savage xl!-brushless conversion help!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> savage xl!-brushless conversion help!
Page: [1] 2   next >   >>
Login
savage xl!-brushless conversion help! - 7/19/2012 5:36 PM
willsavagexl
Score: 100
Last Login: 8/27/2012
Status: offline
 hey guys im getting more and more annoyed of my nitro savage xl so i will be converting it to brushless, i searched on google but i didnt find the things i was looking for.!
first i need to know if this motor is going to work!- i am trying to spend the least amount of money here
http://www.hobbypartz.com/07e-combo-m4a.html
comes with a 150a esc i know nothing about electric-brushless, literally lmao
for the motor mount i really dont know which one to chose, i would like to keep my stock 3 speed or i can order an flux tranny off ebay,
for the brakes i really dont know, i think its the motor that slows it down?
also for the battery i was looking at the 4s or 5s 4000mah battery i will have 2 of them,
i will post pictures on this thread im going to strip down my savage xl later and cleaning it!
thank in advance guys!
Hide Signatures
       Post #: 1
RE: savage xl!-brushless conversion help! - 7/19/2012 6:00 PM
t9dragon
Score: 328
Last Login: 5/22/2013
Status: offline
I picked up a Speed Passions 1/8 setup for my Savage X SS conversion for $150 shipped.
You will need to get a motor mount plate and motor bracket as for batteries I would either two 2s or two 3s lipos.
Hide Signatures
(in reply to willsavagexl)
       Post #: 2
RE: savage xl!-brushless conversion help! - 7/19/2012 11:14 PM
SyCo_VeNoM
Score: 621
Status: online
quote:
ORIGINAL: willsavagexl
yes the motor slows it down, and does the braking
just get the parts that are different in the flux's tranny, and the 3speed I think its around $8 in parts(idler gear and something else I think been a while since I did mine)
as for the motor mount if you go the HPI flux one you will need to grind it down to fit your motor, as its made to fit the stock one only. Took me about an hour to do with a dremel. you will also need the tvp's (can get the TCScrawler ones I think there cheaper than the HPI), ESC mount, and battery box's
could also look at the other kits there is also the Kershaw designs kits where he has a few different options like a center diff (probably better idea) or motor mounts that fit the normal TVP's, and battery box's to fit them too.
I went the TCS flux plates, idler gear, battery box's route because I wasn't in a hurry, and acquired the parts slowly for as cheap as possible
_____________________________
With great speed comes greater repair bills.
Look at my garage for my model list.
Hide Signatures
       Post #: 3
RE: savage xl!-brushless conversion help! - 7/19/2012 11:28 PM
willsavagexl
Score: 100
Status: offline
 ok thank you, i want to keep the stock tvps and what is the idler gear? and can i keep my stock tranny or if i go to the flux tranny where would i put it?
for motor esc should i put this?, http://www.hobbypartz.com/07e-combo-m4a.html
battery - ? - http://www.hobbyking.com/hobbyking/store/__9174__Turnigy_5000mAh_5S_20C_Lipo_Pack.html
i would buy two of those batteries, and is only 20c is it ok or i can take the 4000mah 5s 30c ?
thanks and i was looking at this one with the flux tranny?  http://204.186.93.64/MotorMounts-Savage.html the first one on top? its very cheap or this one http://204.186.93.64/SavageBrushlessConversion.htm
thanks guys!
Hide Signatures
(in reply to SyCo_VeNoM)
       Post #: 4
RE: savage xl!-brushless conversion help! - 7/20/2012 1:14 AM
SyCo_VeNoM
Score: 621
Status: online
I'd go V2 seeing that has battery boxes and all
the idler gear you would take the tranny apart and replace the 3 speed gear if I remember it right with the idler (its the only part difference) when I bought it the gear was $8 shipped
Hide Signatures
       Post #: 5
RE: savage xl!-brushless conversion help! - 7/20/2012 1:54 AM
willsavagexl
Score: 100
Status: offline
nice and can someone get me a link for the idleing gear and is there intrusction on how to install it?]
also i just take off the brakes off my tranny? and the tranny goes where it usually goes?
thanks!
