Gas tank help    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> Gas tank help
Page: [1]
Login
Gas tank help - 7/26/2012 8:03 AM
bbrc77
Score: 100
Last Login: 5/25/2013
Status: offline
 Please help!
I set up a 3-line tank for a 2 stroke glow engine. There is the carburator line with a clunk, the vent line which is pointing to the top of the tank, and a fill line which also has a clunk. Because of the way the engine is mounted, the main carburator has to travel up.
PROBLEM:  the fuel stops going into the carburator. I already checked for leaks, etc. I don't know what I am doing wrong. Any advise is greatly appreciated.
Thanks.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 1
RE: Gas tank help - 7/26/2012 11:27 AM
pe reivers
Score: 646
Status: online
Make the line to the carburetor shorter, so it does not bend upwards.
I may read the picture wrong, but if you have the tank center below the carb center, that is a problem as well.
_____________________________
Pe, (www.mvvs.nl), MVVS, MOKImotor, RCexl, MTW, Xoar, Mejzlik.
Blessing in ignorance? There is sanctuary in analysis.
Hide Signatures
(in reply to bbrc77)
       Post #: 2
RE: Gas tank help - 7/26/2012 12:33 PM
Sport_Pilot
Score: 233
Status: offline
This could be set up as uniflow.  The line you call the fill line is actually the vent line, the vent line is a vent line used for filling only.  Make sure the vent line (the other line with a clunk) is shorter than the pick up line.  When you fill it you unplug the fill vent and pump fuel till fuel runs out of it.  Fuel may come out the pick up line and flood the carb, especially if the carb is not at idle, so this is often plugged during fill up.  Although on many of my  uniflow setups it is just enough to prime the engine.
“I Saw Elvis at 1000 Feet” John Force
Hide Signatures
       Post #: 3
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> Gas tank help
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.547RCU1
