MVVS 2.5D RRV    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> MVVS Support >> MVVS 2.5D RRV
Page: [1]
Login
MVVS 2.5D RRV - 8/2/2012 3:38 AM
fiery
Score: 100
Last Login: 5/25/2013
Status: online
Hello Pe
I would be grateful if you could answer some questions about this engine:
1. Will the piston and liner set for recent production MVVS 2.5 diesels fit OK in this engine?
2. Is a factory header available?
3. If so, does the usual pipe for the 2.5 engine will fit up to it, with the supplied silicone coupling tube?
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1
RE: MVVS 2.5D RRV - 10/10/2012 4:44 AM
fiery
Score: 100
Status: online
I located a piston and liner for a current spec 2.5D. They fit the above engine perfectly.
Porting and timing in the new liner is a little different. I ended up leaving in the old liner. It must not be overly worn as the new piston makes a nice gas seal using it.
The old conrod was unbushed. Both little and big ends were worn. The current spec conrod (supplied fitted to the piston in th enew P&L set) is sturdier, and bronze bushed on the big end.
All fitted up with no issues, except I made a thicker back plate gasket to stop the crank pin binding on the disc valve. Valve clearance is good, no scores on the mating faces.
It's looking good.
Hide Signatures
(in reply to fiery)
       Post #: 2
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> MVVS Support >> MVVS 2.5D RRV
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.094RCU1
