can't give up old faithful (oil soaked wood)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> can't give up old faithful (oil soaked wood)
Page: [1]
Login
can't give up old faithful (oil soaked wood) - 7/17/2012 3:16 AM
kenh3497
Score: 115
Last Login: 5/16/2013
Status: offline
Last year when I crashed my CAP a fellow club member gave me a Super Sportster 40 to use with the caveat it must be passed on to the next person in need, if I stop using it. I think I'm the 5th or 6th owner. It just won't die! Well last week the stopper came out of the fuel tank and you all know where the fuel went. I dumped a bunch of floor dry in the fuel compartment to soak up the left overs. That worked fine.
To the "tip"..... well almost. I was blowing out the left over dust and the air got under the covering at the wing saddle ripping the covering. I tried to iron the covering back down but it would not stick due to all the oil in the wood.
OK "the tip".... I made a long skinny bag out of some brown wrapping paper and put the plane in the bag after stripping all the covering off the fuse. I filled the bag with floor dry and will let it set for a couple weeks to suck out as much oil as possible. From there maybe just a good soapy bath in some hot water????? and rinse well. I know about the KR2 (I thick that's the name) trick and may use that also. It's just the plane is still solid, flies well but with so much oil in the wood. You know the story. I hate to chuck it.
Ken
_____________________________
Sent from my Dry-Erase-Board
Hide Signatures
       Post #: 1
RE: can't give up old faithful (oil soaked wood) - 7/17/2012 5:15 AM
countilaw
Score: 219
Last Login: 5/22/2013
Status: offline
Don't use soapy water! ! !    The wood will warp three ways to  well,,,,,,       Use  MEK,  Acetone or Lacquer thinner to soak the wood,   Then use corn starch  to soak up all the  solvent and it will pull the oil with it.   I made take a couple of applications, but it will pull the oil out.
Frank
It''s a hobby, not a job.
Hide Signatures
(in reply to kenh3497)
       Post #: 2
RE: can't give up old faithful (oil soaked wood) - 7/17/2012 5:46 AM
PatrickCurry
Score: 110
Last Login: 5/23/2013
Status: offline
I'm certainly not an authority but I'd have to agree with Frank.....  especially soapy water which is going to wick in even more and not want to come out.  I would think you'd get enough swelling and warping to pop some glue joints even.  I'd be careful with solvents too because you also might pop some seams depending on what glue was used.  In short, I'd do my best to salvage it, but I wouldn't go nuts or she's a goner anyways.
Hide Signatures
(in reply to countilaw)
       Post #: 3
RE: can't give up old faithful (oil soaked wood) - 7/17/2012 5:49 AM
PatrickCurry
Score: 110
Status: offline
Why don't you just try to floor dry where the covering won't stick, get it as dry as you can and then just glue the covering back down with something appropriate?  I know it's not ideal, but if the covering won't adhere, maybe a really thin layer of epoxy, goop, or whatever might be better than wrecking the whole airframe.  That may be *way* off-base, but just my thinking.  Good luck with it, whatever you decide!
Hide Signatures
(in reply to PatrickCurry)
       Post #: 4
RE: can't give up old faithful (oil soaked wood) - 7/17/2012 2:15 PM
jaka
Score: 158
Last Login: 5/21/2013
Status: offline
Hi!
K2R and aceton will fix it!
Used it many times
Jan Karlsson - Supplier MVVS Products
Hide Signatures
       Post #: 5
RE: can't give up old faithful (oil soaked wood) - 7/17/2012 3:45 PM
Rodney
Score: 169
Status: offline
Once you get all the oil out you can, coat the wood with one of the alaphatic glues such as Titebond II with as thin a coat as you can put on, smear it around with your finger to get a good even coat. Let it dry then put on your covering. I'm quite sure the covering will now iron on nicely.
Hide Signatures
(in reply to jaka)
       Post #: 6
RE: can't give up old faithful (oil soaked wood) - 7/17/2012 4:55 PM
Walt Thyng
Score: 105
Status: offline
K2R from your local bodega is the way to go. May take a number of applications, but it always does the job. As a college student I frequently rebuilt the results of somebody's "oops"; K2R always took care of the oil problem.
Walt
WT in Illinois
Hide Signatures
(in reply to Rodney)
       Post #: 7
RE: can't give up old faithful (oil soaked wood) - 7/18/2012 12:38 AM
kenh3497
Score: 115
Status: offline
I pulled the old girl out of her sack tonight to see how much oil had been soaked up. The wood was less oily, but still a ways to go an boy howdy did that floor dry stink!! I re-bagged her with floor dry and will let her set for a week or so. I'll stock up on the K2R ( I had the right letters, in the wrong order) and have at it later. I may wind up with a new rudder as the tail wheel has wallowed out it's mount and the tail wheel and the rudder can be as much as 20 degrees off of each other. First the oil problem then the easy stuff to follow.
