What Gyro for T-Rex 450XL???    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> T-Rex heli >> What Gyro for T-Rex 450XL???
Page: [1]
Login
What Gyro for T-Rex 450XL??? - 7/23/2012 7:00 PM
k5nwz
Score: 100
Last Login: 4/4/2013
Status: offline
I have a T-Rex 450XL that I never finished putting together. I jsut got it out and want to complete it. Im wondering what would be be an affordable Gyro for this thing. Im not looking to put much  money into it. Just need something that will help me learn to fly my bigger Helis.
Hide Signatures
       Post #: 1
RE: What Gyro for T-Rex 450XL??? - 7/23/2012 11:05 PM
Ddaddy
Score: 100
Last Login: 5/27/2013
Status: offline
Hi k5,
What tail servo are you using?  Helps to match them up sometimes.  I like the old piezo hk 401b and many folks have had good luck with the mems ga250.  Both less than $15.  But best to check what servo your using first ;
And welcome to a lot of fun!  What else are you flying?
Cheers,
Ken
_____________________________
MCX, MSR, BOL, Blade SR, franKENblade 400, FBL 450, mCPX, FBL 500, AXN FPV
Hide Signatures
(in reply to k5nwz)
       Post #: 2
RE: What Gyro for T-Rex 450XL??? - 7/26/2012 7:49 PM
Solman
Score: 100
Last Login: 5/25/2013
Status: offline
Make sure that you have an actual tail servo and not a cyclic servo.  It does make a difference.  I personally am having great success with the GA 250 gyro.  It is a Spartan clone gyro and I have used it on my 450 and currently using it on my 600.
Trex 450 Pro / Trex 500 / Trex 600E
AR7200BX microbeast IKON
Hide Signatures
(in reply to Ddaddy)
       Post #: 3
RE: What Gyro for T-Rex 450XL??? - 7/27/2012 12:17 AM
k5nwz
Score: 100
Status: offline
Ok, Just realized I need servos too. There is (1) Align 6X Micro Servo in the kit. (C614)?? So servo recomendations would be very helpfull too. The Heli DOES have a tail servo mount. Prolly order it all from Hobbyking. It may alse need to be known Im not a 3d pilot yet. So do you still recomend the GA250?  http://www.hobbyking.com/hobbyking/store/__15318__HobbyKing_GA_250_MINI_MEMS_Gyro_.html and if so, What servos should I get?
Thanks SO very much for your help. I really appreciate it!!
Shawn
I fly gient scale airplanes but have lots of everything, Boats, Planes, Trucks, Cars and Helis....Yes, Im a junkie...lol
< Message edited by k5nwz -- 7/27/2012 3:00 AM >
Hide Signatures
(in reply to Solman)
       Post #: 4
RE: What Gyro for T-Rex 450XL??? - 7/27/2012 8:54 AM
Solman
Score: 100
Status: offline
I believe that the GA250 is by far one of the most under-estimated gyro's out there.  I do backwards flight and tail slides with no issues at all.  Set up is so simple, 3 or 4 steps and you are done.  Getting the second half of the menu can be a pain at times.  You have to hold the rudder stick to the side and then flip your gear switch 3x.
Hide Signatures
(in reply to k5nwz)
       Post #: 5
RE: What Gyro for T-Rex 450XL??? - 7/29/2012 10:27 PM
k5nwz
Score: 100
Status: offline
Thank for the reply. The GA250 is defitlay the way I will go. Now I all I need to know is what servos to order. I heard it makes a difference.  http://www.hobbyking.com/hobbyking/store/__287__189__Servos_and_parts-Micro_Servo_5_10g.html
Cant wait to order....
Thanks again for all your help
Shawn
Hide Signatures
       Post #: 6
RE: What Gyro for T-Rex 450XL??? - 7/30/2012 4:26 AM
Solman
Score: 100
Status: offline
When it comes to HK servos for heli's, I am not sure which are good.  You may want to spend a little more on the servo's.  It will be easier to get replacement gears and that way you know you have the right servos.
Hide Signatures
(in reply to k5nwz)
       Post #: 7
RE: What Gyro for T-Rex 450XL??? - 7/30/2012 1:54 PM
k5nwz
Score: 100
Status: offline
 Ok, Great, Thanks. I will go ahead and order the Gyro from HK. Do you have a servo recomndation?
I really appreciate your help
Shawn
Hide Signatures
       Post #: 8
RE: What Gyro for T-Rex 450XL??? - 7/30/2012 8:27 PM
Solman
Score: 100
Status: offline
My personal favorite for the 450 is the Hitec HS65 servos for the cyclic and the Futaba 9257 for the tail.  They have served me well.
Hide Signatures
(in reply to k5nwz)
       Post #: 9
RE: What Gyro for T-Rex 450XL??? - 8/3/2012 5:55 PM
Goggles
Score: 105
Status: offline
quote:
Do you have a servo recommendation?
When choosing servos, for the tail you need something fast, in the .05-.08 range and in the cyclic the typical servo is .10-.14 range. There are many good servos (Savox, Futaba, Align, Hitec, Hyperion, JR). I'm sure there are many more of those micro servos, but those brands should do you well.
I have some cheap HK servo's on my 500 and i don't like them. They don't center well and I've noticed one moves a little slower than the other. I hardly ever fly it so I'm not replacing them.
BTW, you said you fly giant scale, what kind of servos do you run in them and would you use a HK servo instead?
mcpx; HK 500GT; Titan 50 SE; T-600 FBL; T-700 FBL
40% Yak, F4U; P-47; JR
Hide Signatures
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.672RCU1
