RE: TF FW190 GIANT ARF    Gallery
Logged in as Guest
Users viewing this topic: Duplicator41, Triple G
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: TF FW190 GIANT ARF
Page: <<   < prev  7 8 [9] 10 11 12 13 14 15 16   next >   >>
Login
RE: TF FW190 GIANT ARF - 8/30/2012 4:52 PM
Ramstein44
Score: 110
Last Login: 5/24/2013
Status: offline
Glassing absolutely add weight but in doing so, it adds strength; the cost of the weight! As for having to do it just to change the paint scheme..... I think not!
< Message edited by Ramstein44 -- 8/30/2012 5:25 PM >
_____________________________
Dont expect the best if you give the bare minimum.
Platt FW190, Holman FW190, Meister FW190, SIST FW190, TF FW190.
Hide Signatures
(in reply to Ramstein44)
       Post #: 201
RE: TF FW190 GIANT ARF - 8/30/2012 5:04 PM
oliveDrab
Score: 105
Status: offline
quote:
ORIGINAL: vertical grimmace
quote:
ORIGINAL: oliveDrab
quote:
ORIGINAL: cocobear
Ramstein, why wait? The covering comes off pretty easily.
This is not the first time on RCU that I've read about buying an ARF then pulling the covering off to glass it then repaint. I don't understand it and always get a braincramp when I see it so maybe somebody can explain some things:
1. If you glass it, it's gonna be heavier right? Since I tend to go electric, extra weight is a concern.
2. Is Top Flite's flat Monokote covering job unattractive, poorly done?
3. Just a general question, why do this at all? I know why I would do it.........because building/recovering/painting is fun!!
-oD
A properly done glass and paint job will not be a lot heavier than the film. Maybe a little, but not enough to matter on a plane this size.
To me, I do not like the look of plastic coverings and they almost always start to sag, wrinkle and generally look like crap over time.
Then, a properly done paint job just looks so much better and is not that tough to do. Especially using latex paints. An aircraft of this size, with this much money invested, IMO deserves to be made to look good and last a long time.
These are the reasons I glass and paint.
Sagging and wrinkling are very, very bad. That right there is a great reason to glass and paint. Ok - I'm convinced.
"No, no, no........you misunderstand. We make nothing but model airplanes"
Hide Signatures
(in reply to vertical grimmace)
       Post #: 202
RE: TF FW190 GIANT ARF - 8/30/2012 7:30 PM
vertical grimmace
Score: 154
Status: offline
Also, when in the primer stage you can add panel lines and rivet detail if desired to really make the aircraft come alive. This will be even better if accented by airbrushing in the painting stage.
Here is a pic of my .60 sized Pica FW 190 D9. Home depot latex, Airbrushed panel lines layed into the primer. Whole plane fiberglased in .75 oz cloth. I think it looks a little better than monokote. The insignia were airbrushed using shelf paper as frisket. That was one of the coolest ricks I learned last year.
Click to see fullsize image.
Click for fullsize
< Message edited by vertical grimmace -- 8/30/2012 9:13 PM >
"let''''s just say, they will be satisfied with less" Ming the Merciless
Hide Signatures
(in reply to oliveDrab)
       Post #: 203
RE: TF FW190 GIANT ARF - 8/30/2012 8:05 PM
tfarmer96
Score: 125
Last Login: 5/17/2013
Status: offline
[/quote]
[/quote]
Yes this is the biggest reason for me. The Texas heat does a number on covering.
Spitfire Brotherhood #2
www.wyliewarbirds.com
Hide Signatures
       Post #: 204
RE: TF FW190 GIANT ARF - 8/30/2012 10:01 PM
wulf190
Score: 105
Status: offline
From what I saw this plane could add another 4 or 5lbs onto the all up weight with the DLE 55 on there and still be in great shape. Lots of 1/5 FW's out there pushing 30lbs and they all fly well, and this one seemed no different based on the power to weight ratio I saw. There's just so many color schemes and variants one could do if stripping it to glass and paint it that it would seem silly to limit ones options to only that which is provided in the monokote scheme, especially if this causes wrinkling of the covering in the heat of the blazing sun.
Hide Signatures
       Post #: 205
RE: TF FW190 GIANT ARF - 8/31/2012 12:20 AM
n8622t
Score: 101
Last Login: 5/20/2013
Status: offline
Glass will always give you the best finish if done properly and makes the model a lot more durable. I like to model so it wont bother me to strip the film off, however I like an everyday beater to fly as well, so the monokote is perfect...
"Go low if you wanna make a show"
P-40 Brotherhood #49
Hide Signatures
(in reply to wulf190)
       Post #: 206
RE: TF FW190 GIANT ARF - 8/31/2012 12:25 AM
n8622t
Score: 101
Status: offline
while we are waiting for the model to show up so we can get on with the fun part someone needs to post a pic of something cool they have in their hanger
Hide Signatures
(in reply to n8622t)
       Post #: 207
RE: TF FW190 GIANT ARF - 8/31/2012 12:33 AM
Ramstein44
Score: 110
Status: offline
I'm going to keep the first one simple... I'll dirty up the ARC..when it comes out.
