What causes gear doors and thin parts to warp weeks after they are dry?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Jet Central Rhino - RTF
Seller:  thunderbolt-RCU
Details:   $2,700.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> What causes gear doors and thin parts to warp weeks after they are dry?
Page: [1] 2   next >   >>
Login
What causes gear doors and thin parts to warp weeks aft... - 7/14/2012 10:24 PM
FenderBean
Score: 119
Last Login: 5/24/2013
Status: offline
Anyone? seems like my gear doors never fit good after the fact and my once flat spoilers are now warped?
_____________________________
Kingtech 170F
Fly Eagle 1/6 F-16 1/7 F-15E 1/7 F-14
Hide Signatures
       Post #: 1
RE: What causes gear doors and thin parts to warp weeks... - 7/14/2012 10:46 PM
AmishWarlord
Score: 121
Last Login: 5/23/2013
Status: offline
Wild guess with no info to go on.
You paint the fiberglass gear doors with a paint that softens the gel coat on the part then when it rehardens with the paint it warps.
Painting a motorcycle helmet voids the warranty because some paint affects the shell of the helmet.
Use a plastic safe primer for your base coat.
Oh and if you come back with this comment here is your answer,
"But my doors are made of wood"
You didn't say anything about wooden doors. Wood is lively stuff!
Hide Signatures
(in reply to FenderBean)
       Post #: 2
RE: What causes gear doors and thin parts to warp weeks... - 7/14/2012 10:49 PM
SPLIT S
Score: 109
Last Login: 5/11/2013
Status: offline
Need some more info there FB. Weeks after they are dry? What does that mean?
Dan
Hi Dad, Doing anything? Want to go to the field?
Hide Signatures
(in reply to AmishWarlord)
       Post #: 3
RE: What causes gear doors and thin parts to warp weeks... - 7/14/2012 11:57 PM
FenderBean
Score: 119
Status: offline
Well I am talking after its painted and on the jet, I have noticed on my 3 jets so far that this ha happened. My F-14 is just sitting up in my hobby room and the spoilers have warped some, they were fine when I received the jet weeks ago. My F-16 did the same thing on the gear doors, they were fine when it arrived but weeks later they changed.
quote:
ORIGINAL: SPLIT S
Dan
Kingtech 170F
Hide Signatures
(in reply to SPLIT S)
       Post #: 4
RE: What causes gear doors and thin parts to warp weeks... - 7/15/2012 12:07 AM
AmishWarlord
Score: 121
Status: offline
What temperature is this "Hobby Room" during the day in the summer?
You said "Up" so I thinking an converted but un-cooled attic space that's 120° in the summer rather than an un-used cooled upstairs bedroom.
Hide Signatures
       Post #: 5
RE: What causes gear doors and thin parts to warp weeks... - 7/15/2012 12:20 AM
David Searles
Score: 115
Status: online
Fender,
You probably don't want to hear this, but here it is: The problem is with the quality of the epoxy used at FEJ as well as the fact that they tend to pull these parts from the mold too soon, before they are completely cured. I have owned six FEJ aircraft and every single one has shown this defect. Also the problem tends to only get worse with time. Eventually you will begin to see warps and bubbles in the control surfaces and perhaps even in the fuse body as well.
David S
Hide Signatures
       Post #: 6
RE: What causes gear doors and thin parts to warp weeks... - 7/15/2012 1:30 AM
FenderBean
Score: 119
Status: offline
The hobby room is the bonus room which is cooled, so not a temp thing. The only parts I have seen are the thin non honeycomb parts do this
My surfaces have been fine.
Kingtech 170F
Hide Signatures
(in reply to David Searles)
       Post #: 7
RE: What causes gear doors and thin parts to warp weeks... - 7/15/2012 3:09 AM
invertmast
Score: 193
Status: online
Its a resin thing, some dont fully cure for months unless they go through a post cure cycle.
Thomas W.
Euro-sport Evo, Scratch built 1/7 F-14D Tomcat, 26.5% Gee Bee R2
Hide Signatures
       Post #: 8
RE: What causes gear doors and thin parts to warp weeks... - 7/15/2012 3:22 AM
FenderBean
Score: 119
Status: offline
Any way to fix this now? maybe close everything up and put some weight on it
quote:
ORIGINAL: invertmast
Kingtech 170F
Hide Signatures
(in reply to invertmast)
       Post #: 9
RE: What causes gear doors and thin parts to warp weeks... - 7/15/2012 5:25 AM
rpm303
Score: 100
Status: offline
I had this issue with my FEJ F-16. My gear doors were warped. I used a monocoat heat gun to heat up the doors and used blue tape to tape them down to correct the warp.
Worked very well for me. I always keep the doors taped down when hangered and they havent warped again.
Regards
Bob
Hide Signatures
       Post #: 10
RE: What causes gear doors and thin parts to warp weeks... - 7/15/2012 10:09 AM
Pondus
Score: 100
Status: offline
Close everything up and post cure the plane at 60-70 degrees C over night
Problem is just as Invertmast says, on slower curing epoxy resins it's often recommended to do a post cure, usually something like 8-12 hours at a controlled elevated temp. to fully cure the resin. Costly and time consuming so no wonder this is not done by most model airplane manufacturers, downside is just as you have found out that the parts can warp, especially if subjected to high temps.
