Futura 1.9m control horn question    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AMT Netherlands Pegasus HP - RTF
Seller:  thunderbolt-RCU
Details:   $3,000.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Futura 1.9m control horn question
Page: [1]
Login
Futura 1.9m control horn question - 7/27/2012 6:23 AM
mun_iz
Score: 100
Last Login: 5/17/2013
Status: offline
Hi all,
Need some help. I am building the 1.9m version of the futura.
I noticed that the FRP control surface horns provided in the kit are only 0.95 mm thick. Is this sufficient as they really appear to be too thin?
Thanks.
Isaac
Hide Signatures
       Post #: 1
RE: Futura 1.9m control horn question - 7/28/2012 7:00 AM
tobba
Score: 100
Last Login: 5/21/2013
Status: offline
Just finishing at 1.9 Futura. No issue with the thickness / strength of the horns IMO. Double horn setup on all surfaces except for the flap.
I'm building a Tomahawk 1:3 Hawk which runs exactly the same setup - many Hawks flying around the world and never a word re a horn failure.
Make sure you have nice hysol fillets on all the glue points.
Good luck with your build.
Hide Signatures
(in reply to mun_iz)
       Post #: 2
RE: Futura 1.9m control horn question - 10/7/2012 1:49 PM
mun_iz
Score: 100
Status: offline
Hi all,
Another control horn question...
I was looking at the photo in Post #77 in http://www.rcuniverse.com/forum/m_10333400/mpage_4/key_/tm.htm
I noticed that there is a difference in the type of horns supplied with my kit and also their quantity.
Comparing to the photo in the link above, I seem to be short of 4 horns (top of first photo) but have 2 extra larger horns (bottom of first photo).
Can someone advise on the following?
1) do I use the larger horn or the smaller horn for the flap? The manual shows both are usable... I think.
2) Using provided flap clevis, the gap of the clevis is much wider than the thickness of the flap horn (photo #2 & 3)... is this acceptable??I would think that the horn would be able slide on the clevis pin because of this. Will this result in slop in the flap?
Thanks.
Isaac
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to tobba)
       Post #: 3
RE: Futura 1.9m control horn question - 10/7/2012 1:52 PM
mun_iz
Score: 100
Status: offline
These 2 photos are from the softcopy of the build photos (manual) that I have.
But which horn should I use? Both are of the same thickness and which are far smaller than the gap of the flap clevis.
Thanks.
Isaac
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 4
RE: Futura 1.9m control horn question - 10/7/2012 4:01 PM
schroedm
Score: 103
Status: offline
The flap horn should have the ball link attached to it as per the manual photo you have posted. The other large metal clevis is usually used on metal servo arms, not at the control surface end.
Rgds
Mark
Hide Signatures
       Post #: 5
RE: Futura 1.9m control horn question - 10/7/2012 4:05 PM
mun_iz
Score: 100
Status: offline
Hi Mark,
Thanks... I had glued on the bigger horn... I had to cut it shorter in order for the horn to sit nicely into the flap.
Will be using a ball end as advised.
Isaac
Click for fullsize
Hide Signatures
(in reply to schroedm)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.547RCU1
