RE: TF FW190 GIANT ARF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
ReDUCED Balsa USA Fokker DR-1 Triplane - 1/3 Scale - Kit
Seller:  JSZ
Details:   $1,500.00   |  6/6/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: TF FW190 GIANT ARF
Page: <<   < prev  34 35 [36] 37 38 39 40 41 42 43   next >   >>
Login
RE: TF FW190 GIANT ARF - 1/8/2013 4:19 PM
Fly4Real
Score: 106
Last Login: 6/18/2013
Status: offline
Best post EVER! Lol!
_____________________________
www.BestPilots.Typepad.com
Hide Signatures
(in reply to SrTelemaster150)
       Post #: 876
RE: TF FW190 GIANT ARF - 1/8/2013 4:58 PM
Ramstein44
Score: 110
Status: offline
Yeah.. I read that post while at my kids school and just broke out laughing...hilarious Needed it..
Dont expect the best if you give the bare minimum.
Platt FW190, Holman FW190, Meister FW190, SIST FW190, TF FW190.
Hide Signatures
(in reply to Fly4Real)
       Post #: 877
RE: TF FW190 GIANT ARF - 1/8/2013 5:18 PM
sharam
Score: 105
Status: online
quote:
Get your priorities straight!
Stop wasting money on frivelous things like groceries, gas. etc.
Buy several casse of Ramen noodles & get a bicycle so you can conserve your $$$$ for real neccessities like realistic R/C pilots.
Club Saito #785 - FA91S CDI, FA150 CDI, FA180 CDI, FA180HC CDI/BBC, FA200TI, FA300TTDP CDI
LOL, I got my Ramen noodle order in.  Gotta buy a bicycle now!
BTW, my FW-190 is almost finsihed.  DLE 55, Toysrus action hero figure which is a bit small, Robart electric retracts (driven off their own 2S 1600 Lipo), LiFe batteries.  I am dreading adding the extra weight to the front as folks are reporting!  I probably should have used the G-62 in this one similar to my P-47.  Hoping to maiden in a couple of weeks.
I am heading to the AMA convention this weekend in Southern California.
Trex 700 OS105 Vbar
Logo Xxtreme 800
Hide Signatures
       Post #: 878
RE: TF FW190 GIANT ARF - 1/8/2013 5:22 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: sharam
 I am dreading adding the extra weight to the front as folks are reporting!  I probably sould have used the G-62 in this one similar to my P-47.  Hoping to maiden in a couple of weeks.
I'm planning on 6.2# of Saito 450R3 for nose ballast! Add the battery pack for the C&H CDI on top of the motor box & there shouldn't be need for much need for added "ballast".
Hide Signatures
(in reply to sharam)
       Post #: 879
RE: TF FW190 GIANT ARF - 1/8/2013 8:23 PM
MX240
Score: 115
Last Login: 6/15/2013
Status: offline
I joined the wing this mornig and everything fits snug on this baby. Having joined a wing like this before don't put too much glue in the spar spot. I use Elmers white glue for this job and never had a wing fail on the Mustangs. Well, at that point anyways. Trees don't count. On this one, I cut some slots with my band saw in the end of the wing joiner to allow excess glue someplace to go just in case I get too much in their. I then use a "gell white glue" for the wing roots.
Now, to set her on her tail and get the DA 50 mounted before the tail feathers go on.
This is the easiest GS ARF I have ever put together. Well worth the price I think? Mounting the gear strut doors is simple on this one. I usually have to spend hours doing that.
I have used most of the hardware that came in the box but, still like my #2X3/8 button head screws for the wing servo doors.
Jim
Hide Signatures
       Post #: 880
RE: TF FW190 GIANT ARF - 1/8/2013 8:34 PM
MX240
Score: 115
Status: offline
Yes, Sr Tele,,
I have a Saito 5-cylinder in a big bi-plane but it is just too expensive of a motor to put in a plane like this, the way I am going to use it this summer.
I only fly the Bi-plane at special fun flys a couple times a year. Plus filling the 32oz tank with glow fuel for a 15 min flight makes me think too.
I think your 450 R3 would be a lot better.
Hide Signatures
       Post #: 881
RE: TF FW190 GIANT ARF - 1/9/2013 2:28 AM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: SrTelemaster150
I haven't decided on the retracts yet. I want to keep it as simple as possible & only have 6 channels on my radio. Pnuematics might be the way to go unless electrics can be operated W/a single channel.
The operation of the (rear) landing gear & servo/radio channel requirements for steering/retraction are my biggest concern right now.
I have a Hitec Optic 6 radio. The standard 4 channels for throttle/rudder aileron/rudder is simple enough & channel 6 will handle the flaps. The actuation of the mechanical tailwheel has me concerned. I assume that the seperate steering servo can just be controled W/the rudder channel via ''Y'' harness. The control of the retract servo for the tailwheel is my main concern. Can it be integrated W/either the pneumatic/electric mains on the same radio channel?
