BVM Air Fill Valve- How do u get air in them?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
MBA Tornado V3
Seller:  Modellbau USA
Details:   $380.00   |  5/11/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> BVM Air Fill Valve- How do u get air in them?
Page: [1]
Login
BVM Air Fill Valve- How do u get air in them? - 7/15/2012 5:09 PM
carbunkle
Score: 100
Last Login: 5/19/2013
Status: offline
I never had any of these on previous jets. I thought I'd splurge a little and get some fancy high buck valves. So what's the trick to get air in them. I've tried everything in my shop.
http://shopbvmjets.com/zencart/index.php?main_page=product_info&cPath=10&products_id=45&zenid=43942b407mf5o51531obu0cd54
Hide Signatures
       Post #: 1
RE: BVM Air Fill Valve- How do u get air in them? - 7/15/2012 5:13 PM
siclick33
Score: 125
Last Login: 5/20/2013
Status: offline
You can use this:
http://shopbvmjets.com/zencart/index.php?main_page=product_info&cPath=10&products_id=261&zenid=43942b407mf5o51531obu0cd54
or a 'normal' car tyre pump fitting should work, or you can get some airline and push it in the hole in the top (ignoring the threaded bit).
_____________________________
It was all going really well, then I suddenly ran out of talent!
Hide Signatures
(in reply to carbunkle)
       Post #: 2
RE: BVM Air Fill Valve- How do u get air in them? - 7/15/2012 5:21 PM
FenderBean
Score: 119
Last Login: 5/21/2013
Status: offline
Bvm does sale the screw on attachment but I just a piece of air line and insert it into the hole. It works best that way, specially if u have more than on fill valve.
Kingtech 170F
Fly Eagle 1/6 F-16 1/7 F-15E 1/7 F-14
Hide Signatures
(in reply to siclick33)
       Post #: 3
RE: BVM Air Fill Valve- How do u get air in them? - 7/15/2012 5:54 PM
Harley Condra
Score: 105
Status: offline
quote:
ORIGINAL: FenderBean
We usually just SELL them.....LOL.
Fender is pretty close....inserting it is easier of you cut a bevel on the end of the pump airline.
Shown in the photos are two methods....one involving the screw on Air Fill Chuck BVM #2192, and an alternate with the beveled air line.
Also shown is a football inflation needle screwed into the Air Fill Chuck. Cut the end off the needle and deburr it before inserting it into the air line.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Harley Condra -- 7/16/2012 12:35 PM >
Harley Condra
BVM REP, Skymaster REP, JetCat REP
Hide Signatures
(in reply to FenderBean)
       Post #: 4
RE: BVM Air Fill Valve- How do u get air in them? - 7/15/2012 6:13 PM
rolsen12
Score: 100
Last Login: 5/9/2013
Status: offline
I use a 4mm check valve for retract and brake filling.
Hide Signatures
       Post #: 5
RE: BVM Air Fill Valve- How do u get air in them? - 7/15/2012 6:33 PM
BaldEagel
Score: 118
Status: online
The BVM valve comes with some white tube that's the correct size to insert into the valve for filling, well it does in the UK.
Mike
No matter what anyone says 100% is the maximum you can get.
Hide Signatures
(in reply to rolsen12)
       Post #: 6
RE: BVM Air Fill Valve- How do u get air in them? - 7/15/2012 6:52 PM
carbunkle
Score: 100
Status: offline
OPPS! Thanks anyway guys, Stupid me!, I finally figured out that I had a fitting downstream in the system leaking. Fixed the leak and everything works fine now with my trusty old mini 12v portable compressor from wallmart and the stock nozzle.
Hide Signatures
(in reply to BaldEagel)
       Post #: 7
RE: BVM Air Fill Valve- How do u get air in them? - 7/15/2012 6:56 PM
FenderBean
Score: 119
Status: offline
you are correct sir same in states
quote:
ORIGINAL: BaldEagel
Mike
Kingtech 170F
Hide Signatures
       Post #: 8
RE: BVM Air Fill Valve- How do u get air in them? - 7/15/2012 9:34 PM
gooseF22
Score: 103
Last Login: 4/30/2013
Status: offline
tapered air line works the best.. just cut it to a taper like show in Harley's post, and taper it a tiny bit w sandpaper.. no need for a bit....
Goose
Wren Turbines USA, Fromeco
Hide Signatures
(in reply to Harley Condra)
       Post #: 9
RE: BVM Air Fill Valve- How do u get air in them? - 7/15/2012 10:48 PM
CraigG
Score: 105
Status: online
quote:
ORIGINAL: gooseF22
+1 Quick, easy, simple.
