
       Post #: 2
RE: IS THIS ENGINE TOAST? - 7/13/2012 9:45 PM
earlwb
Score: 584
Last Login: 5/24/2013
Status: offline
Bummer., But yeah the crankcase has gone bad in that case. It depends on the brand and engine, but sometimes the crankcase isn't too badly priced and in other cases it can be quite expensive.  So what brand, model and displacement is it? Maybe someone on the forum has one.
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
(in reply to SeamusG)
       Post #: 3
RE: IS THIS ENGINE TOAST? - 7/13/2012 10:21 PM
TCraft Lover
Score: 100
Status: offline
Hi Earl,
  It's my old OS 70 Surpass. My first 4 stroke. Feels like I murdered my best buddy. I bought this motor in the mid 90's. Know of where I can find a C'case for her?
Dave
Hide Signatures
(in reply to earlwb)
       Post #: 4
RE: IS THIS ENGINE TOAST? - 7/13/2012 10:28 PM
dogshome
Score: 110
Last Login: 5/9/2013
Status: offline
Hold on, the bearing seat is good. The valvegear and cam doesn't load that bit and there is not a gas seal there on a 4 stroke. So what (apart from looking nasty) is the problem? Put her back together and go fly!
肉(ròu)包(bāo)子(zi)打(dǎ)狗(gǒu) (meat+bun(2nd and 3rd)+hit+dog)
Literally: To hit a dog with a meat-bun :-)
Hide Signatures
       Post #: 5
RE: IS THIS ENGINE TOAST? - 7/13/2012 10:31 PM
TCraft Lover
Score: 100
Status: offline
That's what I was thinking and why I posted the picture. I just couldn't see what it might hurt but it just looks sooooo nasty!
Hide Signatures
(in reply to dogshome)
       Post #: 6
RE: IS THIS ENGINE TOAST? - 7/13/2012 10:46 PM
dogshome
Score: 110
Status: offline
It is cosmetic. You could dremel it smooth if you feel the need, but it really isn't going to affect performance.
Hide Signatures
       Post #: 7
RE: IS THIS ENGINE TOAST? - 7/13/2012 11:25 PM
SeamusG
Score: 199
Status: offline
As long at the main bearing seats fully and tight.
Hide Signatures
       Post #: 8
RE: IS THIS ENGINE TOAST? - 7/13/2012 11:37 PM
pe reivers
Score: 646
Status: offline
Just close up the hole with some JBweld and metal shavings.
Pe, (www.mvvs.nl), MVVS, MOKImotor, RCexl, MTW, Xoar, Mejzlik.
Blessing in ignorance? There is sanctuary in analysis.
Hide Signatures
       Post #: 9
RE: IS THIS ENGINE TOAST? - 7/13/2012 11:41 PM
Campgems
Score: 138
Last Login: 5/22/2013
Status: offline
I was rebuilding an O.S 1.20 for a friend and as I was cleaning up after the boil out, it looked just like your photo.  I felt awful and I searched all over the shop to for the piece I broke loose, but couldn't find it.  Time to fess up, so I did.  OH, I forgot to tell you about that, it was like that when I got the engine, he said.   I put it back together and tested it out and it ran just fine.  I think he is still flying that engine.
Make sure there are no flakes to pop off, a dental probe poked around the break willl tell if everything is OK. Put it back together and enjoy it.
Don
Hide Signatures
       Post #: 10
RE: IS THIS ENGINE TOAST? - 7/13/2012 11:45 PM
TCraft Lover
Score: 100
Status: offline
Good advice. Thanks Campgems. I'm freezing the new bearings now!
Hide Signatures
(in reply to Campgems)
       Post #: 11
RE: IS THIS ENGINE TOAST? - 7/13/2012 11:55 PM
Campgems
Score: 138
Status: offline
You are welcome.
I just noticed something in the photo, the location of the crank vent.  I guess it is the first one I've seen that goes through the mounting lug.  Was this an add on or the stock location?
Make sure the lifters move smoothly, there should be enough of the two bores left that they wont be a problem, but check just in case.
Don
Hide Signatures
       Post #: 12
RE: IS THIS ENGINE TOAST? - 7/14/2012 12:10 AM
TCraft Lover
Score: 100
Status: offline
It was an add on in a failed effort to power a fuel pump. I'll check the cam/lifter function as soon as I get the thing back together. Thanks again.