OK, I've done some digging, including some calls to Robart & I got the answers to my questions about the actuation of the tailwheel retracts above.
I have posted my finding on ROBART ELECTRIC MAINGEAR & TAILWHEEL RETRACTS & posted them on another thread.
Hide Signatures
       Post #: 882
RE: TF FW190 GIANT ARF - 1/9/2013 2:32 AM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: MX240
I joined the wing this mornig and everything fits snug on this baby. Having joined a wing like this before don't put too much glue in the spar spot. I use Elmers white glue for this job and never had a wing fail on the Mustangs. Well, at that point anyways. Trees don't count. On this one, I cut some slots with my band saw in the end of the wing joiner to allow excess glue someplace to go just in case I get too much in their. I then use a ''gell white glue'' for the wing roots.
Jim
The 450R3 will make about 6HP on CDI/methanol. That's quite a bit more than the 325R5. If you watch, the 450R3 can be had for about $1350 shipped during certain times of the year from a particular retailer. That puts the price much lower than the 325R5 too.
Hide Signatures
(in reply to MX240)
       Post #: 883
RE: TF FW190 GIANT ARF - 1/9/2013 4:38 AM
n8622t
Score: 101
Last Login: 6/12/2013
Status: offline
Beautiful job on the cowl Ram as well as everything else you have done....major contributions to the thread . I've been busy trying to finish another model before starting the 190 but will add that tfarmer96 paint masks are fantastic. I have been using them my current build and will be getting more for the 190. Anyone needing masks should definitely go to tfarmer96 for the masks they might need....nice job to you Terry
"Go low if you wanna make a show"
P-40 Brotherhood #49
Hide Signatures
(in reply to Ramstein44)
       Post #: 884
RE: TF FW190 GIANT ARF - 1/9/2013 4:58 AM
Ramstein44
Score: 110
Status: offline
Thanks my friend. I've enjoyed making the changes; it gives me something to do while the weather worsens. I'm still considering our conversation. Maybe making this version would be challenging..Either way, my next will be it. It'll go a lot faster now that I've done the dirty work once.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to n8622t)
       Post #: 885
RE: TF FW190 GIANT ARF - 1/9/2013 5:05 AM
okie52
Score: 100
Last Login: 3/20/2013
Status: offline
quote:
ORIGINAL: dasintex
quote:
ORIGINAL: okie52
Pardon my ignorance but what is CDI?
CDI: Capacitor Discharge Ignition, gives the Spark Plug the Spark!
Hide Signatures
(in reply to dasintex)
       Post #: 886
RE: TF FW190 GIANT ARF - 1/9/2013 9:09 AM
bladebender
Score: 100
Last Login: 6/16/2013
Status: offline
Mr. Pettit I see if you look over your first picture of your pilot you see that the front of the fuse the covering is mesed up and so are the vents. I was going to ask tower about that, mine is the same way
Hide Signatures
       Post #: 887
RE: TF FW190 GIANT ARF - 1/9/2013 2:34 PM
MX240
Score: 115
Status: offline
Geese, another good reason why I would never be a hobby shop dealer.
It's called get your iron out and your little touch-up paint brush man.
Hide Signatures
(in reply to bladebender)
       Post #: 888
RE: TF FW190 GIANT ARF - 1/9/2013 4:04 PM
Ramstein44
Score: 110
Status: offline
Hide Signatures
(in reply to MX240)
       Post #: 889
RE: TF FW190 GIANT ARF - 1/9/2013 4:28 PM
pettit
Score: 125
Last Login: 6/13/2013
Status: offline
Yes, once I get to working on the fuselage, out comes the covering iron and some touch-up paint (AKA "weathering") and it should look OK.
Right now I'm installing aileron and flap servos, making up linkages and preparing to join the wing panels.  Retracts are already installed.
This weekend, weather permitting, the DLE 55 will be run on my test stand to put some time on it, set carb needles and see how it runs in general.
The electric tail wheel retract unit WILL NOT FIT without major surgery on the rear of the fuselage.  I just received the manual teil gear retract and that one jiust about fits.  It'll be actuated by a separate servo mixed with the retract channel, and adjusted to only retract with the wheel half way pulled up.
Dick Pettit
WACO Brotherhood #168
If You Can Not Stand Behind Our Troops, please Feel Free To Stand In Front Of Them!!!!!
Hide Signatures
       Post #: 890
RE: TF FW190 GIANT ARF - 1/9/2013 6:02 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: pettit
The electric tail wheel I cited is the exact same mechanism as the mechanical TW. The only difference is the small jackscrew that is mounted on the forward surface of the TW mount bracket. The jackscrew would occupy the same area as the pushrod that would go forward to the servo mounted in the wing saddle.
