RE: TF FW190 GIANT ARF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
warbirds
Seller:  hi joe
Details:   $1,900.00   |  6/13/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: TF FW190 GIANT ARF
Page: <<   < prev  32 33 [34] 35 36 37 38 39 40 41   next >   >>
Login
RE: TF FW190 GIANT ARF - 1/4/2013 3:05 PM
SrTelemaster150
Score: 229
Last Login: 6/19/2013
Status: offline
I've been in a nursing home for the last 3 weeks recovering from a total knee replacement.
I spending most of my time gleaning everyting I can find on the full scale FW 190A & the TF 85" ARF.
I'm getting out today & will soon have the other knee done so I will be fully recovered by spring.
Starting to salt away some $$$ for this. I put in a lot of hours W/a Dynaflite PT-19 but this will be my 1st warbird. It looks like a good choice W/the wide landing gear & simple mechanics of same. I think I will be ready when I would be able to get this finished.
I'm planning on a Saito 450R3 running C&H CDI on methanol. Power output on CDI/methanol should be about 6HP. The fit will be tight (about 3/16" cowl clearance) but I think modifying the rocker covers by flattening the tops will give ample room. Since most DLE55 installations require a few #s nose ballast, the 6# saito Radial sould balance out W/O ballast by shifting battery packs.
I haven't decided on the retracts yet. I want to keep it as simple as possible & only have 6 channels on my radio. Pnuematics might be the way to go unless electrics can be operated W/a single channel.
The operation of the (rear) landing gear & servo/radio channel requirements for steering/retraction are my biggest concern right now.
I have a Hitec Optic 6 radio. The standard 4 channels for throttle/rudder aileron/rudder is simple enough & channel 6 will handle the flaps. The actuation of the mechanical tailwheel has me concerned. I assume that the seperate steering servo can just be controled W/the rudder channel via "Y" harness. The control of the retract servo for the tailwheel is my main concern. Can it be integrated W/either the pneumatic/electric mains on the same radio channel?
< Message edited by SrTelemaster150 -- 1/4/2013 5:03 PM >
_____________________________
Club Saito #785 - FA91S CDI, FA150 CDI, FA180 CDI, FA180HC CDI/BBC, FA200TI, FA300TTDP CDI
Hide Signatures
(in reply to SWORDSN)
       Post #: 826
RE: TF FW190 GIANT ARF - 1/4/2013 3:13 PM
MX240
Score: 115
Last Login: 6/15/2013
Status: offline
Well, the FW 190 is now on my work bench.
After building ARF Mustangs for myself and a couple other club members for years all I can say is "wow".
The level of completeness is amazing. Every hole is drilled for you. Lots of laser work on this one. The wing joiner fits like a glove.
I have always liked the 51 ARF's for this but, lets face it..... the TF P-51 is getting old since it was brought out. I started useing them eight years ago and they were around long before that. Don't get me wrong...I think they are still a great warbird to build/fly. All of the Top Flite models are good and i have been buying them since the 50's.
Yep, I found the tail wheel mounting in the box last night also. I thought it would be strange they didn't include one.
Going to use a DA 50 in mine and also see if I can move the servo's foreward a little also.
Hide Signatures
       Post #: 827
RE: TF FW190 GIANT ARF - 1/4/2013 3:22 PM
BobH
Score: 116
Status: offline
You dont need a spare servo for the tail wheel. If its pneumatic just "T" it off one of the main lines and it will work fine. If its electric I imagine you can use a "Y" harness and share a channe.
Good luck with your knee.
BobH.
Hide Signatures
(in reply to SrTelemaster150)
       Post #: 828
RE: TF FW190 GIANT ARF - 1/4/2013 5:01 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: BobH
You dont need a spare servo for the tail wheel. If its pneumatic just ''T'' it off one of the main lines and it will work fine. If its electric I imagine you can use a ''Y'' harness and share a channe.
That's what I thought.
I'm not new to R/C, but I've been away for some time.
