RE: TF FW190 GIANT ARF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: TF FW190 GIANT ARF
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: TF FW190 GIANT ARF - 8/20/2012 11:13 PM
Ramstein44
Score: 110
Last Login: 6/20/2013
Status: offline
I don't think it'll matter being a radial setup with that large cowl. either way, the mufflers for both should be hidden inside the cowl. Unlike the Dora. I'm real curious about the Zenoah G62 with a cup mount and spring starter. Just because of the extra weight the Antons need.
_____________________________
Dont expect the best if you give the bare minimum.
Platt FW190, Holman FW190, Meister FW190, SIST FW190, TF FW190.
Hide Signatures
(in reply to dasintex)
       Post #: 76
RE: TF FW190 GIANT ARF - 8/20/2012 11:23 PM
dasintex
Score: 126
Status: offline
quote:
ORIGINAL: Ramstein44
Your probably right, I have the TF GS P-40 and it was modeled for the DLE55, I have this plane and engine and this combo is perfect; Considering both Top Flite and DLE are distributed by Great Planes, I'm thinking the FW190 would be modeled for the DLE, not sure which one, its possible its modeled for either, that is if the Engine mounting Bolt pattern is the same for either DLE Engine.
P-40 Brotherhood #3
Spitfire Brotherhood #29
Hide Signatures
(in reply to Ramstein44)
       Post #: 77
RE: TF FW190 GIANT ARF - 8/21/2012 12:29 AM
Ramstein44
Score: 110
Status: offline
I'm going to patiently wait to see what everyone does to theirs as the plane comes out and the forum turns into the build forum.
Hide Signatures
       Post #: 78
RE: TF FW190 GIANT ARF - 8/21/2012 2:14 AM
n8622t
Score: 101
Last Login: 6/19/2013
Status: offline
Pic of low pass shows tail gear is up
"Go low if you wanna make a show"
P-40 Brotherhood #49
Hide Signatures
(in reply to wulf190)
       Post #: 79
RE: TF FW190 GIANT ARF - 8/21/2012 2:39 AM
wulf190
Score: 105
Last Login: 6/15/2013
Status: offline
It looked to me like a zenoah would fit in there at the 7 o clock position as it does in the Holman. Nothing was exposed with the DLE with only the cutout for the exit pipes and plug boot. The t.w. retracts pretty much fully into the well and doesn't extend down very far....but this is pretty minor. It needs a nice set of scale wheels too, but the size looked pretty close, so that shouldn't be much trouble. I just found myself saying, man, a guy could really scale this thing out with cockpit and pilot and guns and a paint job and it could be incredible. I am interested to see what you all do with yours.
Hide Signatures
(in reply to n8622t)
       Post #: 80
RE: TF FW190 GIANT ARF - 8/21/2012 2:56 AM
Jeremy_D
Score: 100
Status: offline
Wulf,
Dd it have a 1 piece wing?
It looks like it is a decent size as well at that scale, fuse looks rather large
Global Jet Club Australia
www.aussiejet.com
Hide Signatures
       Post #: 81
RE: TF FW190 GIANT ARF - 8/21/2012 12:56 PM
wulf190
Score: 105
Status: offline
Sorry, I don't know about the 1 or 2 piece wing. I might have asked, but I was too busy eyeballing it I think. The outline is good I thought, and, believe me, I was looking for faults.
Hide Signatures
(in reply to Jeremy_D)
       Post #: 82
RE: TF FW190 GIANT ARF - 8/21/2012 2:51 PM
kahloq
Score: 125
Status: offline
quote:
ORIGINAL: paladin
kahloq, what motor/ battery combo though?
looks like electric could be expencive?
Joe
Rimfire 65cc depends on where you buy it.....I bought one for $219 for my ESM dora9. Retail is 279
castle hv2 160 esc ... depends on where....I got one for $209 off of ebay. Retail is 279
Turnigy nanotech 6s 6000mah at $74 each. Need two for a 12s setup...$150
$560 total for the power system.
For longer flights you could use two 8000mah 6s at $109 each.
You could use a turnigy dlux 160 esc which will run 12s for $120 which woul save $100, but im running the castle to be safe.
That rimfire can turn a 26x12 3 blade prop or you could run 22-24" 14 pitch prop. Ive got a 22x14 2 blade for my 65cc rimfire for the dora9
A rear exhaust DLE 55 at tower is $420.
In my case though, the 6s 6000 batteries are already used in my esm me-110 so arent exactly part of the total power plant cost for me.
Total cost for me is the same as a dle55 then.
Hide Signatures
(in reply to paladin)
       Post #: 83
RE: TF FW190 GIANT ARF - 8/21/2012 3:39 PM
cocobear
Score: 110
Last Login: 6/18/2013
Status: offline
1 piece wing. Optional 3 blade spinner should become available
DJ
Hide Signatures
(in reply to kahloq)
       Post #: 84
RE: TF FW190 GIANT ARF - 8/21/2012 3:43 PM
CashD
Score: 100
Last Login: 6/3/2013
Status: offline
Did anyone happen to ask if it would become available as an RTC (their term for ARC), like the mustang and P-47?
Hide Signatures
       Post #: 85
RE: TF FW190 GIANT ARF - 8/21/2012 3:44 PM
Ramstein44
Score: 110
Status: offline
Wulf was saying earlier to pressure them!