Hide Signatures
       Post #: 208
RE: TF FW190 GIANT ARF - 8/31/2012 2:16 AM
tfarmer96
Score: 125
Status: offline
quote:
ORIGINAL: n8622t
Ok fine i like call this one the baby wulf. I got myself a cutter so i could cut my own paint masks. As you can see i have a set almost done for a buddy of mine that has a big 47 that should be close to paint here anyday
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by tfarmer96 -- 8/31/2012 2:45 AM >
Hide Signatures
       Post #: 209
RE: TF FW190 GIANT ARF - 8/31/2012 12:21 PM
tp777fo
Score: 103
Status: offline
Got my motor (DLE 55), got my gear, got my air system, got my servos...now whats missing?
Tom Perry
In Dog beers, I only had one!
Hide Signatures
(in reply to tfarmer96)
       Post #: 210
RE: TF FW190 GIANT ARF - 8/31/2012 1:55 PM
tfarmer96
Score: 125
Status: offline
quote:
ORIGINAL: tp777fo
+1
Hide Signatures
(in reply to tp777fo)
       Post #: 211
RE: TF FW190 GIANT ARF - 8/31/2012 2:01 PM
kgwomack
Score: 100
Last Login: 11/3/2012
Status: offline
Well, for what its worth. I will most likely get the TF FW190 as my next project to compliment Angels Playmate. I will pull the monocote off and glass and paint. Maybe 1/2 pound heavier. But that will not affect flight performance very much at all with the DLE55. I just want my own paint job. I don't want to be one of ten exact copies at a fly in. Adding detail and rivets does so much for a model. It gives personality.
Karl
Click for fullsize
There are only two types of planes, Fighters and Targets.
Hide Signatures
       Post #: 212
RE: TF FW190 GIANT ARF - 8/31/2012 4:34 PM
vertical grimmace
Score: 154
Status: offline
quote:
ORIGINAL: tfarmer96
quote:
ORIGINAL: n8622t
Where did you get that cutter? That would be a nice thing to have in the shop.
Hide Signatures
       Post #: 213
RE: TF FW190 GIANT ARF - 8/31/2012 4:48 PM
tfarmer96
Score: 125
Status: offline
quote:
ORIGINAL: tfarmer96
quote:
ORIGINAL: n8622t
Its a contour cutter from us cutters
Hide Signatures
       Post #: 214
RE: TF FW190 GIANT ARF - 8/31/2012 7:35 PM
n8622t
Score: 101
Status: offline
Terry that is a beautiful plane!!! Glad to see it will be on the flight line Can I have it
Hide Signatures
       Post #: 215
RE: TF FW190 GIANT ARF - 8/31/2012 7:37 PM
n8622t
Score: 101
Status: offline
quote:
ORIGINAL: tfarmer96
quote:
ORIGINAL: tp777fo
+1
Let me see.....Hmmmmmmmmm
Hide Signatures
       Post #: 216
RE: TF FW190 GIANT ARF - 8/31/2012 7:44 PM
n8622t
Score: 101
Status: offline
Here is a sample of what tfarmer96 can cut out for you ....yes it is paint
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 217
RE: TF FW190 GIANT ARF - 8/31/2012 7:46 PM
n8622t
Score: 101
Status: offline
He also molded the MG's on the hood
Click for fullsize
Hide Signatures
       Post #: 218
RE: TF FW190 GIANT ARF - 8/31/2012 7:51 PM
n8622t
Score: 101
Status: offline
If someone says you cant teach an old do new tricks they dont know too much....Ram44 taught me how to do this
Click for fullsize
Hide Signatures
       Post #: 219
RE: TF FW190 GIANT ARF - 8/31/2012 8:47 PM
jeffk464
Score: 100
Last Login: 5/23/2013
Status: offline
quote:
ORIGINAL: tfarmer96
quote:
ORIGINAL: n8622t
Looks like a nice size actually, what is it?
Hide Signatures
       Post #: 220
RE: TF FW190 GIANT ARF - 9/1/2012 12:31 AM
glazier808
Score: 291
Status: online
I believe that is Jose's(Fliteskin) old FW 190A7, if its his old plane, its the same size as the Sist.
Casey
< Message edited by glazier808 -- 9/1/2012 2:30 PM >
Fliteskin, Sierra, Nelson Hobby, MICKO aircraft, Getstencils, Holman Plans, VicRC, Castle Creations, Addicted to Luft
Hide Signatures
(in reply to jeffk464)
       Post #: 221
RE: TF FW190 GIANT ARF - 9/1/2012 12:40 AM
tfarmer96
Score: 125
Status: offline
quote:
ORIGINAL: glazier808
I believe that is Jose's(Fliteskin) old FW 190A7 Ifits his old plane, its the same size as the Sist
Casey
Ya but it seems the molds got messed up. i was going to get a second one but way it goes.
Hide Signatures
(in reply to glazier808)
       Post #: 222
RE: TF FW190 GIANT ARF - 9/1/2012 12:57 AM
glazier808
Score: 291
Status: online
I had not heard that! What happened?
Casey
Hide Signatures
       Post #: 223
RE: TF FW190 GIANT ARF - 9/1/2012 1:02 AM
tfarmer96
Score: 125
Status: offline
got me. alls i know is i think i got the only one on the planet but it flys great!
Hide Signatures
       Post #: 224
RE: TF FW190 GIANT ARF - 9/1/2012 6:20 AM
Hellcat716
Score: 116
Status: offline
Early October. Why not just say, early 2013?
Hide Signatures
       Post #: 225
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.672RCU1