Hide Signatures
       Post #: 6
RE: savage xl!-brushless conversion help! - 7/20/2012 6:15 AM
willsavagexl
Score: 100
Status: offline
 ive found my motor and esc!
it will be the savage fluxs motor and esc because it is the same price as this - http://www.hobbypartz.com/07e-combo-m4a.html
the esc and motor on ebay come out to roughly 190$
would it be a good choice to go for the savage fluxs electronics?
and also i will be needing something to program the esc right?
thanks
Hide Signatures
       Post #: 7
RE: savage xl!-brushless conversion help! - 7/20/2012 3:16 PM
pyromatic177
Score: 255
Last Login: 4/18/2013
Status: offline
Where did you find that on eBay for that cheap?
!!!Bash Like There''s No Repair Bills!!!
Hide Signatures
       Post #: 8
RE: savage xl!-brushless conversion help! - 7/20/2012 5:28 PM
willsavagexl
Score: 100
Status: offline
il tell you after i buy it lmao,
i just want to know if it will be good? i guesse it will?
will it fit the kershaw v2 motor mount?
thanks!!
Hide Signatures
(in reply to pyromatic177)
       Post #: 9
RE: savage xl!-brushless conversion help! - 7/20/2012 5:58 PM
willsavagexl
Score: 100
Status: offline
 i just discovered i dont buy like two 4s batteries because they add up and make 8s so im buying one 2s and one 3s here are the links, what will be the average run time with both of these?
http://www.hobbypartz.com/77p-sl5000-2s1p-30c-2222.html or this one if comes back in stock! http://www.hobbypartz.com/77p-sl5000-2s1p-30c-2222-hardcase.html
http://www.hobbypartz.com/77p-sl5000-3s1p-30c-3333-hardcase.html
thanks
Hide Signatures
       Post #: 10
RE: savage xl!-brushless conversion help! - 7/20/2012 6:18 PM
t9dragon
Score: 328
Status: offline
Why are you buying one 3s pack? You need two 3s packs.
Hide Signatures
       Post #: 11
RE: savage xl!-brushless conversion help! - 7/20/2012 6:21 PM
SyCo_VeNoM
Score: 621
Status: online
I'd try it with 2 2S batteries first my conversion honestly if I blip the throttle on 4S my savage ends up skidding on its lid for 15 feet on cement...
as for the idler gear installation you would have to look at the parts blowup for the savage flux on HPIs site its kinda easy IMO to install and took me a total of 5 minutes to figure it out
HPI100905 is the idler gear part #
as for fitting the kershaw mount no idea
guy who did a savage X conversion with pretty good pics that used a kershaw mount
http://www.rccoh.com/rc.how-to/savage.brushless.conversion.html
Hide Signatures
       Post #: 12
RE: savage xl!-brushless conversion help! - 7/20/2012 7:02 PM
willsavagexl
Score: 100
Status: offline
quote:
ORIGINAL: t9dragon
one 3s and one 2s
Hide Signatures
(in reply to t9dragon)
       Post #: 13
RE: savage xl!-brushless conversion help! - 7/20/2012 7:03 PM
willsavagexl
Score: 100
Status: offline
quote:
ORIGINAL: SyCo_VeNoM
alright thank you alot! i wont have more run time if im  on 5s than 4s?
and i will defently cheke that link thanks!
Hide Signatures
       Post #: 14
RE: savage xl!-brushless conversion help! - 7/23/2012 2:27 PM
willsavagexl
Score: 100
Status: offline
 alight so this is what i am going to put probly on my savage xl!
-flux 2200kv motor, momba monster esc 1/8 scale 120a
-V2 Savage Brushless Motor Conversion Kit
- 1 5000mah 3s battery and 1 5000mah 2s battery
thats it i think!!
but do i still need my reciever? and my reciever battery and also on the momba monster esc it only has one dean connection, is that for the batter? do i need to put one with a Y so i can plug two batteries?
thanks!!
