RE: glow plug thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: glow plug thread
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: glow plug thread - 7/30/2012 5:11 AM
BobbyMcGee
Score: 131
Last Login: 5/6/2013
Status: offline
quote:
ORIGINAL: dirtybird
In the latest MA they say the glow plug thread is 1/4x28. When did they change it?
You have got to be kidding me, right? I didn't know anyone still reads that magazine anymore!
I got tired of seeing the same articles re-hashed every 18 months.
_____________________________
Freedoms just another word for nothing left to lose. Nothing, dont mean nothing if it aint free!
Hide Signatures
(in reply to dirtybird)
       Post #: 26
RE: glow plug thread - 7/30/2012 5:32 AM  1 votes
countilaw
Score: 219
Last Login: 5/20/2013
Status: offline
I've been in the hobby for about  44 years.   I've seen alot,  learned alot,  and still learning.     I learn something new every time a read an issue of MA.    And anybody that says that they don't learn anything from it is either a    world class genius,  or  has not the ability to learn anything.
It''s a hobby, not a job.
Hide Signatures
(in reply to rcguy59)
       Post #: 27
RE: glow plug thread - 7/30/2012 2:59 PM
Live Wire
Score: 6329
Status: offline
65 yr's and +1
Larry K AMA 36417
Sig Kadet Brotherhood # 4 WACO Brotherhood #34 Cub Brotherhood 14
Hide Signatures
(in reply to countilaw)
       Post #: 28
RE: glow plug thread - 7/30/2012 4:14 PM
Hobbsy
Score: 650
Status: offline
http://www.microfasteners.com/catalog/products/TNMTAP.cfm
They are readily available here. It looks like they no longer carry the die. I have lots of their stuff.
A young man knows the rules and an old man knows the exceptions.
Club Saito member #5
Hide Signatures
(in reply to earlwb)
       Post #: 29
RE: glow plug thread - 7/30/2012 4:48 PM
earlwb
Score: 584
Status: offline
I like to peruse MA magazine. I have no problem with it. Granted I might not read it so much, but from time to time something catches my eye and I read it more closely. It makes for good reading material in the bathroom when you are using the throne.
Club Saito #722, Sig Kadet Brotherhood #80
AMA # 928076
Hide Signatures
(in reply to Hobbsy)
       Post #: 30
RE: glow plug thread - 7/30/2012 4:50 PM
Hobbsy
Score: 650
Status: offline
It has little to distract you from the real job
Hide Signatures
       Post #: 31
RE: glow plug thread - 7/30/2012 5:47 PM
crash1ace
Score: 105
Last Login: 5/17/2013
Status: offline
Wow, cant believe some people. To have such a dislike for the magazine. I find the articles both entertaining and helpful, and do like to keep up up current events. To say that one uses the mag
as a "cutting board" seems a lil bit much to me. Did someone have a bad experience with the magazine or something? I'm very glad to get it monthly and will continue to do so and support it 100%.
Hide Signatures
       Post #: 32
RE: glow plug thread - 7/30/2012 6:28 PM
Charlie P.
Score: 192
Status: online
GITS oil/grease fittings (not to be confused with 1/4-28 Zirk fittings), glow plugs and flintlock vent liners.  About the only things that use 1/4-32 threads.
Which brings us to . . .
http://www.trackofthewolf.com/Categories/PartDetail.aspx/0/1/TAP-1-4-32-P
A $13.99 tap from a muzzleloading gunsmith supplier.  Though if you've torn out the threads I'd recomemnd a Helicoil replacement.
Charlie P. (NY) "Gravity is weak but persistant".
AMA 747089/IMAA 30723
Hide Signatures
(in reply to crash1ace)
       Post #: 33
RE: glow plug thread - 7/30/2012 6:39 PM
Sport_Pilot
Score: 233
Last Login: 5/19/2013
Status: offline
Must be the same salesman that told me Metric would never last.  Also one never heard of numbered drill sizes.  Lots of stuff not found in Home Depot.
