5975 KARBONITE Question
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> 5975 KARBONITE Question
Page: [1]
Login
5975 KARBONITE Question - 9/4/2003 7:49:49 PM
jtholley03
Status: offline
I am reading about Karbonite output shafts snapping. I have three 5975's on the tail of Sig Cap. What is the official stance on this problem?
Thx
_____________________________
The man with the green box. Now what does this switch do?
       Post #: 1
5975 KARBONITE Question - 9/4/2003 10:07:53 PM
MikeMayberry
Status: offline
We are evaluting the situation. The hand full of failures we have seen have come from high vibration applications. We're flying the 5975's in a 1/4 scale cap and have had no problems.
(in reply to jtholley03)
       Post #: 2
5975 KARBONITE Question - 9/5/2003 5:26:29 PM
P-51B
Status: offline
What, exactly, are you defining as a "high vibration application"?
In order to think "outside the box", one must first accept there IS a box.
       Post #: 3
5975 KARBONITE Question - 9/5/2003 9:29:25 PM
MikeMayberry
Status: offline
Throttle and one in a heli.
       Post #: 4
5975 KARBONITE Question - 9/5/2003 9:32:55 PM
P-51B
Status: offline
I'll have to watch this issue carefully, since I just bought two of these.
       Post #: 5
5975 KARBONITE Question - 9/6/2003 5:58:13 AM
mglavin
Status: offline
I have four of the 5975's on throttle in 40% models. Probably well over 50 flights on a few of them. So far so good. I really like them. Smooth and fast!
Michael Glavin
RCU Community Moderator
Hitec * Multiplex Field Representative
       Post #: 6
RE: 5975 KARBONITE Question - 9/22/2003 10:44:32 PM
KAD
Status: offline
Hey Guys, I just got a response from Hitec Service saying that the output shaft failures were due to useing Locktite on the screws that hold the servo arm to the shaft. The implication was that the chemicals in Locktite weakened the Carbonite shaft.
       Post #: 7
RE: 5975 KARBONITE Question - 9/23/2003 1:27:09 AM
Geistware
Status: offline
Why would someone want to put loctite on composite threads?
quote:
ORIGINAL: KAD
Aircraft Proving Grounds
http://www.rcaircraft.net/
Information on the building and flying of Radio Control Aircraft.
Site for hobbyist in the R.C. Aircraft modeling world.
(in reply to KAD)
       Post #: 8
RE: 5975 KARBONITE Question - 9/23/2003 1:49:22 PM
wene71
Status: offline
Well what servo are you suggesting for a 90 size heli, to change to ?
Im Glad you are publicly stating this, I remember when JR were saying the 8411 had no trouble even with high complants.
Thanks.
       Post #: 9
RE: 5975 KARBONITE Question - 9/23/2003 4:53:25 PM
MikeMayberry
Status: offline
The 5945's and 5925's are the best servos we have. After some testing we have found that replacing the stock screw with on 2mm longer eliminated the output shaft problem. We are waiting on new screws and will send out replacments when the become available. The stock screw length is 8mm so if you do replace the screw yourselves it should be no more than 10mm long. We will make an official anouncement about this shortly when they confirm the exact screw size.
Mike.
       Post #: 10
RE: 5975 KARBONITE Question - 9/23/2003 4:58:32 PM
mglavin
Status: offline
One should NEVER use Loctite or anything similar with plastic components of any composition. As mentioned above Loctite or similar will react with the plastic, I believe it causes the plastic to become brittle.
Use something like Shoe Goo, PFM or Zap a Dap Goo. I use this on all servos screws metal or plastic geartrains. This provides a resilient or elastic type retaining component which is easily broken loose, unlike when you get carried away with Loctite type products.
Michael Glavin
(in reply to KAD)
       Post #: 11
RE: 5975 KARBONITE Question - 9/24/2003 12:43:25 PM
P-51B
Status: offline
quote:
ORIGINAL: KAD
Good to hear there is a cause, and I shouldn't have to worry since I don't put locktite on 'em!
(in reply to KAD)
       Post #: 12
RE: 5975 KARBONITE Question - 9/29/2003 5:18:22 AM
akflyer
Status: offline
It even happens with out loctite. I saw one snap yesterday on an aileron. No locktite was used.
I was going to put these on my heli but now am not sure if I want any more.
(in reply to P-51B)
       Post #: 13
RE: 5975 KARBONITE Question - 9/29/2003 5:46:43 AM
mglavin
Status: offline
Mike Mayberry suggested the following previously. This makes sense as the 2mm longer screw extends into the shaft below or past the gear spline.
Michael Glavin
       Post #: 14
RE: 5975 KARBONITE Question - 9/29/2003 6:21:17 AM
akflyer
Status: offline
Are we talking about putting longer screws in the 5945's and 5925's or the Karbonites ???????
I will fix another drink while you reply
(in reply to mglavin)
       Post #: 15
RE: 5975 KARBONITE Question - 9/29/2003 6:34:07 AM
mglavin
Fr
