RE: TF FW190 GIANT ARF    Gallery
Logged in as Guest
Users viewing this topic: BJ64
    Search This Thread
Printable Version
Scale Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  5/1/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: TF FW190 GIANT ARF
Page: <<   < prev  38 39 [40] 41 42 43 44 45 46 47   next >   >>
Login
RE: TF FW190 GIANT ARF - 1/18/2013 10:07 PM
SrTelemaster150
Score: 229
Last Login: 5/21/2013
Status: offline
quote:
ORIGINAL: Ramstein44
I agree with you..I called Tower about you situation and they stated that; all they're going to do is place the item when shipped back in the scratch and dent depending. I think you have room for negotiations here. Save you and them some money depending on how you work it.
But if it were me, I'd just fix it and walk away as it's not that bad.. Somtime it's not worth the stress and you could do worse with the next...
So, would they sell it as a "scratch & dent" @ a reduced cost.
OP sould be able to get some sort of refund.
_____________________________
Club Saito #785 - FA91S CDI, FA150 CDI, FA180 CDI, FA180HC CDI/BBC, FA200TI, FA300TTDP CDI
Hide Signatures
(in reply to Ramstein44)
       Post #: 976
RE: TF FW190 GIANT ARF - 1/18/2013 10:26 PM
Ramstein44
Score: 110
Status: offline
I assumed that " scratch and dent" would be cheaper then a undamaged item. Maybe they can sell it him at that cost and refund the difference if that's what he's willing to do. Something Tony will have to negotiate.
Dont expect the best if you give the bare minimum.
Platt FW190, Holman FW190, Meister FW190, SIST FW190, TF FW190.
Hide Signatures
(in reply to SrTelemaster150)
       Post #: 977
RE: TF FW190 GIANT ARF - 1/18/2013 10:44 PM
MX240
Score: 115
Status: offline
O'ya I agree with Tony on a $700 ARF. But, that is what it is....A ARF! Not a complete ready to fly plane where no work is required. Some assembly & I guess repairs required. About six years ago on one of my TF Mustangs the UPS man drove in my driveway and told me we had a problem as he knew I built model airplanes. He drug out this Top Flite box that someone had run a fork lift fork clear through. He waited till I opened the box to look inside before sending it back through the system. Would you believe the fork went under the rear of the fusalage and over the top of the wings and never hurt a thing.
So I guess if I get something through the mail system that I can work with, I keep it rather then take a chance I would get something worse. Most of my stuff comes through Tower and they have treated me very well.
I think most of us on this thread have been in the hobby a long time and have started with the 3"X36" balsa wood to make something that flys so, this ARF stuff is pretty good to deal with fixing.
Sr. Telemaster. Sorry I don't have a retract tail wheel on my 190 but something bothers me more then that and it is those big as- ugly black control horns we screw with wood screws to our ele & Rudder. Some day I will srip the plastic covering off a ARF and bury all that stuff in the surface and THEN I will feel like spending the extra money making her pretty.
Jim
Hide Signatures
       Post #: 978
RE: TF FW190 GIANT ARF - 1/18/2013 11:16 PM
Ramstein44
Score: 110
Status: offline
I always considered and 'ARF" to be a plane where the basic physical construction was done and completed for you.. No major gluing or assembly, "repairing" required other then the installation of your electronics, engine and the obvious. Anything needing "repairs" in my opinion would be considered.."defective" or damaged goods. I don't recall seeing anywhere in the instruction where it stated " some assembly or repairing required"...
When we get to that stage.. I'll just stick with kits!!
Hide Signatures
(in reply to MX240)
       Post #: 979
RE: TF FW190 GIANT ARF - 1/18/2013 11:19 PM
sweetpea01
Score: 103
Last Login: 2/28/2013
Status: offline
ARF does not equal Repair! Assembly and maybe some sanding to get parts to fit correctly due to tight tolerances, but Repair of a broken, damaged or crappy painted item should be replaced....NO Questions Asked!
www.hobbiesxtreme.com
Hide Signatures
       Post #: 980
RE: TF FW190 GIANT ARF - 1/18/2013 11:46 PM
dasintex
Score: 126
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: MX240
I agree about those Big Ugly Black Control Horns, I solved this problem, or at least improved the appearance of control Horns, I use the ones Robart Retracts sells, they are gray, usually match the underside of a lot of warbirds, and if not they can be painted to match the covering, I have done this on all my Warbirds with great results.
