8th Scale TA-152 Assembly Videos    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pylon Universe - RC Pylon Racing >> Scale Racing >> 8th Scale TA-152 Assembly Videos Page: [1]
Login
8th Scale TA-152 Assembly Videos - 7/26/2012 7:05 AM
pjakew
Score: 100
Last Login: 6/18/2013
Status: offline
Hey Folks:
Tim and I are doing some video segments on construction of his laser cut TA-152 kits. Even though this will focus on the Focke Wulf interceptor, this technique can be used on just about all of 8th Scale Warbird wings. Here is the first video I assembled. I should have part 2 done in a couple of days. This is an ongoing series, but at least it gets those who want to build one of these kits a little bit of help and instruction. Enjoy.
http://m.youtube.com/watch?v=DkZYIcFkOSs
_____________________________
"You Can Teach...Monkeys To Fly Better Than That!"
Hide Signatures
       Post #: 1
RE: 8th Scale TA-152 Assembly Videos - 7/27/2012 7:31 AM
pjakew
Score: 100
Status: offline
Part 2 done. Tim is going to work on the other wing section, and then we will complete the video. May be a little down the road.
Enjoy the videos and give some feedback.
http://m.youtube.com/watch?v=rvfaXFqV6JQ
Hide Signatures
(in reply to pjakew)
       Post #: 2
RE: 8th Scale TA-152 Assembly Videos - 7/30/2012 2:15 AM
Iron Dog
Score: 105
Last Login: 6/19/2013
Status: offline
Jake and Tim,
I love picking up little tips and tricks from other builders.  Even though most of my wings are jig-built now, some little nuggets I found helpful:
When CA-ing the sheeting, I always found it too tricky to try to apply pressure relatively evenly across the entire surface waiting for it set without accelerator.  If I sprayed an area with accelerator, then the glue would often
set in a nearby area (due to overspay) before contact was made.  Eventually, I gave up on CA-ing much of my wing sheeting, and just used aliphatic wood glue and pin the sheeting to the ribs; but, then get bothered by all the pin holes I'd have to fill and sand.  Spraying the back of the balsa sheet with accelerator so that the glue would set nearly instantly in one area that made immediate contact, but not in others until ready, seems to be a tip worth trying.
Thanks for taking the time to do these videos.  I look forward to the next installment.
WARNING: High-nitro fumes cause an unusual form of mental debilitation resulting in excess expenditures on racing airplanes.
Hide Signatures
       Post #: 3
RE: 8th Scale TA-152 Assembly Videos - 8/16/2012 4:53 AM
pjakew
Score: 100
Status: offline
3 more videos, still have one more to do to complete the wing series. Check them all out. Here is the link to the 3rd video.
http://www.youtube.com/watch?v=F2YiqVtr4rM&feature=g-upl
Hide Signatures
(in reply to Iron Dog)
       Post #: 4
RE: 8th Scale TA-152 Assembly Videos - 8/16/2012 1:49 PM
D.E.
Score: 100
Last Login: 6/10/2013
Status: offline
Why not build sheeted foam wings with spar? They are lighter, much easier and more accurate.
Good work and fun to watch though, keep going!
DE
Hide Signatures
       Post #: 5
RE: 8th Scale TA-152 Assembly Videos - 8/16/2012 11:59 PM
tdstaf
Score: 103
Status: offline
quote:
ORIGINAL: D.E.
DE
D.E, Thanks for your input.
I have done them both ways and to make a foam wing accurate it would have to have three panels cut in order to have the airfoil consistant. When they are built that way I have found they are not any lighter or stronger it it takes longer to lay up and I have to wait for it to dry. I'm Impatient!
When I'm by myself building I can have one of the halves completed with alierons, leading edge, and tip In about an hour and a half so this tends to be my prefered method of assembly. It's just personal preference, I like built up wings.
Who says scale warbirds have to be GIANT.
Hide Signatures
(in reply to D.E.)
       Post #: 6
RE: 8th Scale TA-152 Assembly Videos - 9/3/2012 7:14 AM
pjakew
Score: 100
Status: offline
Just to let everyone know, the final video to complete the wing series that Tim did is done and posted. Just look at the previous links to get to my Youtube page and you can find it. I sure had a great time doing the videos and I learned a ton. It should make my next project a lot easier.
Hide Signatures
(in reply to tdstaf)
       Post #: 7
RE: 8th Scale TA-152 Assembly Videos - 12/21/2012 12:23 AM
vertical grimmace
Score: 164
Status: offline
Did you guys ever race this thing? I am wondering how it does?
"let''''s just say, they will be satisfied with less" Ming the Merciless
Hide Signatures
       Post #: 8
RE: 8th Scale TA-152 Assembly Videos - 1/6/2013 2:09 AM
tdstaf
Score: 103
Status: offline
It Hasn't been completed yet. Schedules haven't worked as of late to make the fuse video so I'm going to just continue to build it on the other thread it has been on to complete it for march racing.
Tim
Hide Signatures
(in reply to vertical grimmace)
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.813RCU1
