Savex L39    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric RC Jets >> Savex L39
Page: [1]
Login
Savex L39 - 7/30/2012 7:50 PM
wop flyer
Last Login: 5/17/2013
Status: offline
Hi, I have just picked up a Savex L39. I have the Carbon Ducting, Schubeler DS-30-DIA HDT, Jeti Advance77 opto plus,
LMT TYP1940/12WDG Motor, all came with it. I am new to EDF Jets but it was a bargin, so i had to buy it. So can Anyone help me with the following.
What Servos to use, Lipos, I would like to put Electric Retracts on it.
I will be Greatfull of any help, Thanks
Hide Signatures
       Post #: 1
RE: Savex L39 - 7/31/2012 4:26 AM
speed is life
Last Login: 5/14/2013
Status: offline
Something does not add up with your description:
1) The Savex L-39 is a 90mm size model
2) the DS-30 is a 69mm fan
Either you have a DS-30 (which won't fit the airframe) or you mis-spoke and you really have a 90mm DS-51? I'd guess by your motor description that you have a DS-51
Use this fan calc to refine your choice of batteries and expected power:
http://www.s4a.ch/eflight/fancalc_e.htm
Suggestion; don't go cheap on servos, use at least metal gear and enough torque.
_____________________________
-Schuebeler Sales USA-
Hide Signatures
(in reply to wop flyer)
       Post #: 2
RE: Savex L39 - 7/31/2012 8:25 PM
wop flyer
Status: offline
Sorry looking at the wrong page on fan instructions. Have you any Specific Servos in mind?
Hide Signatures
(in reply to speed is life)
       Post #: 3
RE: Savex L39 - 8/2/2012 5:42 AM
juanjulian
Last Login: 5/16/2013
Status: offline
 Build one for a friend.
Lots of information in rcxxxgroups.
Used two mini hitec digital servos for elevator, one standard servo for rudder, two mini digitals for ailerons, and one  standard servo for steering. They were high torque max 70 oz inch.
The jet a1 retracts considered over priced and had problems  with the front retract, check tams jets formretracts.
Not sure about the specs of your motor but the one i build was neu ans used 50000 mha 8s and produced about 2800 watts.
Go to the other site for best info.
Cheers juan
Hide Signatures
       Post #: 4
RE: Savex L39 - 8/5/2012 6:34 PM
wop flyer
Status: offline
Thanks Juan, this gives me plenty to go on.
Hide Signatures
(in reply to juanjulian)
       Post #: 5
RE: Savex L39 - 8/5/2012 10:44 PM
steveair2
Last Login: 5/18/2013
Status: offline
Have a look here
http://www.rcgroups.com/forums/showthread.php?t=1184285
Cheers
Steve
Hide Signatures
       Post #: 6
RE: Savex L39 - 8/6/2012 9:34 PM
juanjulian
Status: offline
 Hy Steve:
This is the  big thread you want to read
http://www.rcgroups.com/forums/showthread.php?t=908112
I posted some buiding picutes on page 16 gray savex.
If I have to build one again will go MINI on all surfaces exept ruder since a standard servo is easy to glue inside rudder.  Tams Jet Retracts with foam wheels.
The trhust tube is hard to get in and get out.
Keep it light as it has a tendency t bunny jump on landings ruining the retracts.
Cheers
Juan
Hide Signatures
(in reply to steveair2)
       Post #: 7
RE: Savex L39 - 8/28/2012 4:18 PM
Henke Torphammar
Status: offline
HAB Electronic in Sweden got alot of custom parts for the L39. They have built alot of them for customers and have kits ready to ship for makeing the install easier.
http://www.hab.se/cnc-brygga-for-hojdroderstyrning-till-savex-l39-p-10675-c-614.aspx
Email tomas@hab.se or amir@hab.se for more info and priceing. I even think Tomas made a build thread where he shows all his parts made for the EDF build
/Henke
www.youtube.com/henke2
Swist F5D, Lambert Kolibri T25 - 310mph 2012
Hide Signatures
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.250RCU1
