Tornado EPx loses power and/or stops    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> Tornado EPx loses power and/or stops
Page: [1]
Login
Tornado EPx loses power and/or stops - 7/29/2012 7:11 PM
davidgp
Score: 100
Last Login: 2/13/2013
Status: offline
My new stock Tornado loses power after about 5 minutes, Eventually it will get full power again for a few seconds, then lose power again. Sometimes it stops completely. Motor temp was 137, ESC was 105 , battery was 103 degrees. That seems ok to me but it acts like an overheat mode. I'm using a 3800 milliamp 7.4 lipo. Any ideas on what to do short of replacing the electronics?
david
Hide Signatures
       Post #: 1
RE: Tornado EPx loses power and/or stops - 7/29/2012 8:02 PM
nitrosportsandrunner
Score: 296
Last Login: 5/25/2013
Status: offline
quote:
ORIGINAL: davidgp
david
do you have the brushed, or the brushless version?
If its brushless, it sounds like its going into Low Voltage mode a bit early. If it is going into overheat protection, the ESC flashes red (if i remember correctly)
If its going into LVC as I suspect, charge your batt...run the buggy till it stops....then read the voltage of your battery. You wanna rule out that your lipo or charger isnt to blame. 103 is a bit high for a lipo IMO. Whats the "C" rating of that lipo?
_____________________________
Redcat Mirage Pro, Tornado EPX Pro, SC10, TTR Phoenix XB. Redcat Racing Dealer.
Hide Signatures
(in reply to davidgp)
       Post #: 2
RE: Tornado EPx loses power and/or stops - 7/30/2012 7:43 PM
davidgp
Score: 100
Status: offline
It happens with different batteries, so I suspect the ESC cutoff my be set too high, like for Niimh cells. I'll reset it and see what happens. Thanks for your info. It did help.
Hide Signatures
(in reply to nitrosportsandrunner)
       Post #: 3
RE: Tornado EPx loses power and/or stops - 7/30/2012 10:41 PM
NewRageRC
Score: 100
Last Login: 4/8/2013
Status: offline
Definitely what it sounds like to me.
Hide Signatures
       Post #: 4
RE: Tornado EPx loses power and/or stops - 7/31/2012 2:58 AM
Score: 296
Status: offline
if the "C" rating of your lipo is too low, then with 3800mah you may only see 5=8 minutes of runtime.
The C" rating should be at least 20c.
Hide Signatures
(in reply to NewRageRC)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.234RCU1