Are we speaking of the same part#? I looked in the TF FW 190 GS manual & the opening for the pushrod looks ample to clear the jackscrew. Unless there is not room to swing the assembly into place, I fail to see why "major surgury" would be required.
What makes this option attractive to me is the sequencing of the TW retract from the main retract electronic control board. The scale-like speed of the jackscrew retract action is also a big plus.
Worst case scenerio is to remove the jackscrew & mount it forward where the servo would be located. the same pushrod that would connect the servo/TW could be used as a mechanical connection between the jackscrew/TW.
Once the cost of the additional servo is subtracted from the set-up, the added cost of the jackscrew/TW assembly would be down to less than $50. Having the sequencing VIA the electronic control board as well as the more scale like retract speed would be worth it to me.
Adding some sort of speed control to the servo set-up would further reduce the cost difference.
I talked to Robart, & the control board can not be used to control a servo.
Hide Signatures
(in reply to pettit)
       Post #: 891
RE: TF FW190 GIANT ARF - 1/9/2013 6:34 PM
pettit
Score: 125
Status: offline
SrTelemaster:  There isn't room to get the jackscrew motor into the fuselage due to it's length.  Maybe relocating it forward might work.
Even installing the mechanical tailwheel unit requires "some hammering" according the the review in this month's Model Aviation review article.
Dick Pettit
Hide Signatures
       Post #: 892
RE: TF FW190 GIANT ARF - 1/9/2013 7:04 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: pettit
Even installing the mechanical tailwheel unit requires ''some hammering'' according the the review in this month's Model Aviation review article.
OK, looks like relocating the jackscrew is the only option. I don't see any big engineering problems W/that. A small piece of sheet aluminum screwed to same hardwood crossmembers should do the trick. It will take about 2 1/2 oz off the tail anyway (compared to having the jackscrew mounted directly to the TW) even though some of that will be offset by the cable/clevis. It will have about the same weight distribution OA as the servo set-up.
If one goes the servo route, what can be done to control the speed of the retraction & what would be the cost? Sequencing would be nice, but speed control is a very important feature.
If I can get the electric retract system for say $50 more than a mech retract/servo/speed control set-up I would probably opt for the added bonus of utilizing the control board to actuate the TW & having the slow retract speed & sequencing.
Hide Signatures
       Post #: 893
RE: TF FW190 GIANT ARF - 1/9/2013 7:07 PM
pettit
Score: 125
Status: offline
Some high $$$ transmitters have a "slow down" feature and McDaniel R/C makes something called a "Go-Slow" that slows down a servo
Dick Pettit
Hide Signatures
       Post #: 894
RE: TF FW190 GIANT ARF - 1/9/2013 8:42 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: pettit
Some high $$$ transmitters have a ''slow down'' feature and McDaniel R/C makes something called a ''Go-Slow'' that slows down a servo
Well, the high $$$$ transmitter is out of the question as I am using a Hitec Optima-6 TX. Besides, that would probably conflict W/the electric jackscrew mains/servo TW set-up.
The "Go Slow" is $39.95.
By the time I purchase the mechanical TW, a servo & the Go Slow, I'll have almost as much in as the jackscrew actuated TW.
Looks like remote location of the jackscrew in the wing saddle is the best option for me.
Hide Signatures
       Post #: 895
RE: TF FW190 GIANT ARF - 1/9/2013 9:40 PM
SWORDSN
Score: 100
Status: offline
Who makes the gell white glue and what are the advantages
Hide Signatures
(in reply to MX240)
       Post #: 896
RE: TF FW190 GIANT ARF - 1/9/2013 10:53 PM
MX240
Score: 115
Status: offline
Like the name implies it is a "Gel". Nice to use on wing roots that is exposed till you can get the wing slid together.
Made by Elmers glue. I hate having to have a roll of paper towels trying to find all the runs from the regular white glues.
Jim
Hide Signatures
(in reply to SWORDSN)
       Post #: 897
RE: TF FW190 GIANT ARF - 1/10/2013 11:49 AM
pettit
Score: 125
Status: offline
Here are some photos of the Robart electric tail wheel attempting to fit into the opening in the fuselage, the rough modifications to the opening to get the mechanical tail wheel ito fit and the completed installation, minus the screws and linkages.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Dick Pettit
Hide Signatures
(in reply to MX240)
       Post #: 898
RE: TF FW190 GIANT ARF - 1/10/2013 1:30 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: pettit
Thanks. From what I could see, removing the jackscrew & mounting it forward should be an easy task to accomplish.
Hide Signatures
       Post #: 899
RE: TF FW190 GIANT ARF - 1/10/2013 2:05 PM
hellcat56
Score: 101
Status: offline
ramsites 44
is the plane on post 885 your plane?
WOW
Hide Signatures
       Post #: 900
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.344RCU1
