Back Pressure Problem Raptor 90    Gallery
Logged in as Guest
    Search This Thread
Printable Version
More Resources on the
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • All Forums >> RC Helicopters >> Thunder Tiger - Raptor 30, 50, 60, 90 >> Back Pressure Problem Raptor 90
    Page: [1]
    Login
    Back Pressure Problem Raptor 90 - 7/23/2012 2:52 PM
    gjgibson
    Score: 100
    Last Login: 8/25/2012
    Status: offline
     Raptor 90 starting problem. Recently put together the helicopter. When sarting the bird it won't start until you hold your finger over the end of the exhaust pipe to sart the fuel flow to the engine.
    The engine starts fine but then dies as soon as you take your finger of the end of the exhause pipe.
    The engine  runs fine as long as you hold your finger on the end of the muffler, but as soon as you take your finger of the engine dies.
    The problem seems to be that there isn't. enough back pressure to keep the fuel running to the engine when the exhaust pipe is not resricted.
    The fuel tank and the header tank are both full of fuel and there does'nt seem to be an air lock in the fuel line.
    Any advice as to what the problem and a resolve would be greatly appreciated.
    Regards
    Grant Gibson
    Hide Signatures
           Post #: 1
    RE: Back Pressure Problem Raptor 90 - 7/23/2012 2:54 PM
    BarracudaHockey
    Score: 280
    Last Login: 6/19/2013
    Status: offline
    Is your needle open far enough?
    The engine should draw enough fuel to run at idle even without exhuaust pressure
    _____________________________
    Andy - Helicopter Forum Moderator
    AMA 77227 Leader Member- Contest Director
    www.JaxRC.com
    Hide Signatures
    (in reply to gjgibson)
           Post #: 2
    RE: Back Pressure Problem Raptor 90 - 7/23/2012 3:17 PM
    gjgibson
    Score: 100
    Status: offline
    Hi Andy thanks for getting back to me so quickly.
    I've tried adjusting the "Needle Valve" on the left hand side of the engine ( which controls the mixture strength of the engine speed range from half to fully opened throttle ) with no affect.
    I haven't tried adjusting the "Mixture Metering Screw"  which controls the mixture strength of the speed range from idling to half opened trottle.
    I would think the adjustment should be the latter but correct me if I'm wrong.
    Not sure as to what to focus on first !
    Any suggestion.
    Cheers
    Grant
    Hide Signatures
    (in reply to BarracudaHockey)
           Post #: 3
    RE: Back Pressure Problem Raptor 90 - 7/23/2012 6:14 PM
    Goggles
    Score: 110
    Status: offline
    What kind of engine do you have?
    Is your throttle open enough to make it run and not in the 'kill' zone?
    Perhaps try and go back to the factory settings for the needles. If it doesn't run after you make it richer, then there must be a blockage in your carb or lines somewhere.
    mcpx; HK 500GT; Titan 50 SE; T-600 FBL; T-700 FBL
    40% Yak, F4U; P-47; JR
    Hide Signatures
           Post #: 4
    RE: Back Pressure Problem Raptor 90 - 7/26/2012 7:54 AM
    highlander84
    Score: 100
    Status: offline
    I had a similar problem with the ****ty tt39 and it ended up being the glow plug... I understand a 90 and 30 are worlds apart but thats a simple thing to check. id also check the fuel lines to ensure there is no stopages. remove any inline filters to rule them out.
    Raptor 30 V2
    Futaba 9C Super
    Hide Signatures
    (in reply to Goggles)
           Post #: 5
    Page:   [1]
    Page: [1]
  • See User Ratings
  • Jump to:
    Google
    SITE MAP!   : :   FORUM RULES
    0.250RCU1
