RE: HobbyKing 1/16th Short Course Truck thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> 1/16th, 1/18th, Mini & Micro RC Cars >> RE: HobbyKing 1/16th Short Course Truck thread
Page: <<   < prev  1 [2]
Login
RE: HobbyKing 1/16th Short Course Truck thread - 10/31/2012 11:25 PM
thehuntingterminator
Last Login: 5/15/2013
Status: offline
That ESC is gonna do great considering its almost double the size of the stock one if I'm not mistaken.
quote:
ORIGINAL: seehuusen
thanks for your input mate
It sounds like I made the right choice then
I wanted it all yesterday, LOL, so I ordered my stuff from the Aussie warehouse, for quicker delivery
I hope this will work a treat in the little car By the sounds of it, it should do well
Oh and I got the programming card for it as well (yep, I know it says it's for a 150a ESC, but the ESC I bought also supports it)
Cheers
Martin
Hobby King 35A Sensored/Sensorless Car ESC (1:10/1:12) (AUS Warehouse)
Hobby King HKSS programming card for HK 150A ESC (AUS Warehouse)
_____________________________
- HobbyTownUSA Employee
- Writer for ModelKits.com & RcTruckStop.com
Hide Signatures
(in reply to seehuusen)
       Post #: 26
RE: HobbyKing 1/16th Short Course Truck thread - 11/1/2012 4:13 AM
seehuusen
Last Login: 4/30/2013
Status: offline
thanks mate, the original is a 25A rated cheap ESC... I doubt it handled that...
In fact, I don't actually know why it burned up, it happened right when I connected the battery for a test
I'm not game to put another battery back on it, at less than $25 you really don't need to argue reliability vs cost LOL
Should be fun with all the new gear...
I hadn't been able to find a heat sink for the little 2040 motor, do you reckon it's required? For piece of mind, I should just get one
Details below of the only one I could find that looked semi good... but it's for a plane... Thoughts?
Cheers
Martin
20MM HI DISSAPATION HEATSINK
$6.00
Lightweight Hi dissapation heatsink made for 20mm inrunner motors.
Motor locating sleeve for mounting 20mm motors into EDF55 & 64 fan units with 24mm housing.
Hide Signatures
(in reply to thehuntingterminator)
       Post #: 27
RE: HobbyKing 1/16th Short Course Truck thread - 11/1/2012 4:35 AM
Status: offline
Nah as long as your gearing is ok it'll be fine.
Hide Signatures
       Post #: 28
RE: HobbyKing 1/16th Short Course Truck thread - 11/1/2012 6:45 AM
seehuusen
Status: offline
oh OK, AWESOME, Lucky I bought a few different pinions
Thanks again for your advice and knowledge
Hide Signatures
       Post #: 29
RE: HobbyKing 1/16th Short Course Truck thread - 11/4/2012 11:40 PM
seehuusen
Status: offline
woooohooo, ESC and programming card has arrived, this arvo I should be able to put it all together and go for a test drive
Hide Signatures
       Post #: 30
RE: HobbyKing 1/16th Short Course Truck thread - 11/7/2012 10:26 PM
seehuusen
Status: offline
Hey guys,
I've got the whole lot solered up with connectors and everything.
Then I switched it all on, and there was no go on the motor?!? Not even a slight movement (steering servo worked fine, so power is coming to the receiver and onto the servo)
When looking in the manual, it says, if you have an orange and a red LED lit at the same time (constant light), the ESC is setup as a sensored motor
I'm not really sure on the difference between the two... Sensored/ Sensorless, and HK doesn't list whether or not it is or isn't... I didn't think it was...
On my ESC, it has a warning label that reads as follows:
Warning!
1. When installing the ESC on the Sendored Brushless motor, please attend to the  labels marked with A, B, C which must corrospond accordingly on the motor. Once misconnected, ESC will break down
2. Set up the ESC at the Throttle Range Calibration for the debut, or it does not work smoothly
3. Not accessible to the Brushed motor
Point one, I've got my motor wires wired, motor to ESC: blue to blue/ yellow to yellow/ red to orange
images for reference
I think that is right?
Point 2, what is the Throttle Range Calibration?