Hide Signatures
(in reply to gooseF22)
       Post #: 10
RE: BVM Air Fill Valve- How do u get air in them? - 7/15/2012 11:02 PM
rcand
Score: 105
Status: offline
quote:
ORIGINAL: carbunkle
I use many of these and I attach airline tubing to the air pump, then I push the free end of the airline tubing into the fill valve. Sometimes a slight bevel cut allows it to fit inside the valve easily. I don't mess with fancy connectors anymore.
Hide Signatures
       Post #: 11
RE: BVM Air Fill Valve- How do u get air in them? - 7/16/2012 12:06 AM
highhorse
Score: 116
Status: online
For those wanting to use a chuck, I like this one from BVM because of the swivel feature. Dreamworks sell it too
http://shopbvmjets.com/zencart/index.php?main_page=product_info&cPath=10&products_id=261&zenid=5mdfhrkb8uj2jmvfb4jribu640
RCU Rocks, I''d hate to be without it !!
Hide Signatures
(in reply to rcand)
       Post #: 12
RE: BVM Air Fill Valve- How do u get air in them? - 7/16/2012 5:11 AM
S HARRIS
Score: 100
Status: offline
Here's my idea that many are using. Football inflating needle cut off to 3/4 inch. Then slide 1 inch piece of air line on it. Just push in and seals at end of needle. Alittle thin CA will keep tubing from coming off after many uses. I'll try to get a pic out soon. Scott
If it works use it,USA JWM TEAM MEMBER
Hide Signatures
(in reply to highhorse)
       Post #: 13
RE: BVM Air Fill Valve- How do u get air in them? - 7/16/2012 12:23 PM
Harley Condra
Score: 105
Status: offline
quote:
ORIGINAL: highhorse
See the photo I submitted in post #4 of this product.
Harley Condra
Hide Signatures
       Post #: 14
RE: BVM Air Fill Valve- How do u get air in them? - 1/17/2013 9:56 PM
juanjulian
Score: 100
Status: offline
My valve started leaking  air without  using it.
Building a jet and last time that presurized the sistem to 100psi  it was all ok. Now a few month later the valve leaks air instantly. Any sugestion?
Tried some car dashboard silicon  to  moisten the inside but  did not worked, tried vaseline and did not worked.
Not happy having a expensive feed valve that ruined by itself.
Cheers
Juan
Hide Signatures
       Post #: 15
RE: BVM Air Fill Valve- How do u get air in them? - 1/17/2013 11:10 PM
Dave Wilshere
Score: 108
Status: offline
I've seen them ruined by pushing the tube in too far! They can leak after one insertion like that... If that method is used a sleeve should be added to stop the tube being inserted too far. It not good when they are returned as faulty because of this... I've been had!
Dave
Motors & Rotors. JetCat, Powerbox, Intairco, Behotec, Graupner. CARF-models Rep. JR Propo for ever!, Jet 1A, MAP, Evojet, BV
Hide Signatures
(in reply to juanjulian)
       Post #: 16
RE: BVM Air Fill Valve- How do u get air in them? - 1/17/2013 11:32 PM
smchale
Score: 115
Status: offline
Dave, good idea with the sleeve, what is the recommended insertion depth? Thx.
Sean McHale
"Strive for simplicity. You never have to repair what you leave out." - Bill Lear
Hide Signatures
(in reply to Dave Wilshere)
       Post #: 17
RE: BVM Air Fill Valve- How do u get air in them? - 1/18/2013 12:27 PM
rolsen12
Score: 100
Status: offline
I have been using a 4mm check valve for the past 3years.
Hide Signatures
       Post #: 18
RE: BVM Air Fill Valve- How do u get air in them? - 1/18/2013 12:54 PM
Harley Condra
Score: 105
Status: offline
Insert the airline JUST deep enough to clear the beveled end to avoid damaging the internal check valve.
Harley Condra
Hide Signatures
       Post #: 19
RE: BVM Air Fill Valve- How do u get air in them? - 1/18/2013 1:00 PM
smchale
Score: 115
Status: offline
quote:
ORIGINAL: Harley Condra
Thanks Harley, this is less than I've been doing so I appretiate the heads up and will revise my process to prolong the valve. Which I really like btw. I'm building the 80" Sabre right now and it has no less than 6 of these.
Sean McHale
Hide Signatures
       Post #: 20
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.625RCU1