Hide Signatures
(in reply to CashD)
       Post #: 86
RE: TF FW190 GIANT ARF - 8/21/2012 5:54 PM
cocobear
Score: 110
Status: offline
http://www.youtube.com/watch?v=4KuH0nzXf4U
also
http://manuals.hobbico.com/top/topa0706-manual.pdf
Hide Signatures
       Post #: 87
RE: TF FW190 GIANT ARF - 8/21/2012 6:48 PM
tfarmer96
Score: 125
Status: offline
I think i can get a da 85 in this guy aswell. Man the hood guns dont look so snazzy ill have to fix that for sure.
Click to see fullsize image.
Click for fullsize
www.wyliewarbirds.com
Hide Signatures
(in reply to cocobear)
       Post #: 88
RE: TF FW190 GIANT ARF - 8/21/2012 7:07 PM
Ramstein44
Score: 110
Status: offline
quote:
ORIGINAL: cocobear
also
Well, that answers all my questions...
Hide Signatures
       Post #: 89
RE: TF FW190 GIANT ARF - 8/21/2012 10:12 PM
GerKonig
Score: 191
Status: offline
quote:
ORIGINAL: kahloq
quote:
ORIGINAL: paladin
Joe
That rimfire can turn a 26x12 3 blade prop or you could run 22-24'' 14 pitch prop. Ive got a 22x14 2 blade for my 65cc rimfire for the dora9
This puppy screams for an electric conversion... The 8000 pack might work well because it is a short nose 190, and it will need a lot of led to balance... The hatch has a perfect base for the packs that can extend all the way into the cowling, one on each side of the Rimfire...
A shame they did a one piece wing. Will be a pain to move around and in and out of the house. But, nobody is perfect:-)
Gerry
Hide Signatures
       Post #: 90
RE: TF FW190 GIANT ARF - 8/21/2012 10:56 PM
kahloq
Score: 125
Status: offline
My smaller esm 190A took a snot load of weight to balance as far forward as possible, so yup.....anything you can get up front will help more then likely.
Hide Signatures
(in reply to GerKonig)
       Post #: 91
RE: TF FW190 GIANT ARF - 8/22/2012 4:15 AM
n8622t
Score: 101
Status: offline
Ya I called them a week ago and rode em like a pony about a 3 blade spinner option
Jimmy
Hide Signatures
       Post #: 92
RE: TF FW190 GIANT ARF - 8/22/2012 4:46 AM
jeffk464
Score: 100
Last Login: 6/16/2013
Status: offline
Smart, its always easier to let someone else do the experimenting.
Hide Signatures
       Post #: 93
RE: TF FW190 GIANT ARF - 8/22/2012 4:49 AM
n8622t
Score: 101
Status: offline
Anyone know why the retractable tailwheel option is the Robart 160 mechanical??
Jimmy
Hide Signatures
       Post #: 94
RE: TF FW190 GIANT ARF - 8/22/2012 5:28 AM
n8622t
Score: 101
Status: offline
Ya Terry ....24x12 3blade on a DA85 will look great in front of that gun hood mod.
Jimmy
Hide Signatures
(in reply to tfarmer96)
       Post #: 95
RE: TF FW190 GIANT ARF - 8/22/2012 6:35 AM
kwik
Score: 105
Status: offline
Eery ARF has its faults. The only major one on this one, as far as I can see, is the V-shape of the wing.
It's too small.....
Hide Signatures
       Post #: 96
RE: TF FW190 GIANT ARF - 8/22/2012 8:00 AM
Chad Veich
Score: 275
Status: offline
quote:
ORIGINAL: kwik
It's too small.....
A chronic problem with Top Flite warbirds, lack of dihedral.
Hide Signatures
(in reply to kwik)
       Post #: 97
RE: TF FW190 GIANT ARF - 8/22/2012 11:26 AM
dasintex
Score: 126
Status: offline
quote:
ORIGINAL: n8622t
Jimmy
Could be a Tail Weight issue
P-40 Brotherhood #3
Hide Signatures
       Post #: 98
RE: TF FW190 GIANT ARF - 8/22/2012 11:57 AM
n8622t
Score: 101
Status: offline
quote:
ORIGINAL: dasintex
quote:
ORIGINAL: n8622t
Jimmy
I just wanted someone else to say it...nothing a DA85 can't cure
Jimmy
Hide Signatures
       Post #: 99
RE: TF FW190 GIANT ARF - 8/22/2012 12:43 PM
ForcesR
Score: 105
Last Login: 2/22/2013
Status: offline
quote:
ORIGINAL: n8622t
Jimmy
Yes, TF chose the mechanical retractable tailwheel to simulate the full scale retractable tailwheel, which did not fully retract into the wheel well. Using an electric or pneumatic retractable tail wheel allowed for full retraction of the tailwheel into the wheel well which would not be scale IAW full size FW-190.
Roger
Quote from the assembly manual.
RETRACTABLE LANDING GEAR
The Top Flite Giant Fw 190A-3 ARF has been designed
for Robart pneumatic and electric main gear retracts
and mechanical tail gear. The tail gear on the full size
Fw 190A-3 did not retract fully into the fuselage. To
obtain the scale retraction of the tail gear, a mechanical
retract was used.
❍ (1) Robart TFFW190 Top Flite Giant Fw 190
pneumatic retractable main landing gear
(ROBQ1658)
❍ (1) Robart TFFW190E Top Flite Giant Fw
190 electric retractable main landing gear
(ROBQ1657)
❍ (1) Robart #160 retractable tail gear assembly
(ROBQ2220)
❍ (1) Robart #157VRX Large-Scale Deluxe
Air Control Kit – includes pressure tank, air
line tubing, variable-rate air valve, T-fi ttings
< Message edited by ForcesR -- 8/22/2012 1:15 PM >
Hide Signatures
       Post #: 100
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.594RCU1
