Landing gear bracing    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> Landing gear bracing
Page: [1]
Login
Landing gear bracing - 7/28/2012 9:12 PM
impulse09
Score: 100
Last Login: 6/18/2013
Status: offline
What is the best method to brace a standard two-piece set of main gear? I was thinking of some sort of rod running from the axle lock nut to a mounting bolt on the opposite side X2, like the red lines in the picture. Or maybe something with springs?
Click to see fullsize image.
Click for fullsize
_____________________________
Don S :)
Hide Signatures
       Post #: 1
RE: Landing gear bracing - 7/28/2012 10:20 PM
Campgems
Score: 143
Last Login: 6/13/2013
Status: offline
The stouter you make the landing gear, the more likely you are to rip out the landing gear mounting  from the fuselage on a hard landing.
Don
Hide Signatures
(in reply to impulse09)
       Post #: 2
RE: Landing gear bracing - 7/28/2012 10:38 PM
curtrc
Score: 100
Last Login: 1/30/2013
Status: offline
True as that may be, that isn't really a helpful response. I am interested in this too for my Pitts scratch-build. The gear is too springy and I am considering some wires.
Hide Signatures
(in reply to Campgems)
       Post #: 3
RE: Landing gear bracing - 7/28/2012 10:58 PM
impulse09
Score: 100
Status: offline
Stock gear is flexing due to the weight of the airframe.
Besides, I never have hard landings.
Don S :)
Hide Signatures
(in reply to curtrc)
       Post #: 4
RE: Landing gear bracing - 7/28/2012 11:27 PM
All Day Dan
Score: 156
Status: offline
impulse, another way is to get a landing gear made from thicker stock. Try these guys. Dan.
http://tntlandinggear.com/
Dan
Hide Signatures
       Post #: 5
RE: Landing gear bracing - 7/28/2012 11:33 PM
Boomerang1
Score: 120
Status: offline
Rigid bracing will snap in no time so you will need springs if you go that way.
I'd go with Dan's idea, new stiffer undercarriage, probably the quickest easiest, cheapest method. - John.
Distributor for: Nothing! So my posts can be unbiased.
Hide Signatures
(in reply to All Day Dan)
       Post #: 6
RE: Landing gear bracing - 7/28/2012 11:49 PM
Live Wire
Score: 6334
Status: offline
Like your drawing, Wire from wheel to wheel and from one mount bolt to the other with a rubberband or spring in the center like the J 3 CUB. It is more ridged ,but still has the bounce.
Larry K AMA 36417
Sig Kadet Brotherhood # 4 WACO Brotherhood #34 Cub Brotherhood 14
Hide Signatures
       Post #: 7
RE: Landing gear bracing - 7/28/2012 11:55 PM
impulse09
Score: 100
Status: offline
I see that TNT has the gear that I need, the only question I have is whether the gear is stronger or similar to the stock gear. Do they improve upon the stock gear, or just offer replacements?
Don S :)
Hide Signatures
       Post #: 8
RE: Landing gear bracing - 7/29/2012 1:26 AM
All Day Dan
Score: 156
Status: offline
impulse, I have ordered several custom gears from them and each one has been perfect. If the one they already have is made from thicker stock, then try it. If not, go to their custom order sheet and fill in the dimensions you need from the gear you have. Choose the next higher aluminum thickness than the one you have. It should be good enough. By the way, how much does you plane weigh? Dan.
Dan
Hide Signatures
       Post #: 9
RE: Landing gear bracing - 7/29/2012 2:18 AM
impulse09
Score: 100
Status: offline
15lbs dry.
Can TNT drill the gear out?
Don S :)
Hide Signatures
       Post #: 10
RE: Landing gear bracing - 7/29/2012 2:46 AM
All Day Dan
Score: 156
Status: offline
impulse, use 3/16 inch aluminum at that weight. I mount my wheels and sometimes wheel pants to the gear with 1/4 inch bolts and the gear to the plane with 1/4 inch nylon bolts. You can see them in the attached image. I have no problem drilling the 1/4 inch diameter holes required with a 1/4 inch drill in a drill press. Ask the nice lady that answers the phone at TNT if they would do it. Dan.
Click for fullsize
Dan
Hide Signatures
       Post #: 11
RE: Landing gear bracing - 7/29/2012 3:00 AM
impulse09
Score: 100
Status: offline
My stock gear is 1/8". I'll see how it holds up tomorrow.
Don S :)
Hide Signatures
       Post #: 12
RE: Landing gear bracing - 7/29/2012 9:28 AM
Rotten40851
Score: 110
Status: online
Why not take some flat stock aluminum straight across from strut to strut 1/3 up from the wheels. bend a 45 degree angle on each side drill it out and bolt it on.  I have done this on wire gear as well with a peice of 1/4 inch brass tubing flattened 1 inch on both sides, bent to match the angle of the gear and soldered on to the wire. It works very well.  HTH
Futaba 18 MZ... Nothing even comes Close!!!
Hide Signatures
       Post #: 13
RE: Landing gear bracing - 7/29/2012 10:56 AM
Lifer
Score: 153
Status: offline
Once you stiffen the gear, you might consider mounting with 1/4-20 nylon bolts, if you haven't done so already. Protect the structure just in case.
Hide Signatures
(in reply to Rotten40851)
       Post #: 14
RE: Landing gear bracing - 7/30/2012 2:28 AM
N1EDM
Score: 125
Status: offline
To add my ideas to the mix, take a look at a J-3 Cub gear. It's very similar to the diagram that you drew in Post #1. Just add some compliance (O-Rings, etc) and see what you have. An even simpler idea is from the Hangar 9 J-3 Cub 40 LG at:
http://www.horizonhobby.com/products/landing-gear-j-3-cub-40-HAN4005
It's not all that exotic but it does have some compliance just from the wire. For the record, that black cylinders are just plastic decoration to simulate the bungees.
Just adding my $.02
Bob
Club Saito #61 Cub Brotherhood #107
Spitfire Brotherhood #143
Hide Signatures
(in reply to Lifer)
       Post #: 15
RE: Landing gear bracing - 7/30/2012 3:08 AM
impulse09
Score: 100
Status: offline
I'll take all the cents I can get.
Don S :)
Hide Signatures
(in reply to N1EDM)
       Post #: 16
RE: Landing gear bracing - 7/30/2012 5:36 PM
FlyerInOKC
Score: 116
Status: offline
I have the Hobart Cub gear on my 1/5th Cub and they suspension works quite nice. You could use this gear as a guide and use "O" rings like Hobart does to provide the resistance.
My workbench where you always find the weird and unusual! Sig Kadet Brotherhood #89 Ryan STA/STM/SC Brotherhood # 27
Hide Signatures
       Post #: 17
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.438RCU1