“I Saw Elvis at 1000 Feet” John Force
Hide Signatures
       Post #: 34
RE: glow plug thread - 7/30/2012 11:30 PM
blw
Score: 655
Status: offline
I knew a guy who used MA magazines for mixing epoxy. He just tore off the pages when done.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
"It doesn''t take but one Auburn man to be a majority" -
Coach Pat Dye
Hide Signatures
(in reply to Sport_Pilot)
       Post #: 35
RE: glow plug thread - 7/31/2012 12:33 AM
aspeed
Score: 105
Status: offline
Don't forget the Tee Dee .049 carb is 1/4" 32 UNEF (unified national Extra fine I think).  I am making all of my heads with the Turbo plugs now.  8mm x .75 . May as well get an extra 1000 rpm if you are going to the trouble of making a head.  The Nelson plugs are harder to find the tap and are a bigger diameter for the smaller motors. And to get off the topic, I wouldn't mind reading a MA mag again for a change.  I thought they were fairly good for the few I read.. They only print what is handed to them in most cases likely. If no one contributes then they get kind of dry.  (zone meetings and rule changes)  I read MA Canada and it is kind of similar.  We can contribute articles if we want, and they might get printed depending on things.
Hide Signatures
(in reply to blw)
       Post #: 36
RE: glow plug thread - 7/31/2012 3:15 AM
1QwkSport2.5r
Score: 155
Status: offline
quote:
ORIGINAL: Ernie Misner
Best thing I ever did was get a 1/4x32 die for cleaning up new plugs before installing. Apparently the plug's threads are just rolled and not precision cut from the factory. You would be amazed at all the shaving that come off of new plugs to make them right.
Ernie Misner
I have a Higley 1/4-32 tap but no die. The tap cost me $7. I haven't had any problems stripping threads with my McCoy plugs. Though your comment does inspire me to get a 1/4-32 die just to have one. My hobby shop has a Higley die for $14
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
(in reply to Ernie Misner)
       Post #: 37
RE: glow plug thread - 7/31/2012 3:45 AM
earlwb
Score: 584
Status: offline
quote:
ORIGINAL: aspeed
That isn't a bad idea using turbo plugs. The small 1/2a engines are quite sensitive to the slight compression loss from just the threads on a glow plug. So using a turbo plug that seals at the bottom does correct for that issue.
AMA # 928076
Hide Signatures
(in reply to aspeed)
       Post #: 38
RE: glow plug thread - 7/31/2012 7:47 AM
Ernie Misner
Score: 130
Status: offline
>>> Though your comment does inspire me to get a 1/4-32 die just to have one. My hobby shop has a Higley die for $14 >>>
Here's a little more poop then on why threads strip out of the head often. What happens is sometimes when we unscrew the plug, it has become welded to the aluminum in the head so the aluminum comes out with it. That happens because of poor fitting glow plug threads that cause little tight fitting spots. Then with a hot or lean run those tight spots become even tighter causing the bonding or welding of the plug and head together. Simply running new plugs into the die eliminites this from happening.
The local screw products store ordered my die for $9.00.
Ernie Misner
Hide Signatures
       Post #: 39
RE: glow plug thread - 7/31/2012 12:37 PM
qazimoto
Score: 100
Status: online
Ernie Misner
Actually the shavings coming off the plugs are most likely making them fit much worse in the head.
The worst case scenario is that after chasing them the plugs now seal at the copper washer under their head rather than at the first thread.
Not a good idea at all, and really the reason that bottom sealing plugs like the Turbo and the Nelson give about a 1000 rpm advantage over the stock standard threaded ones.
Yours will be much worse!.
Hide Signatures
       Post #: 40
RE: glow plug thread - 7/31/2012 12:49 PM
Hobbsy
Score: 650
Status: offline
I hava 1/4x32 die and tried it on a couple of plugs with cut threads, after running them in and out of the die they fit pretty loose, that made me nervous. Fox plugs have rolled threads and the first thrad is tapered, the die doesn't do much to a Fox plug.
