CARF Ultra Flash    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Fly Eagle Jet F-16 Project, 1/5.5 Scale, includes turbine - ARF
Seller:  Screamin Eagle
Details:   $6,300.00   |  6/13/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> CARF Ultra Flash
Page: [1] 2   next >   >>
Login
CARF Ultra Flash - 8/1/2012 11:59 PM
rcand
Score: 105
Last Login: 6/17/2013
Status: offline
I have heard CARF makes quality planes. Has anyone had any problems with any delamination of skin hinging , flutter or anything of concerns?
Hide Signatures
       Post #: 1
RE: CARF Ultra Flash - 8/2/2012 1:22 AM
seflyer
Score: 105
Last Login: 6/16/2013
Status: offline
Nope,Nope and Nope. this is one of the most bulletproof aircraft ever built. you can damage the flaps if you don't put the gear down but other than that it is built like a tank.
Kevin
Hide Signatures
(in reply to rcand)
       Post #: 2
RE: CARF Ultra Flash - 8/2/2012 1:35 AM
AFTERBURNER1
Score: 139
Last Login: 6/12/2013
Status: offline
quote:
ORIGINAL: seflyer
Kevin
+1,,,,, flys all day long as good as a bandit for half the scratch and extremely strong.... I've had both...
2 cents,,,
_____________________________
Jetcat USA
Hide Signatures
(in reply to seflyer)
       Post #: 3
RE: CARF Ultra Flash - 8/2/2012 2:25 AM
smchale
Score: 115
Last Login: 6/18/2013
Status: online
Is the classic flash still available?
Sean McHale
"Strive for simplicity. You never have to repair what you leave out." - Bill Lear
Hide Signatures
(in reply to AFTERBURNER1)
       Post #: 4
RE: CARF Ultra Flash - 8/2/2012 3:38 AM
wojtek
Score: 115
Status: offline
All flashes and ultras have potential for skin delamination along the hinge areas . The elevator is especially prone to this problem. Usually this will never manifest itself from flight, however transport and ground handling can attribute to this. In the case of the elevator, a bounded landing , or a nose high landing on rougher surface can cause the elevator horns to get pushed up and peel up the hinge area. Bumping the other surfaces can cause a similar problem. Very few have also claimed they have had surface separation after many flight, however there is a possibility this was also from "handling" just went unnoticed for some time. hmm, funny some who have posted here already have had this problem and and posted about it in the past .. All said, the UFlash is my favorite sport jet I have ever flown ... and yes, I have had a delamination issue after hitting a divot on a runway and having my plane bounced .. in the air, the plane will take what you can throw at it ..
http://www.youtube.com/watch?v=n8VP4TjRlNI&hd=1
~V~
www.facebook.com/allscale
http://www.all-scale.com
-working model MFD & HUD, 3D print, Metal-Morph Plating, Custom-Build
Hide Signatures
(in reply to smchale)
       Post #: 5
RE: CARF Ultra Flash - 8/2/2012 4:53 AM
dubd
Score: 135
Status: offline
quote:
ORIGINAL: AFTERBURNER1
quote:
ORIGINAL: seflyer
Kevin
2 cents,,,
+1. Best...Sports...Jet...Ever...
Hide Signatures
       Post #: 6
RE: CARF Ultra Flash - 8/2/2012 5:02 AM
InboundLZ
Score: 140
Status: offline
Yeah, Agreed......
Dave Bottita
evoJet Factory Pilot
Smart-Fly
Hide Signatures
(in reply to dubd)
       Post #: 7
RE: CARF Ultra Flash - 8/2/2012 7:35 AM
SniperWj
Score: 100
Last Login: 6/10/2013
Status: offline
UF is my first proper full jet size other then my habu/p20 and funjet/p20
the UF is much easier to fly then above two! superb slow flying perfomance,very easy to land!
and it able took all those abuse from p180rx! thumbs up! carf price them just about rite! you will never go wrong
with ultraflash!
http://www.youtube.com/watch?v=xI7TN44jvGU&feature=youtube_gdata_player
yiming
Hide Signatures
(in reply to InboundLZ)
       Post #: 8
RE: CARF Ultra Flash - 8/2/2012 1:31 PM
Meesh
Score: 100
Status: offline
One of my flying buddies experienced elevator hinge delamination on his.