Point 3 doesn't concern me, I have a brushless motor
Thanks in advance for your input
Martin
Hide Signatures
       Post #: 31
RE: HobbyKing 1/16th Short Course Truck thread - 11/8/2012 3:48 PM
brenthampton79
Last Login: 5/17/2013
Status: offline
My wife got me one of these for my birthday and I ran it last night for the first time. Seems pretty fun for the money, its a little skaty but i figure thats because its so light and on concrete. I like it so far.
N802KC AT-802A Work
N66EC Pitts S1-S Fun!!
Hide Signatures
       Post #: 32
RE: HobbyKing 1/16th Short Course Truck thread - 11/12/2012 1:41 AM
seehuusen
Status: offline
welcome to the thread mate
They are fun little cars for sure!! I can warmly recommend the upgrade shocks and also the metal out drives, especially on 3S
Tested my ESC with two different motors, both brand new, and I think I might have a dud ESC... spewin' now I've gotta contact HK to find out more...
Time-wise, it'd probably be faster to just go pick one up from the local hobby store... but I don't like the guy there, anti-"anything not from his store" makes for a bad customer experience...
cheers
Martin
Hide Signatures
(in reply to brenthampton79)
       Post #: 33
RE: HobbyKing 1/16th Short Course Truck thread - 11/13/2012 10:52 PM
seehuusen
Status: offline
it's confirmed, the new ESC was a dud so it's in the mail back to HK for a replacement...
On the upside, I did test the motors on my boat ESC, and I can't wait to try them out in the car!!!
Hide Signatures
       Post #: 34
RE: HobbyKing 1/16th Short Course Truck thread - 11/15/2012 4:14 AM
seehuusen
Status: offline
it seems I'll be without an ESC for about a week... damn
Surfing evilBay, I found another potential motor...
I might buy it too LOL
Check out the specs:
Brushless motor Model: B2445 KV4200
Rotational Speed: 4200Kv (rpm/v)(rpm/v)
Power (W): 450W
Wire Winds: 6
Motor Dimensions (Diameter x Length): 24mm x 47 mm
Shaft Dimensions (Diameter x Length): 2mm x 12mm
Input Battery Types: NiCd/ Nimh/ Li-po Battery
Recommend Model: RC Model Car or Boat
Weight(g): 100
< Message edited by seehuusen -- 11/15/2012 8:51 PM >
Hide Signatures
       Post #: 35
RE: HobbyKing 1/16th Short Course Truck thread - 11/18/2012 11:03 PM
seehuusen
Status: offline
mmmmm Hobbyking has come out with a new SCT in this size, and it has some aluminium upgrade parts I'll have to have a look at fitting them up to this model too
Interestingly, the motor is pretty much identical to what I'm putting into this SCT
Hide Signatures
       Post #: 36
RE: HobbyKing 1/16th Short Course Truck thread - 12/11/2012 4:50 AM
seehuusen
Status: offline
still without an ESC, sending the second one back again... it was DOA
Hide Signatures
       Post #: 37
RE: HobbyKing 1/16th Short Course Truck thread - 12/18/2012 9:01 PM
seehuusen
Status: offline
still waiting on HK to send me a working ESC. Now I've purchased a different model... will see how that one goes... it's been like two months since I ran this car last... not enjoying the wait, but in all fairness to HK they have swapped all faulty items out and given HK Points to redeem against another item...
Hide Signatures
       Post #: 38
RE: HobbyKing 1/16th Short Course Truck thread - 1/4/2013 5:33 AM
seehuusen
Status: offline
new ESC arrived, then I installed it all, and the new motor is so powerful that it strips the rear diff gears!!! Awesome... but only for 10 seconds, then it's only getting front wheel drive LOL
gonna see what I can do about it, and what HK has available, the new SCT might have something I can use in this one?!?
If not, I will have to turn the timing down a fair bit... Currently it could side step/ drift with brand new tyres on tarmac! this is probably why the diff is not liking it...
When I get it back together, or know what I'm doing with it, I'll update Feel free to ask questions if you have any
Cheers
Martin
Hide Signatures
       Post #: 39
RE: HobbyKing 1/16th Short Course Truck thread - 4/24/2013 5:07 PM
jessemikkelsen
Last Login: 4/24/2013
Status: offline
Anything new on the rc car project?
Hide Signatures
       Post #: 40
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.734RCU1