Hide Signatures
       Post #: 13
RE: IS THIS ENGINE TOAST? - 7/14/2012 12:18 AM
Daniel Spurlock
Score: 100
Status: online
I am with Dogshome it should be fine to run.
Hide Signatures
       Post #: 14
RE: IS THIS ENGINE TOAST? - 7/14/2012 12:44 AM
TCraft Lover
Score: 100
Status: offline
Thanks D.S.,
   I hope so. I just got the front bearing put in. A few more minutes the main will be in also.
Hide Signatures
(in reply to Daniel Spurlock)
       Post #: 15
RE: IS THIS ENGINE TOAST? - 7/14/2012 1:30 AM
SeamusG
Score: 199
Status: offline
How much run-in time on the bench do you guys suggest before trusting it on a beloved plane?
Hide Signatures
       Post #: 16
RE: IS THIS ENGINE TOAST? - 7/14/2012 2:26 AM
blw
Score: 655
Status: offline
You biggest concerns are probably bits of aluminum from the rough edges, or excessive oil leaks, or any hairline cracks. I would run it if it were mine. Good luck.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
"It doesn''t take but one Auburn man to be a majority" -
Coach Pat Dye
Hide Signatures
       Post #: 17
RE: IS THIS ENGINE TOAST? - 7/14/2012 3:17 AM
TCraft Lover
Score: 100
Status: offline
I think that some time on my test stand before going back into my Cub is a good thought
Hide Signatures
(in reply to blw)
       Post #: 18
RE: IS THIS ENGINE TOAST? - 7/14/2012 6:19 AM
Mr Coffee
Score: 100
Last Login: 8/11/2012
Status: offline
Good Evening,
I personally would not use the engine. I did a quick search on ebay. Here is the link to the search results.
http://www.ebay.com/sch/i.html?_nkw=os++70+crankcase&_sacat=0&_odkw=os+fs+70+crankcase&_osacat=0
- Allan
Hide Signatures
       Post #: 19
RE: IS THIS ENGINE TOAST? - 7/14/2012 3:13 PM
earlwb
Score: 584
Status: offline
I didn't know it was a 4 stroke engine, it sort of looked like a 2 stroke there in the pic. Yeah since the bearing area is OK, you could use it as is, as it is a low stress area. You could also JB-Weld the broken piece back on and dremel off any excess epoxy as needed too.
AMA # 928076
Hide Signatures
(in reply to Mr Coffee)
       Post #: 20
RE: IS THIS ENGINE TOAST? - 7/14/2012 4:25 PM
TCraft Lover
Score: 100
Status: offline
Just took her off the test stand. Seemed to run just like before. I ran it for 40 minutes, 11 oz. of fuel, varying rpm. I think she's going back in the
Cub.
   Gentlemen thank you for all of your assistance / suggestions. At least for now the old girl seems just the same as before, maybe even better. (New bearings you know)
Hide Signatures
       Post #: 21
RE: IS THIS ENGINE TOAST? - 7/14/2012 4:40 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: dogshome
Why bother? Nobody is going to see it anyway once the engine is assembled.
Club Saito #785 - FA91S CDI, FA150 CDI, FA180 CDI, FA180HC CDI/BBC, FA200TI, FA300TTDP CDI
Hide Signatures
       Post #: 22
RE: IS THIS ENGINE TOAST? - 7/14/2012 10:09 PM
do335a
Score: 105
Last Login: 5/18/2013
Status: offline
quote:
ORIGINAL: SrTelemaster150
quote:
ORIGINAL: dogshome
It's got nothing to with the cosmetics of a concealed appearance. You get stress points at sharp edges and could easily lose another piece while running, with catastrophic consequences.
Hide Signatures
(in reply to SrTelemaster150)
       Post #: 23
RE: IS THIS ENGINE TOAST? - 7/14/2012 10:22 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: do335a
quote:
ORIGINAL: dogshome
Good point!
Hide Signatures
(in reply to do335a)
       Post #: 24
RE: IS THIS ENGINE TOAST? - 7/14/2012 11:28 PM
TCraft Lover
Score: 100
Status: offline
[/quote]
Good Point.
I wish you had made it before I re-assembled and test ran the engine.
Hide Signatures
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> IS THIS ENGINE TOAST?
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.625RCU1