Hide Signatures
       Post #: 11
RE: What causes gear doors and thin parts to warp weeks... - 7/15/2012 4:27 PM
FenderBean
Score: 119
Status: offline
Im talking weeks/months later this happen, everything is dry by the time it shows up.
quote:
ORIGINAL: Pondus
Kingtech 170F
Hide Signatures
(in reply to Pondus)
       Post #: 12
RE: What causes gear doors and thin parts to warp weeks... - 7/15/2012 5:44 PM
essyou35
Score: 100
Status: offline
Fender just curious, are you talking about your FEJ f-16? My 1/8 scale has the same issue. The gear dorrs warp. I hit then with heat and then they are good, but after a few days they warp back.
Hide Signatures
       Post #: 13
RE: What causes gear doors and thin parts to warp weeks... - 7/15/2012 6:23 PM
DavidR
Score: 110
Status: offline
Just the nature of epoxy resin. It continues to shrink/cure. I still build my models, paint black, and let cure in the sun, then, putty/heat up and reposition hatches etc... Before painting. Don't know how I'd approach an ARF since I don't "build" many of them.
Hide Signatures
(in reply to essyou35)
       Post #: 14
RE: What causes gear doors and thin parts to warp weeks... - 7/15/2012 6:59 PM
FenderBean
Score: 119
Status: offline
Yeah the F-16 did it a little, but my f-14 spoilers are the worse so far. The entire corner has a 1/8in plus gap. not a huge deal since both sides have warped the same, but I like things to be perfecto I figured this would be the norm with material like this that has no wood or carbon to help keep its shape.
quote:
ORIGINAL: essyou35
Kingtech 170F
Hide Signatures
       Post #: 15
RE: What causes gear doors and thin parts to warp weeks... - 7/15/2012 8:15 PM
RCNCMAN
Score: 100
Last Login: 5/22/2013
Status: offline
I cannot tell if wood is involved here but if it is the construction should be balanced, same on front as on back. Use a 3, 5 or 7 ply construction just like quality plywood and the form whether flat or shaped should stay as you need it. This can be done with other materials or combinations of materials as well. Just balance it. If 3 ply, the front and back grain direction can be the same with the middle piece rotated 90 degrees.
Hide Signatures
       Post #: 16
RE: What causes gear doors and thin parts to warp weeks... - 7/15/2012 9:55 PM
FenderBean
Score: 119
Status: offline
The doors I am referring to have no wood in them.
quote:
ORIGINAL: RCNCMAN
Kingtech 170F
Hide Signatures
(in reply to RCNCMAN)
       Post #: 17
RE: What causes gear doors and thin parts to warp weeks... - 7/15/2012 10:05 PM
invertmast
Score: 193
Status: online
Fender,
Typically the thinner the parts, the worse the warp becomes without the use of post-curing the parts. Epoxy resin's can continue to cure for months after they are mixed and appear to be cured (IE dry to the touch).
The only recommendation i can tell you, is to put the parts on a flat surface (glass table top) weight then down, then elevator the temperature and leave them in this state for a couple hours (its hard to say exactly how hot and how long since we don't know what resin is used), but 120-130*f at 8 to 12 hours should suffice. only down side, is since they are already painted, you could cause the paint to bubble on the parts. But this is really your only chance in getting them back flat, except for making a secondary structure using G-10 to correct the warp.
Thomas W.
Hide Signatures
       Post #: 18
RE: What causes gear doors and thin parts to warp weeks... - 7/15/2012 10:49 PM
FenderBean
Score: 119
Status: offline
Thanks, well I will probably just let it go since there is no easy way to remove them. I will just keep them closed add a little weight to the slat to keep it flat maybe throw a heat gun at it to warm it up just a bit, not enough to damage anything. Thanks
Fender,
Kingtech 170F
Hide Signatures
       Post #: 19
RE: What causes gear doors and thin parts to warp weeks... - 7/15/2012 10:58 PM
rcand
Score: 105
Status: offline
quote:
ORIGINAL: David Searles
Fender,
David S
I tend to believe what you summized is true. I have had dozens of jets from BVM, Airworld, SM, Extreme and never had this problem.
Hide Signatures
       Post #: 20
RE: What causes gear doors and thin parts to warp weeks... - 7/15/2012 11:56 PM
CraigG
Score: 105
Status: online
quote:
ORIGINAL: FenderBean
If there's room, you could glue some small wood "ribs" to the back side of the doors. Just tape the doors shut while the glue dries.
That's what I did to stiffen this door I cut out of the fuselage.
Craig
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 21
RE: What causes gear doors and thin parts to warp weeks... - 7/16/2012 1:38 AM
FenderBean
Score: 119
Status: offline
I thought about the as well, thanks
Kingtech 170F
Hide Signatures
(in reply to CraigG)
       Post #: 22
RE: What causes gear doors and thin parts to warp weeks... - 7/16/2012 3:37 AM
flycatch
Score: 118
Status: offline
It is called lack of moisture. You most seal the surface of the wood prior to covering or painting.
Hide Signatures
       Post #: 23
RE: What causes gear doors and thin parts to warp weeks... - 7/16/2012 4:15 AM
David Searles
Score: 115
Status: online
quote:
ORIGINAL: flycatch
Read the description. The parts spoken off do not contain any wood. They are cloth and epoxy layups.
David S
Hide Signatures
(in reply to flycatch)
       Post #: 24
RE: What causes gear doors and thin parts to warp weeks... - 7/16/2012 4:32 AM
SCALECRAFT
Score: 119
Status: offline
As noted before.
This issue is common with most inferior epoxy and polyester resins. I have models (old) made out of West System resin and none of the surfaces warp or degrade. I have a few Chinese composite fuses, most of which go soft in the sun (gummy bear soft), hatches and covers shink and warp. Not unheard of with the resins used out there.
Copy the part with epoxy. Or...
Tape down surface and gently use a heat gun. Practice on scrap first.
Steve
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.953RCU1