I've never set up retracts though.
If I use a mechanical tailwheel retract like the plans, can I use a "Y" harnes to drive the TW servo off the same channel as the electric mains?
Being a (retired) journeyman pipefitter, pneumatics seem to be the most reliable option.
< Message edited by SrTelemaster150 -- 1/5/2013 4:34 AM >
Hide Signatures
(in reply to BobH)
       Post #: 829
RE: TF FW190 GIANT ARF - 1/4/2013 5:39 PM
Tommy_Gun
Score: 100
Last Login: 6/18/2013
Status: offline
Made a point of ordering my Giant 190 from RC Country as soon as I saw they were releasing it.
Have had it in the shop for a couple months now. I have a couple other projects to finish before I get to work on this beautiful beast.
Managed to save enough money before the tax hikes to order a Saito FG57T and and working to save money for the retracts.
If this plane has the same staying power as the TF FW190D9 I have in my shop, then I have many years ahead to enjoy this giant.
My D9 with a YS120 is still my favorite knockaround warbird. It always gets compliments for the silly stuff I do with it.
Can't wait to get this big Wurger in the air. And with the gas burning twin four stroke it will sound great and be affordable to fly!
It''s called "Warbird Racing".
So ask yourself, is that a warbird?
Hide Signatures
       Post #: 830
RE: TF FW190 GIANT ARF - 1/4/2013 6:40 PM
Hellcat716
Score: 116
Last Login: 6/10/2013
Status: offline
Yes you can run the whole gear off of one channel with a y harness.
Hide Signatures
       Post #: 831
RE: TF FW190 GIANT ARF - 1/4/2013 7:21 PM
Tom in Cincy
Score: 110
Status: offline
quote:
ORIGINAL: SrTelemaster150
I'm planning on a Saito 450R3 running C&H CDI on methanol. Power output on CDI/methanol should be about 6HP. The fit will be tight (about 3/16'' cowl clearance) but I think modifying the rocker covers by flattening the tops will give ample room. Since most DLE55 installations require a few #s nose ballast, the 6# saito Radial sould balance out W/O ballast by shifting battery packs.
Just got my 2nd Wolfee today. The first one was taken care of by the "United Package Smashers" (ups). Telemaster, I have a 450r to mount on it. As has been posted the cowl will fit but the wooden cowl ring/mount will need mods. I am planning on using a very old pair of robart retracts intended for a nosen P47 that I never built. Looks like a good fit with a minor mod to the wheel wells. I am interested in adding E/I to the 450r. Let me know If you do one..
"Nosen Cessna 310 Club #10"
Hide Signatures
       Post #: 832
RE: TF FW190 GIANT ARF - 1/4/2013 8:47 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: Tom in Cincy
All Of my Saitos have been or are being converted to CDI. More power, better fuel economy & better handling characteristics every time.
Only one left to convert is the NIB FA200Ti. I need a modified magnet hub ring from C&H to convert it. Already have the correct hall sensor/mount as well as the twin module. Hub ring is ten same OD/ID as FA180, but needs to be 1/2" OAL.
C&H is workiing on a 4 magnet, single hall sensor/module system like the Saito FG84. A CDI like that burning methanol will make the 450R3 live up to it's full potential
< Message edited by SrTelemaster150 -- 1/5/2013 12:26 AM >
Hide Signatures
(in reply to Tom in Cincy)
       Post #: 833
RE: TF FW190 GIANT ARF - 1/5/2013 2:31 AM
SU-31 flyer
Score: 100
Last Login: 6/17/2013
Status: offline
Just got mine today. What a big box. The DLE 50 RA engine and electric retracts are on back order. Will start after I finish the ME-262 I'm working on.
Hide Signatures
       Post #: 834
RE: TF FW190 GIANT ARF - 1/5/2013 2:43 AM
tfarmer96
Score: 125
Status: online
ok its done and dusted. if you dont do a bunch of tricked up stuff its a snap to put together. I just pulled it out of the box and did a few very small mods. 3 days is all you need on this bird from box to ready to fly
Click to see fullsize image.
