BUSA 1/6th scale Sopwith Pup build.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> BUSA 1/6th scale Sopwith Pup build.
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
BUSA 1/6th scale Sopwith Pup build. - 7/24/2012 7:30 PM
GaryHarris
Score: 168
Last Login: 5/19/2013
Status: offline
Just got the kit in about an hour ago and I have to say that the quality is everything I expect from Balsa USA. Very, very nice! However, this will most likely NOT be the easiest kit I ever built, so I am wide open for suggestions and hope yall tune in on this journey.
Power will be provided by a Saito 56 and most likely I'll stick with the standard antique Solartex with the roundel design, but I am open for suggestions. I'm also thinking of NOT clear coating the covering and just let it get that vintage look.
_____________________________
Sig Kadet Brotherhood #1
Ultra Sport Brotherhood #105
Hide Signatures
       Post #: 1
RE: BUSA 1/6th scale Sopwith Pup build. - 7/24/2012 8:34 PM
optech
Score: 105
Last Login: 5/17/2013
Status: offline
Sweet! Subscribed and looking forward to the build.
Enjoy,
Mike
Hide Signatures
(in reply to GaryHarris)
       Post #: 2
RE: BUSA 1/6th scale Sopwith Pup build. - 7/24/2012 8:35 PM
GaryHarris
Score: 168
Status: offline
Getting the board ready.
Hide Signatures
       Post #: 3
RE: BUSA 1/6th scale Sopwith Pup build. - 7/24/2012 8:44 PM
soarrich
Score: 136
Last Login: 5/20/2013
Status: offline
I remember a Jeff Troy trick of using a wet teabag to get that old look.
Rich Border AMA 77727
Sig Kadet Brotherhood #2
Hide Signatures
       Post #: 4
RE: BUSA 1/6th scale Sopwith Pup build. - 7/24/2012 8:52 PM
GaryHarris
Score: 168
Status: offline
quote:
ORIGINAL: soarrich
Or the coffee trick.
Hide Signatures
(in reply to soarrich)
       Post #: 5
RE: BUSA 1/6th scale Sopwith Pup build. - 7/24/2012 10:30 PM
SunDevilPilot
Score: 147
Status: offline
Subscribed!  This should be fun!
SunDevilPilot
SunDevilPilot
Cub Brotherhood # 47
Hide Signatures
       Post #: 6
Rv7garage
Score: 128
Last Login: 4/26/2013
Status: offline
I'm sub'd, too
#26 Club Saito ***CUB BROTHERHOOD*** #86
My full-scale build: www.rv7garage.blogspot.com
Hide Signatures
(in reply to SunDevilPilot)
       Post #: 7
RE: BUSA 1/6th scale Sopwith Pup build. - 7/24/2012 10:40 PM
GaryHarris
Score: 168
Status: offline
Thanks guys.
I'm going through the ribs now trying to number them, but I'm going to take my time on this build as not to make many mistakes.
Hide Signatures
(in reply to Rv7garage)
       Post #: 8
RE: BUSA 1/6th scale Sopwith Pup build. - 7/25/2012 4:59 AM
GaryHarris
Score: 168
Status: offline
I got the W1 ribs separated and did a quick check and noticed that the notches for the forward spar are too shallow which make for a lot of sanding after the wing was built. I hate that.
I used a Dremel cut off wheel to open up the notches a little and to keep the corners square.
I'm not too worried about perfection on this build, so I won't get anal about getting everything being perfect. I want it a little rough.
Hide Signatures
       Post #: 9
RE: BUSA 1/6th scale Sopwith Pup build. - 7/25/2012 5:05 AM
GaryHarris
Score: 168
Status: offline
Oh yea, I gots some Popa Chubby jamming in the background.
Hide Signatures
       Post #: 10
RE: BUSA 1/6th scale Sopwith Pup build. - 7/25/2012 6:00 AM
oldtyme
Score: 148
Last Login: 5/6/2013
Status: offline
Gary.........how do you subscribe? I want to follow this build. I have one on the shelf ready to start and want to watch your build. Mine will have a Magnum 52FS for power and I am also using the Solartex. I bought the vintage wheels and the vinyl decal package.
Good luck and I can't wait to see the progress!
Andy
AMA 16066
Hide Signatures
       Post #: 11
RE: BUSA 1/6th scale Sopwith Pup build. - 7/25/2012 6:12 AM
GaryHarris
Score: 168
Status: offline
Thanks Andy.
Look at the top right hand corner of the page. And providing my Saito 56 will have ample power for the Pup, you should be fine with a Mangum 52 on your plane. I had one that had unlimited vertical on a 4*40.
Hide Signatures
(in reply to oldtyme)
       Post #: 12
RE: BUSA 1/6th scale Sopwith Pup build. - 7/25/2012 6:22 AM
oldtyme
Score: 148
Status: offline
Hi Gary...........I have a 4*40 with a Magnum 52FS also..........just waiting to be maidened........I've got too many projects!