Hide Signatures
(in reply to qazimoto)
       Post #: 41
RE: glow plug thread - 7/31/2012 2:36 PM
dirtybird
Score: 173
Status: offline
I like to keep MA beside my bed. When I wake up at night and can't go back to sleep I read it. It puts me to sleep.
Hide Signatures
       Post #: 42
RE: glow plug thread - 7/31/2012 2:59 PM
aspeed
Score: 105
Status: offline
I have noticed that the threads on one brand are sandblasted which made for a not so good seal. I had to tighten one to more than I was comfortable with to get a seal.  It would abrade away at the softer alum. threads after a while. Maybe some scotchbright carefully twisted on the threads might help polish the threads if you are careful to not touch the element. I use antiseize grease on the plug threads, or castor oil.  I also use the castor on the head gasket if I remember. I have never stripped one yet in 40 years.(yikes I'm old, I started as a little kid though) I wouldn't run a die on  the plug unless it doesn't want to go in.  The factories likely have cut the thread to the right tolerance.  You could check the size to the spec. with a proper size wire (best wire size  BWS) and figure the measurement over the wires(MOW), but I am sure they are likely good.  They should definately not be too loose because the rpm's will suffer. There are special micrometers made for checking the tread pitch dia. as well.
Hide Signatures
       Post #: 43
RE: glow plug thread - 8/1/2012 7:04 AM
Ernie Misner
Score: 130
Status: offline
My earlier post (below) was quoted pretty much word for word from Clarance Lee. His advise is usually right on. It was in an article about how to avoid stripping glow plug threads if you like to keep your engines around a long time.
Thanks, Ernie
Ernie Misner
Hide Signatures
       Post #: 44
RE: glow plug thread - 8/1/2012 8:42 AM
qazimoto
Score: 100
Status: online
Thanks, Ernie
Clarance who?
Hide Signatures
       Post #: 45
RE: glow plug thread - 8/1/2012 1:13 PM
BarracudaHockey
Score: 280
Status: offline
THE RC engine guru north of the equator. Kind of like your Brian Winch
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
       Post #: 46
RE: glow plug thread - 8/1/2012 1:24 PM
qazimoto
Score: 100
Status: online
quote:
ORIGINAL: BarracudaHockey
C. Lee can't be that bad!
My point was that "cleaning up" the threads on a conventional glowplug is going to lose rpm This is an accepted fact amongst those who treasure
every extra rev of the prop.
If your aim is to preserve the threads in you g;ow engine head then that is a different story.
This may have been important in an era before CNC manufacturing. These days both plug and head are made to exacting tolerances.
I just don't think it's important anymore.
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 47
RE: glow plug thread - 8/1/2012 1:48 PM
Four Stroker
Score: 104
Last Login: 3/28/2013
Status: offline
1) You guys that drop a 1000 rpm by cleaning up the threads should try using the copper washer that comes with the plug to seal it.
2) I just cleaned up 10 new "CNC" plugs because I broke a chip off of the last head thread.
3) C. Lee's advice is just as valid today.
Hide Signatures
       Post #: 48
RE: glow plug thread - 8/1/2012 2:02 PM
Sport_Pilot
Score: 233
Status: offline
The advantage of Nelson plugs has to do with detonation and pre ignition at high nitro precentages, because of the smoother surface and transition.  There will be little to no advantage on lower nitro engines, and no advantage due to fuel and air between the threads.  The copper washer is there for a reason.
Also the rolled threads are very precise and more desireable.  If your die is cutting substantial metal off it is because you tend to push the die into the thread.
Hide Signatures
(in reply to Four Stroker)
       Post #: 49
RE: glow plug thread - 8/1/2012 2:22 PM
fizzwater2
Score: 124
Status: offline
back when I dabbled a little (played at..) Formula 1 racing, we cleaned up the threads on the 1/4-32 glow plugs before we used them. Changing a plug every flight, the heads would wear out prematurely if you didn't.
I had an adjustable die that you could open or close slightly with a screw - it was set to just barely clean up the threads a little to reduce wear on the head.
No matter where you go, there you are!
Hide Signatures
       Post #: 50
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> RE: glow plug thread
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.547RCU1