Hide Signatures
       Post #: 15
RE: savage xl!-brushless conversion help! - 7/23/2012 4:18 PM
pyromatic177
Score: 255
Status: offline
You don't need your receiver battery anymore, but you do need your receiver. And you need to get a deans splitter for your MM www3.towerhobbies.com/cgi-bin/wti0001p
Hide Signatures
       Post #: 16
RE: savage xl!-brushless conversion help! - 7/23/2012 9:09 PM
willsavagexl
Score: 100
Status: offline
 alight is everything that i listed above and the dean connecter spliter is all i need? because im going to order all this soon!]
thanks alot!!
Hide Signatures
       Post #: 17
RE: savage xl!-brushless conversion help! - 7/23/2012 10:32 PM
t9dragon
Score: 328
Status: offline
thanks alot!!
I wouldn't use the splitter. I would just do this with the wires on the ESC.
Hide Signatures
       Post #: 18
RE: savage xl!-brushless conversion help! - 7/23/2012 11:23 PM
willsavagexl
Score: 100
Status: offline
 okok i see because i saw one mamba monster esc that only had one deans connection ( nvm i just saw on the picture i just of missed look i guesse!)
thanks,
and is the list that i wrote above good for the conversion, the kershaw vs motor mount comes with pinion gear idler gear and battery holder/boxes
Hide Signatures
       Post #: 19
RE: savage xl!-brushless conversion help! - 7/24/2012 7:08 PM
willsavagexl
Score: 100
Status: offline
 are these batteries good, like can the hard shell break, and is the connections on the batteries like solid or im better with the other ones?
http://www.hobbypartz.com/98p-30c-5300-2s1p-hardcase.html
thanks
Hide Signatures
       Post #: 20
RE: savage xl!-brushless conversion help! - 7/24/2012 7:32 PM
t9dragon
Score: 328
Status: offline
You would need to add plugs to them.
Hide Signatures
       Post #: 21
RE: savage xl!-brushless conversion help! - 7/24/2012 9:07 PM
SyCo_VeNoM
Score: 621
Status: online
thanks
no those are not good in the savage due to where the wire connects. it you hit the side of the truck it would snap the place the wires plug into on the battery clean off
on the savage you would want the battery exit to be on the end of the battery like this one http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=14991, and not the top of it like the one you linked
Also as for run time between 4S and 5S there is no difference(missed when you asked that b4, and see no one commented on it). The run time is directly affected by the mAh rating of the batteries. putting batteries in series only adds the voltage, and does not add the mAh
(side note the battery I linked I do use in my savage)
Hide Signatures
       Post #: 22
RE: savage xl!-brushless conversion help! - 7/24/2012 11:32 PM
willsavagexl
Score: 100
Status: offline
alright thanks alot! i there are these ones that are not hardcase though, are the gen aces like the ski lipos that have a metal plate all around the batteries?
 http://www.hobbypartz.com/98p-30c-5300-2s1p.html
and also can i put a battery example 5000mah ski lipo 30c  and another one that is 5000 mah ski lipo but 40c? or i have to have both batteries with the same c rating,
thanks! and between 5000 mah and 5300mah will i see a difference because i think the gen ace doesnt have a metal plate like the normal ski lipos i would need hard cases ones but gen ace doesnt have lots of them so yeah and i heard that the gen aces are better than ski lipos
thanks alot!! i will be ordering the HobbyWing XERUN Power System w/XERUN-150A ESC 4274-2000KV Motor for 1/8 Monster Truck finaly because it is a little cheaper and it will be better i thanks
Hide Signatures
       Post #: 23
RE: savage xl!-brushless conversion help! - 7/25/2012 12:50 AM
pyromatic177
Score: 255
Status: offline
They need to be the same C and MAH rating. it's also best that they're the same brand
Hide Signatures
       Post #: 24
RE: savage xl!-brushless conversion help! - 7/25/2012 1:36 AM
SyCo_VeNoM
Score: 621
Status: online
there are no metal plates around batteries. There is one only between cells (I've dismantled lipos before) in hardcases there is a (thin) hard plastic shell on it, on softcases they are shrink wrapped
I have that ESC combo in my savage thing is a beast
My savage flips on its lid with the slightest throttle touch on 4S
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.563RCU1