I'm not sure what kind of glue was used on this plane. It was an ARF so who knows I try some Acetone after the K2R. Everybody is right on NOT using soapy water. What the heck was I thinking
Ken
Hide Signatures
(in reply to Walt Thyng)
       Post #: 8
RE: can't give up old faithful (oil soaked wood) - 7/18/2012 4:23 AM
rcmigpilot
Score: 103
Last Login: 12/17/2012
Status: offline
Balsarite film formula will fix your problem.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXB355&P=SM
The two most useless things on Earth are altitude above you, and runway behind you.
Hide Signatures
       Post #: 9
RE: can't give up old faithful (oil soaked wood) - 7/18/2012 9:49 PM
AERORICH73
Score: 115
Last Login: 5/10/2013
Status: offline
Yes, Frank is on to the way of getting the oil out. I made dams around a oil soaked fuse side, and filled it with cornstarch. Then using an eye dropper, soaked the cornstarch with acetone. After it dried, I dump it, and checked for oil. Just to be sure, I did the second soak period, and cleaned off the surface with more acetone. Coated the wood with Balsarite, and ironed on new ultracoat. Believe some method of damming wing ribs enough to allow the cornstarch and acetone to suck out the oil enough for the Balsarite to stick. As it has been mentioned, soap and water is really a no-no.
aerorich73
Scappoose, Oregon
Hide Signatures
       Post #: 10
RE: can't give up old faithful (oil soaked wood) - 7/19/2012 1:52 AM
biam
Score: 110
Status: offline
A good tip I picked up here is to use a heat gun, works fantastic, pretty quick also, when applying heat the oil will bead up on the wood which then can be wiped off. Be patient, keep heating and wiping till its all out.
Bill.
It is always better to be under the gun, than in front of it!
Hide Signatures
(in reply to AERORICH73)
       Post #: 11
RE: can't give up old faithful (oil soaked wood) - 7/19/2012 4:31 PM
PatrickCurry
Score: 110
Status: offline
Lot of great tips here for varying situations!
Hide Signatures
(in reply to biam)
       Post #: 12
RE: can't give up old faithful (oil soaked wood) - 7/19/2012 10:29 PM
kenh3497
Score: 115
Status: offline
quote:
ORIGINAL: rcmigpilot
Now that you mention it I do vaguely remember somebody saying something about balsarite being a big help. Thanks for jogging my memory!!
The heat idea is a good one. My garage is about 140, so that and the floor dry should do the trick
ken
Hide Signatures
(in reply to rcmigpilot)
       Post #: 13
RE: can't give up old faithful (oil soaked wood) - 7/20/2012 12:05 AM
DadsToysBG
Score: 125
Status: offline
Don't laugh but I've people use kitty litter as well. Dennis
DadstoysRC. I fly what I sell
CD Vette City Big Bird
Hide Signatures
       Post #: 14
RE: can't give up old faithful (oil soaked wood) - 11/12/2012 7:49 PM
Papa51
Score: 100
Status: offline
You are correct. I've used kitty litter with great success. It's cheap too!
Hide Signatures
(in reply to DadsToysBG)
       Post #: 15
RE: can't give up old faithful (oil soaked wood) - 11/12/2012 9:06 PM
Dzlstunter
Score: 105
Last Login: 5/18/2013
Status: offline
You can mix up a "slurry" of alcohol and talc (or corn starch) so that it is just spreadable with a stiff brush. Brush it into the wood and let it dry.
When dry, brush the powder off with a stiff brush, then wipe with alcohol and paper towels. Repeat as necessary. Good luck, Dzl
If it doesn't stink, it's not a diesel.
Hide Signatures
(in reply to Papa51)
       Post #: 16
RE: can't give up old faithful (oil soaked wood) - 11/13/2012 4:24 PM
Scott Douglas
Score: 100
Status: offline
My usual trick is....if you have an iron for covering, lay some kitchen roll over the affected area then run the iron (hot!) over it..it'll draw the fuel into the kitchen roll. Then its good old Balsarite (Balsalock as it is here) and re-cover
**edit to corrent my useless typing **
http://www.dadmac.org.uk
http://www.douglasaviation.co.uk
Hide Signatures
(in reply to Dzlstunter)
       Post #: 17
RE: can't give up old faithful (oil soaked wood) - 11/15/2012 3:20 AM
blvdbuzzard
Score: 123
Status: offline
I have used denatured alcohol in a spray bottle to soak the wood. You can see the oil come out of the pours. The oil was designed to mix with alcohol so spraying it on works well. I have used the alcohol with corn starch, saw dust, paper towel to good effect also. I had one fuse that was so soaked, I could not get the oil out so it was a write off any way. So, if it is broken you can not break it. I used break cleaner right out of the can. I soaked it with break cleaner. You should have seen the oil run out of the wood. After it dried I applied 2 coats of Balsarite for film and the covering stuck like it was a fresh kit.
Buzz.
Hide Signatures
(in reply to Scott Douglas)
       Post #: 18
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.235RCU1
