RE: Fly Eagle F-16 1:4.6 Advance, wow    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Mig 15 Global Jet Club with Jetcat p-80SE - RTF
Seller:  cessna172av
Details:   $5,000.00   |  5/4/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: Fly Eagle F-16 1:4.6 Advance, wow
Page: <<   < prev  2 3 4 [5] 6 7 8 9 10 11   next >   >>
Login
RE: Fly Eagle F-16 1:4.6 Advance, wow - 9/6/2012 3:17 PM
FenderBean
Last Login: 5/18/2013
Status: offline
I really like they added all the detail stuff.
_____________________________
Kingtech 170F
Fly Eagle 1/6 F-16 1/7 F-15E 1/7 F-14
Hide Signatures
(in reply to macmuz)
       Post #: 101
RE: Fly Eagle F-16 1:4.6 Advance, wow - 9/6/2012 4:08 PM
Pepperpete
Status: offline
In the video I thought the exact same thing.
quote:
ORIGINAL: macmuz
Hey all.
Nice video.
Does the nose gear door seem too close to the ground?
In a hard landing or bump in the runway and the nose strut compresses, looks (to me) like it might grab and break the nose door off.
Not meaning to be mean, just my observation.
Mario.
Hide Signatures
       Post #: 102
RE: Fly Eagle F-16 1:4.6 Advance, wow - 9/6/2012 8:19 PM
Pinnacle Aviation
Last Login: 5/17/2013
Status: offline
Hi guys I just got the model on the work bench and then compressed the nose leg and then is over 1" (25mm) clearance and I mean over.
Anyway here are some photos of the weather of the top after it has been clear coated and a couple with its workshop buddy.
Photobucket Pictures, Images and Photos
Phil Noel
Pinnacle Aviation (Professional model builder and painter)
Hide Signatures
(in reply to Pepperpete)
       Post #: 103
RE: Fly Eagle F-16 1:4.6 Advance, wow - 9/7/2012 12:30 PM
EagleJC
Last Login: 3/17/2013
Status: offline
Wow, I really love the work you done on this bird. Thanks for all information. I think I might think about to do the same too.
Nice job, Phil
James
FLY EAGLE JET/ US Distributor
Hide Signatures
(in reply to Pinnacle Aviation)
       Post #: 104
RE: Fly Eagle F-16 1:4.6 Advance, wow - 9/7/2012 3:48 PM
David Jackson
Status: offline
Wow, that MB 346 also looks great.
Hey James,
Any word from the factory regarding the Yak 130.
Hide Signatures
(in reply to EagleJC)
       Post #: 105
RE: Fly Eagle F-16 1:4.6 Advance, wow - 9/7/2012 6:03 PM
Pepperpete
Status: offline
James PM sent.
Hide Signatures
(in reply to David Jackson)
       Post #: 106
RE: Fly Eagle F-16 1:4.6 Advance, wow - 9/7/2012 6:48 PM
drdoom
Status: offline
Still waiting for a MD F-101 VooDoo.. any Chance for it in 7th scale
AMA #70046 Jet Junkie!
Without Gravity, Your Lockout Jet becomes Space Junk.
Hide Signatures
       Post #: 107
RE: Fly Eagle F-16 1:4.6 Advance, wow - 9/8/2012 3:40 AM
EagleJC
Status: offline
Hi Drdoom:
not sure about F101, but company is working on Gulfstream Jet this moment, the Vampire, after that should be Yak130 etc.
James
Hide Signatures
(in reply to drdoom)
       Post #: 108
RE: Fly Eagle F-16 1:4.6 Advance, wow - 9/9/2012 2:49 AM
EagleJC
Status: offline
Hi All:
as some people suggested nose wheel can be bigger, we made it now. See photo.
Ali, I will have one bigger nose wheel for you at Jet Power.
James
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 109
RE: Fly Eagle F-16 1:4.6 Advance, wow - 9/9/2012 6:38 AM
sskianpour
Status: offline
James,
How about that large Hawker Hunter? Is that still on the back burner for FEJ?
Shaz
Hide Signatures
       Post #: 110
RE: Fly Eagle F-16 1:4.6 Advance, wow - 9/9/2012 11:44 AM
Ali
Status: offline
That looks better. Thanks! I hope Phil can bring his weathering equipment... A brand new clean nose wheel might look at tad out of place
Regards Al
Al''''s Hobbies. Airworld. BVM, Tams, Jet Cat, AMT, Skymaster, FEJ, pull over, Tomahawk, Skygate, C-ARF, Jet-Teng,Kingtech
Hide Signatures
       Post #: 111
RE: Fly Eagle F-16 1:4.6 Advance, wow - 9/9/2012 2:05 PM
EagleJC
Status: offline
hi Shaz: I will check this one with company.
Ali, you can keep nose wheel as now, change it when you fly at grass field.
Phil: PM sent.
Hide Signatures
(in reply to Ali)
       Post #: 112
RE: Fly Eagle F-16 1:4.6 Advance, wow - 9/9/2012 2:08 PM
dubd
Status: online
Ali, just rub some dirt on it.
Hide Signatures
       Post #: 113
RE: Fly Eagle F-16 1:4.6 Advance, wow - 9/9/2012 3:03 PM
FalconWings
Status: online
quote:
ORIGINAL: EagleJC
Hi All:
James
James, not just the nose wheel. The mains need to be at least 33% larger to be close to scale. On the newer, heavier F-16's, there is even a bulge on the gear doors to accommodate the larger required wheel.