Click for fullsize
Spitfire Brotherhood #2
www.wyliewarbirds.com
Hide Signatures
(in reply to SU-31 flyer)
       Post #: 835
RE: TF FW190 GIANT ARF - 1/5/2013 4:31 AM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: tfarmer96
I know you have posted all the info on here, but what kind of mods did you do?
Which retracts, etc?
I'm particularly interested in how you treated the tailwheel as well as the mains.
I want to use a 6-channel radio in mine so there will be no auxuiliary channels, just ailerons, elevator, throttle, rudder, gear & flaps, 1 channel each.
Except for stuffing a CDI/methanol Saito 450R3 into the cowl, my build will be straight forward & as simple as possible, especially the landing gear.
Hide Signatures
(in reply to tfarmer96)
       Post #: 836
RE: TF FW190 GIANT ARF - 1/5/2013 1:10 PM
SteveD-RCU
Score: 101
Status: offline
quote:
ORIGINAL: tfarmer96
I got a conversion kit for my Saito 300 from C&H,what are you adding to your methanol ,just oil? or oil and nitro? what ratios?
Steve Daly
MAAC #14007
Hide Signatures
       Post #: 837
RE: TF FW190 GIANT ARF - 1/5/2013 3:02 PM
BobH
Score: 116
Status: offline
I'd like to believe "more power" but I'm not convinced. I have had CH Ignition and yes the engine runs better and leaner. More power though? I could never tell the difference. If you have some before and after numbers I'd love to see them.
BobH.
Hide Signatures
       Post #: 838
RE: TF FW190 GIANT ARF - 1/5/2013 4:03 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: BobH
I'd like to believe ''more power'' but I'm not convinced. I have had CH Ignition and yes the engine runs better and leaner. More power though? I could never tell the difference. If you have some before and after numbers I'd love to see them.
By advancing the timing to take advantage of the Metanol fuel (34-36* BTDC) I have had typical RPM increaess of 200-300 RPM W/about 23% longer run times W/a given amount of fuel. (15% Cool Power)
The 28* BTDC settings are for gasoline. Methanol has a much slower burn so more ignition timing advance is beneficial.
One could eliminate the nitro thus lowering fuel cost W/O loosing (significant) power over the standard glow ignition/15% nitro. Mixing your own methanol/8% lube would be about 1/2 the cost of gasoline.
Furthermore: Higher nitro content will still achieve higher power output even W/CDI. My high compression FA180HC W/the BB 220 carb & ported 180 intake manifold made 3.4 HP W/15% Cool Power. Switching to 30% O'Donnel Speed Blend (8% lube) upped power to 3.94 HP. (8850 RPM W/a Dynathrust 18X8 prop)
Links to test results.
FA91S C&H Conversion
FA150 FA180 FA180HC HP Tests (CDI)
< Message edited by SrTelemaster150 -- 1/5/2013 5:30 PM >
Hide Signatures
(in reply to BobH)
       Post #: 839
RE: TF FW190 GIANT ARF - 1/5/2013 4:49 PM
BobH
Score: 116
Status: offline
Thank you for the explaination. I have a Saito 300 I may put on CH ignition and 15% to get just a lil more power.
BobH.
Hide Signatures
       Post #: 840
RE: TF FW190 GIANT ARF - 1/5/2013 5:27 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: BobH
LIKE THIS?
Hide Signatures
(in reply to BobH)
       Post #: 841
RE: TF FW190 GIANT ARF - 1/6/2013 7:02 PM
vertical grimmace
Score: 164
Status: online
For those using FW 190 Sierra retracts, do you feel it is necessary to change the aluminum downlinks to steel? If so, how do you go about acquiring them? Is this an item Sierra will have? I did not see them on the website.
