What pack should I use?!?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> E-Flight Power Sources >> What pack should I use?!? Page: [1]
Login
What pack should I use?!? - 9/4/2003 11:05:26 PM
jocool282
Status: offline
Hello, I am new to electric flight and do not know much about battery packs. I am looking to power a speed 600 motor on a 7 cell pack. What is the difference between 1500 mAh -1800mAh? which should I choose for the longest duration flights? I will be using a high freq ESC w BEC if that makes a difference. Thanks for the help!
       Post #: 1
What pack should I use?!? - 9/6/2003 5:32:54 AM
Dr Kiwi
Status: offline
Obviously the greater the capacity of your battery [1800mAh v. 1500mAh], at any given current draw, the longer the duration. If the 1800's are physically larger cells they may be able to supply higher currents to your 600 motor, but against that, if they weigh significantly more than the 1500's, then you'll have to take this extra weight into account as far as overall flying performance goes. The ESC is not a factor here.
Cheers, Phil
_____________________________
Dr Phil Millener, Chattanooga, TN
(in reply to jocool282)
       Post #: 2
What pack should I use?!? - 9/6/2003 4:40:44 PM
Greg Covey
Status: offline
Phil has some good advice.
Without more specific information about the motor, manufacturer, and cell type, if is difficult to give more than a general recommendation.
The Speed 600 canned motors (no brushes showing) typically can handle up to 20amps short term current draw so you'll want a battery cell type that can handle the delivery requirement.
Visit my Web Hangar at www.gregcovey.com/rc.htm
       Post #: 3
What pack should I use?!? - 9/6/2003 10:33:57 PM
jocool282
Status: offline
Thanks for responding! Let me now get more specific with the details... Its going to be a Magnetic Mayhem Reverse 22x1 motor on a 2.5:1 gear drive with a 10x8 prop. I would like to get the maximum flight times possible, and if 18 or 1900's weigh a little more I do not think it will be too big a problem since it is going to be a pretty good size plane to start with. (great planes electricub 59'') In other words...I'm not relly looking for awesome vert performance lol. All I want is something that will give enough power for a nice rog and pretty scale flight. Thanks again for the help!
Steven
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.438RCU2
