God, I Really Can't Tell!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> God, I Really Can't Tell! Page: [1]
Login
God, I Really Can't Tell! - 7/31/2012 11:08 PM
Homer712
Score: 100
Last Login: 5/2/2013
Status: offline
Purchased a used Sig Hog Bipe and am proceeding to mount my servos, receiver, engine (Thunder Tiger .91 4-stroke) and have run into an issue. I took everything off that would come off in an effort to clean the plane up a bit. That included the landing gear (looks like the stock Sig gear) which had been painted blue, but was peeling, so it needed to come off. Found a web site (last post was many yeasr ago) that dealt with nothinbg but Sig Hog Bipes and one of the statements made was "if your having issues with the plane tipping over on take-off, make sure the landing gear is facing forward, not mounted backward." Of course, when I took the landing gear off to get the peeling paint off I DID NOT mark which way is forward. I have now had the landing gear off and on (both ways) a number of times, and for the life of me, I can not see a difference.
Being a "third owner" I do not have access to a plan sheet against which to compare. Can the difference be so slight that it really is that hard to see?
_____________________________
Cub Brotherhood #57
Club Saito #802
Hide Signatures
       Post #: 1
RE: God, I Really Can't Tell! - 7/31/2012 11:19 PM
FlyingPilgrim
Score: 100
Last Login: 5/9/2013
Status: offline
Mount it so the wheels are as far forward as possible.
I know just enough to be dangerous
Hide Signatures
(in reply to Homer712)
       Post #: 2
RE: God, I Really Can't Tell! - 7/31/2012 11:25 PM
GaryHarris
Score: 168
Last Login: 5/16/2013
Status: offline
X2.
Sig Kadet Brotherhood #1
Ultra Sport Brotherhood #105
Hide Signatures
(in reply to FlyingPilgrim)
       Post #: 3
RE: God, I Really Can't Tell! - 7/31/2012 11:50 PM
Buckmeister
Score: 101
Last Login: 5/17/2013
Status: offline
x3
Corsair Brotherhood # 69
It''''s not how good you are, but how much fun you are having!
Hide Signatures
       Post #: 4
RE: God, I Really Can't Tell! - 8/1/2012 2:18 AM
N1EDM
Score: 125
Last Login: 5/18/2013
Status: offline
You guys are no help. I think he probably figured that one out already.
Club Saito #61 Cub Brotherhood #107
Spitfire Brotherhood #143
Hide Signatures
(in reply to Buckmeister)
       Post #: 5
RE: God, I Really Can't Tell! - 8/1/2012 2:40 AM
Nergall
Score: 115
Last Login: 5/12/2013
Status: offline
Is it possible the used plane has aftermarket landing gear on it? In which case, maybe there is no front and back anymore?
Hide Signatures
(in reply to N1EDM)
       Post #: 6
RE: God, I Really Can't Tell! - 8/1/2012 3:18 AM
Rv7garage
Score: 128
Last Login: 4/26/2013
Status: offline
Pics would help
#26 Club Saito ***CUB BROTHERHOOD*** #86
My full-scale build: www.rv7garage.blogspot.com
Hide Signatures
(in reply to Nergall)
       Post #: 7
RE: God, I Really Can't Tell! - 8/1/2012 3:56 AM
Homer712
Score: 100
Status: offline
Thanks guys. I'll take some pictures tomorrow morning with the gear mounted both ways. I'll put a tape measure on the work bench for reference. I've been flying trail draggers for years so I'm familar with them. On a H9 Pulse 60 I got earlier this year I ended up turning the gear backwards to get it to stop flipping over on takeoff (come to find out in these forums that it was a common issue with that plane).
Cub Brotherhood #57
Club Saito #802
Hide Signatures
(in reply to Rv7garage)
       Post #: 8
RE: God, I Really Can't Tell! - 8/1/2012 4:54 AM
Gray Beard
Score: 314
Status: offline
If you tried flipping it and can't tell then you have after market gear and it may not mater. Being a kit the builder may have put the LG block forward so you don't need an angled gear? In a kit build the LG block can also be placed at an angle so it is forward but you would have noticed that. I wouldn't worry about it. Ground testing will tell you if you have a problem or not!