Click to see fullsize image.
Click for fullsize
Click for fullsize
P-40 Brotherhood #3
Spitfire Brotherhood #29
Hide Signatures
(in reply to MX240)
       Post #: 981
RE: TF FW190 GIANT ARF - 1/18/2013 11:48 PM
Ramstein44
Score: 110
Status: offline
quote:
ORIGINAL: dasintex
quote:
ORIGINAL: MX240
Nothing a little paint can't fix..
Hide Signatures
(in reply to dasintex)
       Post #: 982
RE: TF FW190 GIANT ARF - 1/19/2013 12:06 AM
GO4IT
Score: 100
Status: offline
Does anyone have a lead on a custom wing bag?
Joe
CA YAK 55 / ZDZ100
Hide Signatures
       Post #: 983
RE: TF FW190 GIANT ARF - 1/19/2013 12:21 AM
Tony Gag Jr.
Score: 100
Last Login: 5/11/2013
Status: offline
I am fine doing work on an ARF but I don't think I should be fixing something that was already fixed poorly. Maybe I will call them tomorrow and see if I can work something out with them. I have been dealing with Tower for 20+ years and they have always been fantastic.
Tony
Hide Signatures
(in reply to GO4IT)
       Post #: 984
RE: TF FW190 GIANT ARF - 1/19/2013 1:23 AM
dasintex
Score: 126
Status: offline
quote:
ORIGINAL: GO4IT
I bought a Great Wing Bag from www.hobby-pak.com that is made to fit the Top Flite GS Warbird One Piece Wings, I have 2, one for my TF Giant P-40 and one for my TF Giant P-51; the Model to get is 'WBS04; measures 88" Long X 24" Wide; $79.99 http://www.hobby-pak.com/indexmain.htm
Click for fullsize
P-40 Brotherhood #3
Hide Signatures
(in reply to GO4IT)
       Post #: 985
RE: TF FW190 GIANT ARF - 1/19/2013 11:38 PM
SWORDSN
Score: 100
Status: offline
quote:
ORIGINAL: dasintex
quote:
ORIGINAL: MX240
A friend painted the black ones and they look good
Hide Signatures
       Post #: 986
RE: TF FW190 GIANT ARF - 1/20/2013 2:09 AM
GO4IT
Score: 100
Status: offline
dasintex: Thank you.
Joe
CA YAK 55 / ZDZ100
Hide Signatures
       Post #: 987
RE: TF FW190 GIANT ARF - 1/21/2013 2:43 AM
sharam
Score: 105
Status: offline
Does any one know where I can get a nice slab of lead around 36 ozs?  I am not going to stick on these tiny 1/4 oz weights one by one!!  Thanks.
Trex 700 OS105 Vbar
Logo Xxtreme 800
Hide Signatures
(in reply to GO4IT)
       Post #: 988
RE: TF FW190 GIANT ARF - 1/21/2013 2:58 AM
Ramstein44
Score: 110
Status: offline
Why not build a box and slap some shotgun buckshot or BB's in it with epoxy? Some simple walmart BB's are what I use. The cool thing about this method is that, no one knows that's a weight and the box becomes usable space.
Here is a pic of one I did for one of the Doras. Just over the muffler it can be seen.
Click for fullsize
Hide Signatures
(in reply to sharam)
       Post #: 989
RE: TF FW190 GIANT ARF - 1/21/2013 3:22 AM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: sharam
If there is someplace near you that does stained glass, you can get the scrap pieces of came.
Hide Signatures
       Post #: 990
RE: TF FW190 GIANT ARF - 1/21/2013 3:51 AM
Tom in Cincy
Score: 110
Status: offline
30oz for $!0 Harbor Fright http://www.harborfreight.com/1-2-half-oz-wheel-weights-67226.html
"Nosen Cessna 310 Club #10"
Hide Signatures
       Post #: 991
RE: TF FW190 GIANT ARF - 1/21/2013 4:15 AM
n8622t
Score: 101
Status: offline
No cracks here
"Go low if you wanna make a show"
P-40 Brotherhood #49
Hide Signatures
       Post #: 992
RE: TF FW190 GIANT ARF - 1/21/2013 5:14 AM
sharam
Score: 105
Status: offline
Thanks for the great ideas, guys!
