Pipe length, starting point .40 & .45    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Nitro Boats >> Pipe length, starting point .40 & .45 Page: [1]
Login
Pipe length, starting point .40 & .45 - 7/26/2012 3:01 PM
HeliDrop
Last Login: 11/9/2012
Status: offline
Does anyone have a chart on pipe length/motor size?
I've got a .40 OPS in a rigger and a .45 K&B in a 3point hydro. I'm looking to get a base length to start with from the glow plug to the weld on the pipe.
I tried searching the forums. Maybe I'm not looking in the right place. Thanks.
Hide Signatures
       Post #: 1
RE: Pipe length, starting point .40 & .45 - 7/27/2012 5:25 AM
Ron Olson
Last Login: 5/18/2013
Status: offline
Start it off at 10-1/2" and see where that gets you. With 'riggers you might need to go shorter but it's better to start off long than short.
_____________________________
Member, Southwest Michigan Model Boat Club and the IMPBA.
269 Racing Team
Hide Signatures
(in reply to HeliDrop)
       Post #: 2
RE: Pipe length, starting point .40 & .45 - 7/30/2012 3:36 PM
HeliDrop
Status: offline
Are you saying a little shorter for the rigger because it's a .40 or because it's a rigger?
Also tell me if I'm correct here: Lengthening the pipe will create more torque but lower the top end. Likewise, shortening the pipe will give you a higher top end but lower your bottom end.
Hide Signatures
(in reply to Ron Olson)
       Post #: 3
RE: Pipe length, starting point .40 & .45 - 7/30/2012 3:44 PM
Blackout
Last Login: 5/16/2013
Status: offline
quote:
ORIGINAL: HeliDrop
Yup, longer pipe is more torque. A shorter pipe will give you more rpm's, but less torque.
Craig Mapstone, IMPBA #20305S, Stony Pond Model Boat Club
2012 D1 20 Hydro Champion
Hide Signatures
       Post #: 4
RE: Pipe length, starting point .40 & .45 - 7/30/2012 3:49 PM
HeliDrop
Status: offline
Thanks Craig.
I'll measure my pipe lengths out and make sure my fuel is ballpark and give it another try.
Hide Signatures
(in reply to Blackout)
       Post #: 5
RE: Pipe length, starting point .40 & .45 - 8/5/2012 1:56 AM
wilsonreef
Last Login: 5/9/2013
Status: offline
Helidrop,
I'm not trying to hijack your thread, but I have a question I started to post, but this has the answers, well I have one more.  Maybe this will help others too.  I too have a K&B 45, but my pipe has a band in the center not a convergence point (or weld point).  The 10 1/2" your referencing, would this be to the center of the band on the pipe?
Thanks for the interuption.
Carl
Hide Signatures
       Post #: 6
RE: Pipe length, starting point .40 & .45 - 8/6/2012 7:17 PM
HeliDrop
Status: offline
I'm pretty sure you measure to where the pipe starts to taper down toward the stinger. I'm not really sure with some of the new style pipes though. Maybe Craig can chime back in.
Measure to the weld on this:
I am unfamiliar with a pipe like this so I am unable to tell. I'm very inexperienced.
Hide Signatures
(in reply to wilsonreef)
       Post #: 7
RE: Pipe length, starting point .40 & .45 - 8/6/2012 7:34 PM
Blackout
Status: offline
quote:
ORIGINAL: HeliDrop
I'm not sure on the two nitro pipes you linked.
Normally you measure at the widest point or the middle of the widest point if it is a band pipe. I'm no expert, I just error on the long side and then shorten from there.
Hide Signatures
       Post #: 8
RE: Pipe length, starting point .40 & .45 - 8/7/2012 2:16 AM
advanced builder
Last Login: 5/17/2013
Status: offline
I've been running the new AB .45 pipe from Stu Barr I like it plenty. NOT the black CAM one. http://www.hobbysupplies.com.au/CMB%20Pipes.htm
oops Craig I let that one out. But I like the .45 water cooled header from Glenn at Nova Rossi. I got that today. I had a $50 gift card from NLMBC
Stoney Pond Model Boat Club, Canandaigua, NY
International racer
Hide Signatures
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.297RCU1