Other than that it has been a great plane.
Bob
If it''s worth doing, it''s worth doing it right.
AMA 779352, JPO 1965, IMAA 40337
Hide Signatures
(in reply to rcand)
       Post #: 9
RE: CARF Ultra Flash - 8/2/2012 2:40 PM
sailing1
Score: 100
Status: offline
On the plus side, should you experience a delamination problem it is usually a really easy problem to fix with no adverse affect to future flying.
Hide Signatures
(in reply to Meesh)
       Post #: 10
RE: CARF Ultra Flash - 8/2/2012 2:42 PM
gooseF22
Score: 103
Last Login: 6/13/2013
Status: offline
If you set the plane down on the horns on the elevator during transport, it puts pressure on the hinges, and can cause delam.. slide a pipe insulation foam piece on the rear keel for transport.. quick and easy.. keeps the horns off the table... Its a cool plane.. I converted my CF to an UF.. flew it a little, but its undergoing a redo this winter with a smaller motor and lighter.. No issues, just wanted the motor for something else..
Goose
Wren Turbines USA, Fromeco
Hide Signatures
(in reply to Meesh)
       Post #: 11
RE: CARF Ultra Flash - 8/2/2012 3:26 PM
Bostonu
Score: 100
Status: offline
Great Plane. I love mine. Like Goose I am converting mine to UFlash this winter and doing an entire redo on the plane.
Hide Signatures
(in reply to gooseF22)
       Post #: 12
RE: CARF Ultra Flash - 8/2/2012 4:48 PM
gooseF22
Score: 103
Status: offline
quote:
ORIGINAL: Bostonu
Pins dont line up, neither do the bolt holes.. PM me if needed..
Make a template from the old wing..
Goose
Hide Signatures
(in reply to Bostonu)
       Post #: 13
RE: CARF Ultra Flash - 8/2/2012 7:17 PM
Bostonu
Score: 100
Status: offline
quote:
ORIGINAL: gooseF22
quote:
ORIGINAL: Bostonu
Tim R. was telling me that as well. I have the wings and both don't line up. I won't be starting it until the winter. I will talk to you at Illinois Jets. Thanks Bro.
Hide Signatures
       Post #: 14
RE: CARF Ultra Flash - 8/3/2012 1:56 AM
rcand
Score: 105
Status: offline
OK, thanks for everyones replies. Great help. I know they recommend 22-26 pounds of thrust. Any recommendation from you guys who are flying them. I don't need to go ballstic but like good performance. I guess I got all the speed stuff out of my system flying Bandits for years.
Hide Signatures
(in reply to rcand)
       Post #: 15
RE: CARF Ultra Flash - 8/3/2012 2:44 AM
Bostonu
Score: 100
Status: offline
quote:
ORIGINAL: rcand
p120 or p160 would be fine. I prefer the bigger engine because I could always use it in other planes.
Hide Signatures
(in reply to rcand)
       Post #: 16
RE: CARF Ultra Flash - 8/3/2012 7:19 AM
indubitably
Score: 101
Last Login: 5/22/2013
Status: offline
P 100 RX will push it to 215, but it takes a while to get there. Take off needs 400 ft, and the speed builds slowly. Once up to speed, it will go vertical possibly 1,000 feet before perceptably slowing. And low residual thrust is nice. The P120 SX Will be all around faster getting there, and higher top end. The 160 is frequently used, and is lively, but will not hold a vertical climb if you start slow and point vertical, and hold it. I cannot wait to see what the P180RX will dow for this plane. Will find out in a few weeks when a friend picks his up. We will probably radar him for reference.. The vertical should accelerate, and the take off should be under 200 ft. estimated. The P200SX wont fit, without a lot of work, and im not the one to do it.
Hide Signatures
       Post #: 17
RE: CARF Ultra Flash - 8/3/2012 8:26 AM
SniperWj
Score: 100
Status: offline
the 180rx work just like what you said.