Ram, right under the engine - great idea.  I have these round 6 oz fishing weights that I can glue into the box.
Thanks!
Trex 700 OS105 Vbar
Logo Xxtreme 800
Hide Signatures
(in reply to n8622t)
       Post #: 993
RE: TF FW190 GIANT ARF - 1/21/2013 6:14 AM
SU-31 flyer
Score: 100
Status: offline
Sharam I get weights from our tire store and melt them down as I need them. Some times they give me the old ones even though they can sell them back. Sometimes I just use them the way they are as they come in all weights.
Hide Signatures
       Post #: 994
RE: TF FW190 GIANT ARF - 1/21/2013 11:06 AM
Lifer
Score: 148
Status: online
I go to the local tire store and grab a handful of used tire balancing weights. Make a mold out of aluminum foil, surround it with bricks and then melt the lead into it with a propane torch. I then bolt the mass to the engine box. Cheap, but effective.
Hide Signatures
(in reply to SU-31 flyer)
       Post #: 995
RE: TF FW190 GIANT ARF - 1/21/2013 1:04 PM
samparfitt
Score: 125
Status: offline
I'm sure you guys already know this but make sure you melt lead outside in a well ventilated space: also, always wash your hands after handling it and, especially, keep children away from lead.
Us old farts are already brain dead, so we're safe!
G. Samuel Parfitt
Hide Signatures
(in reply to Lifer)
       Post #: 996
RE: TF FW190 GIANT ARF - 1/21/2013 2:06 PM
SrTelemaster150
Score: 229
Status: offline
Oh yeh, I forgot about wheel weights.
Most tire shops discard the old weights so you might score some of those for free!
I am so used to seeking pure lead for muzzleloaing bullets I forgot about wheel weights.
Hide Signatures
(in reply to samparfitt)
       Post #: 997
RE: TF FW190 GIANT ARF - 1/21/2013 2:55 PM
pettit
Score: 125
Status: offline
I installed the 3 battery packs (2 for receiver and one for retracts) in the "pockets" behind the shutters that lots of folks find were broken.   Wrapped in foam they fit firmly in place.
First photo shows the weight box I made that holds the 14 ounces of lead shot and epoxy needed to balance the plane.
Second photo is me holding the plane on my fingertips and it balances fine with that 14 ounces of lead. (Sorry, timed photo, I was alone)
Photo 3 is sheet of screening glued to the cowl that I painted yellow and covers most of the engine cylinder.  It may look better in the air.
BTW, for you folks that are mounting the cowl, be sure to add some epoxy or CA to those 6 blind nuts in the fuselage.  I had 2 of then work free and the prongs were not bent.  It looked like they were just pushed into the wood by hand.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by pettit -- 1/21/2013 4:19 PM >
Dick Pettit
WACO Brotherhood #168
If You Can Not Stand Behind Our Troops, please Feel Free To Stand In Front Of Them!!!!!
Hide Signatures
       Post #: 998
RE: TF FW190 GIANT ARF - 1/21/2013 3:53 PM
sweetpea01
Score: 103
Status: offline
I like the lead box from the first pic.
Hide Signatures
(in reply to pettit)
       Post #: 999
RE: TF FW190 GIANT ARF - 1/21/2013 4:49 PM
sharam
Score: 105
Status: offline
That is where I am making my weight box as well.  The fishing weights will fit nicely in there!
Pettit, nice clean job you did on yours!  Thanks for the pic.  I am surprised you only need 12 ozs.  I am also using three batteries and I have put them where you did but I need 36 ounces.
Also, thanks for all the other great ideas.  Ask and yee shall receive should be the motto of this forum!
Trex 700 OS105 Vbar
Logo Xxtreme 800
Hide Signatures
       Post #: 1000
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.047RCU1
