SM large Viperjet Cockpit mounting?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> SM large Viperjet Cockpit mounting?
Page: [1]
Login
SM large Viperjet Cockpit mounting? - 7/17/2012 9:37 AM
Alpenglider
Score: 100
Last Login: 5/21/2013
Status: offline
Hi guys,
i just recently bought a large Viperjet from Skymasterjets!
Everything is set up and ready to go - except the the two cokpits
As i did not come up with a good method how i should mount the front and the back cockpits, so that i can take them out easyly after each flight.
I have seen somewhere, that some are mounting them to the cockpit frame, but cant find any pictures of it.
So i ask you guys how you did it?
I would be very thankful for any tip you can give me!!
Cheers
Thomas
_____________________________
I´m the real Oetzi !!
Hide Signatures
       Post #: 1
RE: SM large Viperjet Cockpit mounting? - 7/17/2012 11:46 AM
CraigG
Score: 105
Status: online
Thomas,
Here's how I did mine. I didn't even use any screws or latches since the canopy frame fits over the cockpit tub flanges and holds them in place. Quick and easy to remove.
Craig
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Alpenglider)
       Post #: 2
RE: SM large Viperjet Cockpit mounting? - 7/17/2012 12:53 PM
f106jax
Score: 110
Status: offline
Thomas,
Mine is mounted to the canopy frame. Everything comes off in one piece, makes start up very easy.
Mike
Hide Signatures
(in reply to CraigG)
       Post #: 3
RE: SM large Viperjet Cockpit mounting? - 7/18/2012 6:49 AM
Alpenglider
Score: 100
Status: offline
HI Craig,
many thanks for the pics - thats one good solution how to do it
Hi Maik,
would you have some pictures for me to see how you did it?
That would really help me a lot
Best regards
Thomas Reiter
Hide Signatures
(in reply to f106jax)
       Post #: 4
RE: SM large Viperjet Cockpit mounting? - 7/18/2012 1:26 PM
f106jax
Score: 110
Status: offline
quote:
ORIGINAL: Alpenglider
HI Craig,
Hi Maik,
Best regards
Thomas Reiter
Hi Thomas,
Will take some pics later today.
Mike
Hide Signatures
       Post #: 5
RE: SM large Viperjet Cockpit mounting? - 7/18/2012 2:11 PM
Gonzalo38
Score: 100
Status: offline
Mine is also attached to the canopy frame. That's the easiest way to go.....
My Gallery http://www.rcuniverse.com/community/profile.cfm?section=gallery&memid=314761
Hide Signatures
       Post #: 6
RE: SM large Viperjet Cockpit mounting? - 7/18/2012 3:12 PM
gonzalom
Score: 100
Status: offline
I have the same setup like Craig and it works quite well too. I believe newer versions of the SM Large Viper had the cockpit attached to the canopy.
Gonzalo
Northern California
Hide Signatures
(in reply to Gonzalo38)
       Post #: 7
RE: SM large Viperjet Cockpit mounting? - 7/20/2012 6:09 PM
Alpenglider
Score: 100
Status: offline
Hi Guys,
many thanks for your answers!
@Mike:
I would really appriciate your efford to upload some images how you mounted the cockpit to the canopy frame.
I think this is how i would like to do it.
Keep them pics coming please
Cheers
Thomas
Hide Signatures
(in reply to gonzalom)
       Post #: 8
RE: SM large Viperjet Cockpit mounting? - 7/21/2012 5:46 PM
f106jax
Score: 110
Status: offline
Hi Thomas,
This photo shows the finished canopy with the tubs installed. Due to photo size, I must make several posts.
Click for fullsize
Mike
Hide Signatures
       Post #: 9
RE: SM large Viperjet Cockpit mounting? - 7/21/2012 5:54 PM
f106jax
Score: 110
Status: offline
These photos show the tubs when attached to the canopy frame. The yellow colored material along the edges of the tubs are 10mm wide strips of G10 which have been glued to the tubs. The G10 stiffens the fragile edges of the tubs as well as provides material for the button head screws to grip to. The button head screws can be seen around the perimeter of the frame. Since the screw heads are not flush to the canopy frame fiberglass, you may need to relieve some fiberglass on the fuselage portion of the cockpit opening. To locate the areas needing to be relieved, dab a black marker pen onto the screw heads and then install the canopy onto the fuselage. When the canopy is removed you will notice black dots where the screw heads are located. I used a round carbide bit in a Dremel to remove a slight amount of material until the canopy frame was flush to the fuselage cockpit opening. It is trial and error to get a good fit.
Click for fullsize
Click for fullsize
Mike
Hide Signatures
       Post #: 10
RE: SM large Viperjet Cockpit mounting? - 7/21/2012 5:58 PM
f106jax
Score: 110
Status: offline
These photos show the ease of installation when you're ready to fly. My VJ has about 80 flights on it and the cockpit attachment has withstood the test of time. Since the tubs are screwed onto the frame, they are easily removed for cleaning, repair, etc.
I hope that the photos have helped explain this mounting method.
Click for fullsize
Click for fullsize
Mike
Hide Signatures
       Post #: 11
RE: SM large Viperjet Cockpit mounting? - 7/22/2012 12:09 PM
Alpenglider
Score: 100
Status: offline
Hi Mike,
many thanks for the pics and your description how you did it! That really helps me doing mine the same way
One more question:
The front of the cockpit with the istrument board and the black cover; it that mounted permanently to the fuse?
It looks like on the pictures that these parts are not coming of with the canopy.
Would i ask to much if you could post some pics on that as well? Your help is really appriciated, thanks!
Best regards
Thomas Reiter
Hide Signatures
       Post #: 12
RE: SM large Viperjet Cockpit mounting? - 7/24/2012 11:28 PM
f106jax
Score: 110
Status: offline
Hi Thomas,
The forward portion of the cockpit is a fixed piece of G-10 that fits in the half moon space in front of the instrument hood. I used a piece of cardboard to make a template, then using trial and error, fitted the G-10, then painted it flat black and glued it in place.
Click for fullsize
Mike
Hide Signatures
       Post #: 13
RE: SM large Viperjet Cockpit mounting? - 7/24/2012 11:39 PM
f106jax
Score: 110
Status: offline
The instrument hood is attached by Velcro to 2 pieces of L shaped graphite angles. The graphite pieces were scrap material and are glued to the sides of the fuselage. The forward edge of the instrument hood is attached by Velcro to the bottom of the G-10 that I described in the previous post. By using Velcro to attach the hood, it can be removed easily to access the batteries which I've mounted on the outside of the nose gear bay.
Click for fullsize
Click for fullsize
Mike
Hide Signatures
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.719RCU1