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
       Post #: 9
RE: God, I Really Can't Tell! - 8/1/2012 5:55 AM
SeamusG
Score: 199
Last Login: 4/10/2013
Status: offline
I used a symmetrical composite (Super Strength DB789) Dubro landing gear with my Hog Bipe. I missed the "move the LG forward" suggestion so I'm in a stock location. I was playing around with "other" solutions to move the wheel axle forward. Took a piece of tapered stock and used it as a shim between the finished fuse bottom and the LG. This moved the axle 3/4" forward. Not the cleanest look. I'm gonna try "good take off throttle management" to see how well (or poorly) the piggy handles. Btw, mine has a Saito 100 on the nose.
The bolts have been replaced with three 1/4x20 nylon bolts - 2 forward and 1 rear. That way I can't screw up mounting the LG backwards!!!
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to Gray Beard)
       Post #: 10
RE: God, I Really Can't Tell! - 8/1/2012 4:17 PM
Gray Beard
Score: 314
Status: offline
Jim, without photos those are the gear I see in my minds eye that are on the OPs plane too. A tapered hardwood block is the cure for getting them set forward if you didn't do it during the build. The Sukhoi LG was very popular for a long time and found it's way onto a lot of planes. I have a couple of sets plus an ugly set that was sold through Tower that has a taper. I used them on scratch built Up-Roars because they are so strong and I could slam the plane in for spot landings
Hide Signatures
(in reply to SeamusG)
       Post #: 11
RE: God, I Really Can't Tell! - 8/1/2012 8:13 PM
Homer712
Score: 100
Status: offline
My gear looks exactly like the one in the picture above. What I did this morning was to take out my tape rule, back the tail wheel up against a stop and measure directly from the stop to the center line of the landing gear wheel shaft. Exactly 36 inches. Turned the gear around and took the same measurement. Right at 36 1/4 inches. I'll leave it in the 36 1/4 position and give it a try.
One other question (looking for opinions here I guess). The previous owner had an OS .91 4-stroke on this plane. I was planning on using a Thunder Tiger .91 4-stroke that I already have, but, I have an opportunity to purchase a used Magnum .80 4-stroke for this plane which I'm considering because my style of flying tends to be slow and easy (read "scale") flying. I'm sure being retired has something to do with it, but I prefer to just lazily cruise the sky. Don't have any experience with Magnum engines, all Thunder Tiger and Saitos so far. Any thoughts on the Magnum for this plane would be appreciated.
Cub Brotherhood #57
Club Saito #802
Hide Signatures
       Post #: 12
RE: God, I Really Can't Tell! - 8/1/2012 10:50 PM
thepamster
Score: 110
Status: offline
I would recommend sticking that TT.91 in there since you already have it and not to go down in size with a smaller size engine that is used and you are not familiar with.
The Pamster
AMA 202345
Hide Signatures
       Post #: 13
RE: God, I Really Can't Tell! - 8/1/2012 10:55 PM
Minnreefer
Score: 195
Status: offline
I would only suggest look at the weight of all three engines, if one is closer to the original os then i would go with that one.
Tiger 2 brotherhood #14
The Common flyer, best of the lousiest, and lousiest of the best.
Hide Signatures
(in reply to thepamster)
       Post #: 14
RE: God, I Really Can't Tell! - 8/1/2012 11:34 PM
Gray Beard
Score: 314
Status: offline
101 threads debating the Magnums, love um or hate um? I hate um. Your option.
Hide Signatures
(in reply to Minnreefer)
       Post #: 15
RE: God, I Really Can't Tell! - 8/2/2012 2:23 AM
Homer712
Score: 100
Status: offline
Thanks guys, the information/suggestions have been very helpful. Based on the weight of the previous owners installed OS .91 4-stroke, the weight of my Thunder Tiger .91 4-stroke and the fact that I fly off a (sometimes mowed) grass field, I'm going to stay with the Thunder Tiger .91. Thanks to all.
Cub Brotherhood #57
Club Saito #802
Hide Signatures
       Post #: 16
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.813RCU1