"let''''s just say, they will be satisfied with less" Ming the Merciless
Hide Signatures
       Post #: 842
RE: TF FW190 GIANT ARF - 1/6/2013 7:05 PM
Ramstein44
Score: 110
Status: offline
I've been using the aluminum downlinks all this time with no problems. If you want to upgrade them, Possibly call Sierra and send yours in for an upgrade.
Dont expect the best if you give the bare minimum.
Platt FW190, Holman FW190, Meister FW190, SIST FW190, TF FW190.
Hide Signatures
(in reply to vertical grimmace)
       Post #: 843
RE: TF FW190 GIANT ARF - 1/6/2013 7:30 PM
Tommy_Gun
Score: 100
Status: offline
With regard to the retracts and especially the tailwheel retraction.
The full scale 190 had individual electric actuators for each main wheel with a cable on pulleys that was linked to the right main that worked to pull
the tailwheel into the up position.
Has anyone given any thought to reproducing this type of setup?
Seems as though using a mechanical retract on the tailwheel, lightly spring loaded to the down/lock position would make it possible to run a light
cable or kevlar thread thru some nyrod to accomplish this task.
Click for fullsize
Click for fullsize
< Message edited by Tommy_Gun -- 1/6/2013 9:15 PM >
Hide Signatures
(in reply to Ramstein44)
       Post #: 844
RE: TF FW190 GIANT ARF - 1/6/2013 8:23 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: Tommy_Gun
I think that a similar system is used W/an additional servo "Y" harness linked to the mains as the force used to pull the mechanical tailwheel retract up.
Right now, I'm thinking of using the Sierra pneumatic mains W/a separate servo "Y" harnessed into the retract circuit for the tailwheel. 1 servo for the pneumatic manis actuator valve, the other for the cable to the mechanical tailwheel.
I like the looks of the Sierras W/the downlinks better. One of the most visual striking things about the FW 190 si the angle of the mains from a frontal view & the lack of the downlinks will spoil that.
If I could modify the electric Robarts for a (cosmetic) downlink, that would be another, perhaps simpler solution.
Hide Signatures
(in reply to Tommy_Gun)
       Post #: 845
RE: TF FW190 GIANT ARF - 1/7/2013 2:22 AM
Hellcat716
Score: 116
Status: offline
Flew the maiden flight today. Absolutley great flying plane. The DLE 55 pulled the plane well even with the 27 1/2 lbs. The only negative was on the roll out the plane started to ground loop and could not keep it straight, so dragged a wingtip and clipped the prop. Very minor damage. Hope to get that straightened out next time. The landing was perfect, wheel landing. Beautiful sight in the air. Hope to get some pictures next flight.
Click for fullsize
Hide Signatures
       Post #: 846
RE: TF FW190 GIANT ARF - 1/7/2013 2:48 AM
tfarmer96
Score: 125
Status: online
quote:
ORIGINAL: Hellcat716
Well done sir. I had that issue with my SisT what i finally found was the pull pull wires were not tight enough. I here ya on the nose weight i got 2lbs and 15 oz. I wonder what servos they used. i use hs 5645 hitecs and i noticed it calls for 50 oz servos...could get by with resin gear servos.
Click for fullsize
Hide Signatures
(in reply to Hellcat716)
       Post #: 847
RE: TF FW190 GIANT ARF - 1/7/2013 5:51 AM
Ramstein44
Score: 110
Status: offline
Well, I think I have most of the lines on this in prep for the rivets. I still need to do some outline detailing and the cowl. I’m still considering engine accessibility options before I do the cowl. I want to do a hatch so I don’t have to remove the prop, spinner and so on.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 848
RE: TF FW190 GIANT ARF - 1/7/2013 6:18 AM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: Ramstein44
Perhaps SOMETHING LIKE THIS is what you have in mind?
Hide Signatures
       Post #: 849
RE: TF FW190 GIANT ARF - 1/7/2013 6:25 AM
Ramstein44
Score: 110
Status: offline
No, that is nice but I'm considering something more scale like Invertmast did on his holman Anton. Just engineering it.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 850
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.453RCU1
