Help with a Paddle boat rc gear.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> RC Scale Boating >> Help with a Paddle boat rc gear. Page: [1]
Login
Help with a Paddle boat rc gear. - 7/24/2012 3:54 AM
vxquizit1
Score: 100
Last Login: 9/8/2012
Status: offline
  I know everyone here is happy to help, I just dont like hassling for basics.
I want to build a scale Murray River Paddle Boat. Around a meter long. There are no plans because most the people who built them had no boat building experience.
As I can see at the moment, I need twin, reversable motors and rudder.
I have 1x FS 6c Tx with matching 6c Rx`s. 3x BEC`s, 2x 4500 LiPo batts.
Have got the Rx talking to the Tx operating servo ok but doesnt appear to cause any voltage change on the throttle. Motor not connected, using muliti meter.
I have the Bec plugged into the Rx channel 3 for power supply to the Rx. Is it right that I cant plug another Bec in unless I cut the power wire ?
Cheers. David.
Hide Signatures
       Post #: 1
RE: Help with a Paddle boat rc gear. - 7/24/2012 4:03 AM
dauntlessfan
Score: 110
Last Login: 6/18/2013
Status: offline
Gosh I'd think for a paddle boat you wouldn't need LiPos and elaborate speed controls, rather just basic gel cell batteries and a pair of low RPM, low amp-draw geared motors. But then again I've never built one. allelectronics dot com is a great surplus site for geared motors if that is indeed the case.
Hide Signatures
(in reply to vxquizit1)
       Post #: 2
RE: Help with a Paddle boat rc gear. - 7/24/2012 6:14 AM
Deathwish
Score: 100
Last Login: 6/9/2013
Status: offline
Try this out
http://web.aanet.com.au/dragoncity/A_Murray_River_paddle_Boat.pdf
Hide Signatures
(in reply to dauntlessfan)
       Post #: 3
RE: Help with a Paddle boat rc gear. - 7/28/2012 12:58 AM
herrmill
Score: 106
Last Login: 6/19/2013
Status: offline
You'll also want to spend some time on Paddleducks, a UK forum dedicated to paddle boat modeling.
www.paddleducks.co.uk
Hide Signatures
(in reply to Deathwish)
       Post #: 4
RE: Help with a Paddle boat rc gear. - 7/28/2012 10:41 AM
mfr02
Score: 105
Status: online
Lipos only if you really really need to keep the weight down.
3xBEC.  ???  1 ESC per motor (2) if you need independent control.  If they both have a BEC fitted, disable one by disconnecting the centre (usually red) wire of one. 1 servo for the rudder.  Stick with brushed motors for a simple life, probably something big and slow running with a lot of poles and gear them down using a pulley drive for quietness, a gearbox if you don't mind the noise, maybe a worm drive if you can find the parts.
Hide Signatures
(in reply to herrmill)
       Post #: 5
RE: Help with a Paddle boat rc gear. - 7/28/2012 10:38 PM
vxquizit1
Score: 100
Status: offline
 thank you all.
Hermil a special. i wasnt sure about the bec wires, so wasnt game to plug in the extra. Been in PDucks to, thanks Herrmill. Awsome site.
Hide Signatures
       Post #: 6
RE: Help with a Paddle boat rc gear. - 7/29/2012 11:16 AM
mfr02
Score: 105
Status: online
No need to cut - just winkle the terminal out of the plastic body and tape it back in a tidy manner with insulating tape.  Should you need to later, it can easily be replaced.  Modern BECs might not need the precaution, but doing the job can prevent problems.
Hide Signatures
       Post #: 7
RE: Help with a Paddle boat rc gear. - 7/29/2012 6:50 PM
Apismelifera
Score: 100
Last Login: 2/21/2013
Status: offline
1, Top view. 2 - Side view. 3 - 3D View. 4 - Connector, tabs visible. 5 - Cur away view.
All you need to do, is push down on the the connector pin's tab. Where indicated in drawing. Just enough to let it slide out of the back of the connector. I use a tiny jewelers screwdriver. Cover the pin with a little bit of tape and you're done. No need to cut the wire.
If there comes a time when you want to put the pin back in, you can gently pull the back of the tab back up so it will lock in place when reinserted into the connector.
My drawings are not to scale, they're just meant to provide clarity and understanding.
Click to see fullsize image.
Click for fullsize
_____________________________
John KaBang
Hide Signatures
(in reply to mfr02)
       Post #: 8
RE: Help with a Paddle boat rc gear. - 7/30/2012 12:38 AM
vxquizit1
Score: 100
Status: offline
Thank you   Apismelifera.
Hide Signatures
(in reply to Apismelifera)
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.437RCU1