See the pic below so you can get an idea of the proportion.
David
Click for fullsize
Buying Jet Legend? Read here: http://www.rcuniverse.com/forum/m_11372496/mpage_1/key_/tm.htm
Hide Signatures
       Post #: 114
RE: Fly Eagle F-16 1:4.6 Advance, wow - 9/9/2012 4:23 PM
Pepperpete
Status: offline
quote:
ORIGINAL: FalconWings
quote:
ORIGINAL: EagleJC
Hi All:
James
David
It may be more accurate but it almost looks cartoony to me. I prefer the way it currently is on the FEJ except the larger nosewheel is an improvement.
Hide Signatures
(in reply to FalconWings)
       Post #: 115
RE: Fly Eagle F-16 1:4.6 Advance, wow - 9/9/2012 4:30 PM
FalconWings
Status: online
quote:
ORIGINAL: Pepperpete
quote:
ORIGINAL: EagleJC
Hi All:
James
David
The picture above is a normal wheel, not the oversized I was referencing.
I don't see a big deal as almost every other F16 kit has it right. Not cartoonish....more like real.
Hide Signatures
       Post #: 116
RE: Fly Eagle F-16 1:4.6 Advance, wow - 9/9/2012 5:06 PM
EagleJC
Status: offline
Falcon:
Thanks  for information. The main wheels work good on pave and grass field so far. So, I think company will stay same now. It still can be bigger a little by pumping some air into tire.
James
Hide Signatures
       Post #: 117
RE: Fly Eagle F-16 1:4.6 Advance, wow - 9/9/2012 5:19 PM
FalconWings
Status: online
quote:
ORIGINAL: EagleJC
Falcon:
James
Yeah I'm aware. I over pumped mine on my smaller F-16 yesterday and the gear door was becoming trapped! I need to deflate them some now.
Hide Signatures
       Post #: 118
RE: Fly Eagle F-16 1:4.6 Advance, wow - 9/9/2012 7:13 PM
FenderBean
Status: offline
So is the current tire not the correct scale? I doesnt matter care how it looks from pictures I prefer it be the correct scale not what works better for a grass field or looks better.
Kingtech 170F
Hide Signatures
       Post #: 119
RE: Fly Eagle F-16 1:4.6 Advance, wow - 9/9/2012 8:24 PM
smchale
Status: online
Assuming the scale is 1/4.6, then:
The mains should be 6" (27.75"/4.6) dia.
The nose should be 4" (18"/4.6) dia.
Sean McHale
"Strive for simplicity. You never have to repair what you leave out." - Bill Lear
Hide Signatures
(in reply to FenderBean)
       Post #: 120
RE: Fly Eagle F-16 1:4.6 Advance, wow - 9/17/2012 6:58 PM
tulz161
Status: offline
Ali - how are you liking it?
Money isn''''t everything... but everything makes me want it.
Hide Signatures
(in reply to smchale)
       Post #: 121
RE: Fly Eagle F-16 1:4.6 Advance, wow - 9/18/2012 8:19 AM
Ali
Status: offline
Still loving it, but having said that. I have not had a chance to fly it any more since the test flights I could not get it under the 25 Kg strict weight limit ( Full of fuel ) for the German shows. So no go at Jetpower.... Which is a real bummer as everyone worked their nuts off to get this model done in time.
I have a couple of lightweight high power output 160 can turbines ( Knocking out 180-190 newtons of thrust ) and am tempted to drop one of these in, but then I think that it flew perfectly at that weight, so not sure. I might just put it through the over 20 Kg scheme and fly it with lots of fuel and all the whistles and bells.
I will be sure to update this thread as I fly it more.
Regards Al
Hide Signatures
(in reply to tulz161)
       Post #: 122
RE: Fly Eagle F-16 1:4.6 Advance, wow - 9/30/2012 8:20 PM
David Jackson
Status: offline
What servos are being used on the flight surfaces?
Hide Signatures
(in reply to Ali)
       Post #: 123
RE: Fly Eagle F-16 1:4.6 Advance, wow - 10/29/2012 4:08 PM
EagleJC
Status: offline
Hi All:
as request main wheels to be bigger, we get the complete landing gear to be bigger now on F16 1/4.6 scale.
It will be 700-800g heavier than last one.
Gear is beefy and wheels are bigger too.
see a photo. I will make some good photos again sooner.
James
Click for fullsize
Hide Signatures
       Post #: 124
RE: Fly Eagle F-16 1:4.6 Advance, wow - 10/29/2012 4:34 PM
Ali
Status: offline
I have JR 8711's on all surfaces now. I started off with 8511's on the ailerons but these were not man enough and as the speed built the roll rate would reduce slightly. I am just waiting for the new gear and some repair work to the nose of my 16. I had a incident where the nose gear did not lock out on landing and on grass the pitot tube dug in and damaged the nose on the way back Gutted as I was really enjoying it and had just made the first flight with the smoke winders fitted. Oh well. I hope to be back up and flying in a few weeks. After flying the factory demo model whilst at BITW in California last week I think I may re engine mine to a Jet italia 190 turbine as its way lighter than the 200, as well as move the centre of gravity back a chunk. I thought mine flew well.. Till I flew the factory one, wow that felt so light on the sticks and solid at slow and high speeds.
Regards Al
Hide Signatures
       Post #: 125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.078RCU1
