CG On flying wing?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Hangar 9 Twist 3D 40 (less Rx) - RTF
Seller:  stuk_at_work
Details:   $250.00   |  5/14/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Aerodynamics >> CG On flying wing?
Page: [1]
Login
CG On flying wing? - 7/31/2012 8:33 AM
sagehillspilot
Score: 100
Last Login: 4/5/2013
Status: offline
How do you find the CG On a flying wing??
It is homemade with a wingspan of 56 1/2 inches. where do i start?
_____________________________
Sage Hills Pilot
Hide Signatures
       Post #: 1
RE: CG On flying wing? - 7/31/2012 12:05 PM
up_in_smoke
Score: 100
Last Login: 5/18/2013
Status: offline
http://fwcg.3dzone.dk/
Hide Signatures
(in reply to sagehillspilot)
       Post #: 2
RE: CG On flying wing? - 7/31/2012 12:55 PM
edsplane
Score: 100
Last Login: 5/15/2013
Status: offline
The calculator used in the previous message, is limited to a single-panel wing and does not include the effects of the wing tips. If your flying wing is similar to this simple configuration, the calculator results should get you within about 10% of the actual CG location.  If your flying wing is multi-panel, the true results can be very different. If the wing shape is more complex and/or you want a closer estimate, I suggest that you read the description of a multi-panel wing analysis, including wing-tip effects, at the RCAeronauts website.
President of RC Aeronauts, sharing knowledge and providing innovative techniques and software solutions to RC modelers
Hide Signatures
(in reply to up_in_smoke)
       Post #: 3
RE: CG On flying wing? - 8/1/2012 5:03 AM
Lnewqban
Score: 163
Last Login: 5/6/2013
Status: offline
quote:
ORIGINAL: sagehillspilot
This is why and how:
http://adamone.rchomepage.com/index5.htm
Lnewqban - "The recipe for perpetual ignorance is: be satisfied with your opinions and content with your knowledge." - E. H.
Hide Signatures
       Post #: 4
RE: CG On flying wing? - 8/1/2012 1:43 PM
edsplane
Score: 100
Status: offline
 The links suggested in this discussion give some good info about conventional airplanes, ie. with tails, but the flying wing is a special case. Normally, the horizontal tail(HTail) influences the location of the Neutral Point(NP) by moving it rearward.  The NP is somewhere between the Aerodynamic center of the wing and that of the HTail. But, your plane doesn't have an HTail, so the NP of the plane is at the NP of the wing, which is normally very close to 25% of the wing Mean Aerodynamic Chord(MAC).
This being the case, the CG must be located a safe distance forward of the NP. For typical sport flying, a Static Margin would be about 10%.
So, since the NP is at about 25% of the MAC, putting the CG at 15% of the MAC would give you a 10% static margin. My recommendation is that you start test flying the plane with the CG at 10% of the wing MAC, ie.a 15% static margin, which should be a little nose-heavy. Then, when you are more familiar with flying the plane, move the CG rearward in 1 or 2% increments until you are comfortable with the way it flys. I wouldn't go much lower than a 10% static margin.
In order to be confident in what you're doing here, it is very important that you calculate the Neutral Point location accurately, which depends on the HTail area, shape, efficiency and some other important factors. It is equally important that the MAC is correct. For example, any calculation must include the effects of wing tips. If a CG Calculator doesn't use these factors and use them correctly, then you are risking the safety of your plane. You can read a more complete description of the analysis, at the RC Aeronauts website.
Good luck
Hide Signatures
(in reply to Lnewqban)
       Post #: 5
RE: CG On flying wing? - 8/3/2012 6:28 PM
BMatthews
Score: 247
Last Login: 5/14/2013
Status: offline
Sage Hills, you've given us little to go by. But the simple facts in the online calculator posted in the first link is a good basis for where the CG should go once you know the MAC of your wing.
There's one other factor you need to allow for if this is a swept Zagi or similar style wing. And that's the amount of wing twist you need to use. A good way to get that is using the Panknin twist formulas in a spreadsheet. You can read about and download this handy piece of work at;
http://www.b2streamlines.com/Panknin.html
Now if your foam wings, assuming that's what you used, do not have any twist in them it can be faked by using outboard elevons and simply reflex them upwards a little. Doing so sort of replicates the twist you need for a swept wing model to be stable.
But that's a poor way to do it if this is a thermal flying glider where you want to get all the efficiency you can. For that you want to use a proper graduated wing twist.
Witty saying to be plagarized shortly.....
Hide Signatures
(in reply to edsplane)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.281RCU1