Ok........I'm subscribed as well......Thanks and I'll be following your progress closely.
AMA 16066
Hide Signatures
       Post #: 13
RE: BUSA 1/6th scale Sopwith Pup build. - 7/25/2012 6:29 AM
GaryHarris
Score: 168
Status: offline
Hi Andy.
After thinking about it Andy, I would love for this to be more than me building this kit. Put it on the board and lets build together. It would help keep me motivated.
Hide Signatures
       Post #: 14
RE: BUSA 1/6th scale Sopwith Pup build. - 7/25/2012 1:32 PM
dmbaerry
Score: 100
Status: offline
Sub'd also.. looking forward to this build....
Hide Signatures
       Post #: 15
RE: BUSA 1/6th scale Sopwith Pup build. - 7/25/2012 3:43 PM
Sporto
Score: 100
Last Login: 4/17/2013
Status: offline
Hello Gentlemen - I subscribed as well.  I bought this plane completed by an old builder about 3 years ago and put an OS 52 and Futaba S3004 servos in it this summer.  Although she now flies great (very scale and a lot of fun), we have alot of weight upfront (about a pound of lead in the nose plus a 2 oz heavy hub).  Not sure why it took so much weight (other than the builder probably mounted the rudder and elevator servos a bit too far back).  There are a couple of existing good threads on this plane (one electric and one glow).  Very interested in seeing how this one comes out.  Good luck!
Hide Signatures
(in reply to dmbaerry)
       Post #: 16
RE: BUSA 1/6th scale Sopwith Pup build. - 7/25/2012 11:09 PM
GaryHarris
Score: 168
Status: offline
quote:
ORIGINAL: Sporto
Hello Sporto, that's good to know. In order to cut down on adding lead to the nose, I will look at building my own RX battery pack in order to increase mAh and turn dead weight into longer flight times between charges. Looking at the fuse drawing, I might be able to fit a 4 cell sub C size pack with some creativity.
Hide Signatures
(in reply to Sporto)
       Post #: 17
RE: BUSA 1/6th scale Sopwith Pup build. - 7/25/2012 11:26 PM
GaryHarris
Score: 168
Status: offline
quote:
ORIGINAL: dmbaerry
Welcome dmbaerry.
I guess I better get to work!
Hide Signatures
       Post #: 18
KitBuilder
Score: 131
Status: offline
I'm finishing up the 1/6 N17. I beleive it's similar techniques and an easy build. The only issue I had was the soldering the struts and cabane and lining up the wings.. but its my first bipe as well.
Mike -
I was born a pilot... 100 years to late.
Hide Signatures
       Post #: 19
RE: BUSA 1/6th scale Sopwith Pup build. - 7/25/2012 11:30 PM
Minnreefer
Score: 195
Status: offline
I am watching this as well, I won't be doing mine for a while, I have many other projects that I need to do first. I have a Saito 51 that needs a kit home and this sounds great. Maybe I can sneak a peak at you flying in when I come down to visit my inlaws in Conroe in October.
Tiger 2 brotherhood #14
The Common flyer, best of the lousiest, and lousiest of the best.
Hide Signatures
(in reply to KitBuilder)
       Post #: 20
RE: BUSA 1/6th scale Sopwith Pup build. - 7/25/2012 11:42 PM
GaryHarris
Score: 168
Status: offline
quote:
ORIGINAL: KitBuilder
Thanks Mike.
Hide Signatures
       Post #: 21
RE: BUSA 1/6th scale Sopwith Pup build. - 7/25/2012 11:46 PM
GaryHarris
Score: 168
Status: offline
quote:
ORIGINAL: Minnreefer
Howdy Minnreefer. I live near and fly at Scobee field, which is about 40-50 miles from Conroe. Hit me up !
Hide Signatures
(in reply to Minnreefer)
       Post #: 22
RE: BUSA 1/6th scale Sopwith Pup build. - 7/26/2012 12:38 AM
I_Fly
Score: 100
Status: offline
Subscribed.   Looking to get back into kit building and considering some BUSA kits...  This thread might be just the motovation I need.
Ultra Sport Brotherhood #122
Ryan STA/STM Brotherhood #5
Hide Signatures
       Post #: 23
RE: BUSA 1/6th scale Sopwith Pup build. - 7/26/2012 1:13 AM
GaryHarris
Score: 168
Status: offline
quote:
ORIGINAL: I_Fly
If anyone can mess a plane up, I can.
Hide Signatures
(in reply to I_Fly)
       Post #: 24
RE: BUSA 1/6th scale Sopwith Pup build. - 7/27/2012 11:46 PM
GaryHarris
Score: 168
Status: offline
Got a little done but not much to report. The only real issue I had was trying to figure out why the 4th rib in from the left is made of plywood and the instructions call for using a dihedral gauge to angle it. But that's why it's important to read ahead in the manual and study the drawings. It's for the cabane struts. My first bipe.
Working on the aileron now.
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.672RCU1