I can give it unlimited vertical come out from slow and low pass.
one word..awesome!
mine weight 10.5kg uat full but tanks is empty
yiming
Hide Signatures
(in reply to indubitably)
       Post #: 18
RE: CARF Ultra Flash - 8/3/2012 11:41 AM
basimpsn
Score: 120
Status: offline
quote:
ORIGINAL: SniperWj
one word..awesome!
yiming
I wouldn't use any turbine with thrust rating higher than a 170, I did the K-180 in my ultra Flash although the full throttle was not a problem, but my idle thrust was too much for landing. So I swap with my k-170. Notice my video I had to bleed off speed before take off .
http://www.youtube.com/watch?v=k357mbHFCmI
It''''''''''''''''''''''''''''''''s a hobby - keep it simple
Hide Signatures
(in reply to SniperWj)
       Post #: 19
RE: CARF Ultra Flash - 8/3/2012 1:36 PM
gooseF22
Score: 103
Status: offline
when I had the 160 in it, we kept dialing it back...ended up around 24-26 lb thrust.. plenty to go vertical (midwest).. If you have all the speed out of your system, then build it light weight and use one of the smaller lighter engines.. thats what Im doing this winter.. I saw one fly recently with a Tam pipe, lighter servos, and less than 20lb overall weight..yes, less than 20lb.. with a P100.. it flew absolutely beautifully.. would slow to a crawl.. plenty of smash.. Im going to put a wren 100 in mine with the stock pipe, and toss the pilot/cockpit, and take out the smoke.. that should bring me in around 22lb.. FWIW
Goose
Hide Signatures
(in reply to basimpsn)
       Post #: 20
RE: CARF Ultra Flash - 8/3/2012 2:37 PM
SniperWj
Score: 100
Status: offline
that said you need
more flaps...the video above is my
maiden flight. I got no problem
landing her with 180rx.
if talking light weight uf I can swap out
the 180 and put in vt80 from my velox one day to try out .
should be a fun flyer with lower wing loading!
yiming
Hide Signatures
       Post #: 21
RE: CARF Ultra Flash - 8/3/2012 3:57 PM
luv2flyrc
Score: 102
Status: offline
quote:
ORIGINAL: gooseF22
Totally agree, have flown flash with Rabbit 100 at 21lbs, and Cheetah at 22lbs aircraft weight. With the lighter engine, the plane handles SO nice, still does 180mph, take off and landings in 150ft. It is faster with the Cheetah, about 225mph but, doesn't "feel" as light and becomes more of a straightline speed plane.Also, higher residual thrust and more time to spool down with a bigger engine.  I like the way it will slow to a crawl with the smaller engines.
I fail to see why people continue to hang bigger and bigger engines in them? You get marginal speed gains and lose handling. The Flash was designed as an aerobatic sport jet, not a speed plane.
Mike
Hide Signatures
       Post #: 22
RE: CARF Ultra Flash - 8/3/2012 4:29 PM
KFX450
Score: 100
Status: offline
Why did they get rid of the classic flash?? I love the look in the thunderbirds scheme with the wingtips..Just my taste, but it stinks its not available..Anyone know???
Hide Signatures
(in reply to luv2flyrc)
       Post #: 23
RE: CARF Ultra Flash - 8/3/2012 5:27 PM
luv2flyrc
Score: 102
Status: offline
quote:
ORIGINAL: KFX450
+1, looks and schemes on the Classic were much better! Had that T-38/ F-5 look to it and the Jolly Roger and Thunderbird schemes were awesome.  UF looks like every other sport jet
Mike
Hide Signatures
(in reply to KFX450)
       Post #: 24
RE: CARF Ultra Flash - 8/3/2012 5:33 PM
Robrow
Score: 100
Status: offline
I'm sure there are plenty of people who would be happy to swap their standard flash wings/stab for an ultra set to save the 1k cost of an upgrade.
Rob.
UK distributor: Jets Munt Merlin 90, 140 & 160. Jet Central UK. FADEC ECU''''s UK
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.641RCU1
