XTE brushless motor in Earthquake 8e    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> XTE brushless motor in Earthquake 8e
Page: [1]
Login
XTE brushless motor in Earthquake 8e - 7/25/2012 10:45 PM
EvoLouShun
Score: 100
Last Login: 11/22/2012
Status: offline
Does anyone know if the brushless motor in the XTE series fit the 8e series, specifically the Earthquake 8e?  I would keep everything stock in the 8e, including pinion gear and ESC.  Any help would be appreciated.
Thanks in advance.
Lou
< Message edited by EvoLouShun -- 7/26/2012 2:59 AM >
Hide Signatures
       Post #: 1
RE: XTE brushless motor in Earthquake 8e - 7/27/2012 1:32 AM
nitrosportsandrunner
Score: 296
Last Login: 5/19/2013
Status: offline
quote:
ORIGINAL: EvoLouShun
Thanks in advance.
Lou
It should fit.
However, if you keep the gearing the same then it will be slower than stock.
The 8e motor is a 2200+kv motor, while the XTE has a 1744kv motor. Since both motors run on 4s lipo, the XTE motor will run at less RPM's than the 8e motor.
You could gear up the 8e to compensate, but honestly I wouldnt. The XTE motor will have more torque and will put more strain on the 8e's driveline.
Look for other 1/8 scale 550 sized motors that are around 2100-2300kv if you want to replace the stock motor with a different one.
_____________________________
Redcat Mirage Pro, Tornado EPX Pro, SC10, TTR Phoenix XB. Redcat Racing Dealer.
Hide Signatures
(in reply to EvoLouShun)
       Post #: 2
RE: XTE brushless motor in Earthquake 8e - 7/27/2012 1:49 AM
EvoLouShun
Score: 100
Status: offline
quote:
ORIGINAL: nitrosportsandrunner
Thanks in advance.
Lou
It should fit.
Thanks for the response!  I actually burnt out my earthquake 8e motor.  I was running aftershock 15T pinion and aftershock spur gear as well as Monsoon XTE wheel/tire combo.  Even with a heatsink and fan upgrade, I managed to cooked the poop out of that stock 8e motor.  Would the 550 motor can fit in the earthquake?  I believe the stock 8e motor is a 540.  With the range of kv you mentioned run cooler temps in my truck (given the 550 motor fits) and all my other mods.
Thanks again!
Hide Signatures
(in reply to nitrosportsandrunner)
       Post #: 3
RE: XTE brushless motor in Earthquake 8e - 7/27/2012 2:02 AM
Score: 296
Status: offline
its been alittle while since I had my 8e, but I think a 550 will fit. I believe the stock motor has a rather large heat sink on it, correct? That will take up the same space as a 550 motor. I think the difference between a 540 and a 550 is like 1-2 mm in width (diameter)
I hadnt realized you were running larger tires and different gearing already. If the stock motor heated up, the a lower KV motor should help that problem.
If you want PM me for a price on a XTE motor
Hide Signatures
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.266RCU1
