Saito 90TS    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> Saito 90TS
Page: [1]
Login
Saito 90TS - 8/2/2012 2:40 PM
swify
Score: 100
Last Login: 5/24/2013
Status: offline
I bought a NIB 90TS last summer on line, never had a Saito before. It has two red wires included in the box with spade type clips on the end, to fit over the glow plugs I assume and one black wire with a ring type connector on it, not sure what it"s for. Are these typically included with a saito engine? I am thinking of using a glo driver setup for it. What is a good type to use?
Hide Signatures
       Post #: 1
RE: Saito 90TS - 8/2/2012 2:49 PM
w8ye
Score: 318
Last Login: 5/25/2013
Status: offline
The glow plug wires are typically supplied with the multiple cylinder engines.
I have all the current smaller multiple cylinder Saito engines and I do not use a on-board glow driver with them.
_____________________________
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to swify)
       Post #: 2
RE: Saito 90TS - 8/2/2012 3:27 PM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: swify
I bought a NIB 90TS last summer on line, never had a Saito before. It has two red wires included in the box with spade type clips on the end, to fit over the glow plugs I assume and one black wire with a ring type connector on it, not sure what it''s for. Are these typically included with a saito engine? I am thinking of using a glo driver setup for it. What is a good type to use?
You can wire the plugs in series if you have an ajustable glow driver in your flight box power panel. Just hook 1 glow plug to + & the other glow plug to - & adjust the amperage to 3 amps. (green on the scale)
You can also use 2 seperate clip-on glow drivers if you do not have a power panel.
Club Saito #785 - FA91S CDI, FA150 CDI, FA180 CDI, FA180HC CDI/BBC, FA200TI, FA300TTDP CDI
Hide Signatures
(in reply to swify)
       Post #: 3
RE: Saito 90TS - 8/2/2012 10:11 PM
farmerric
Score: 100
Status: offline
I have one of these engines running on a glo driver, it will only run on one cylinder, checked valves, glo plug, all ok. I can't put it back into a plane in the current state. I never had any issues with my os 160 twin. so I am a little confused
Hide Signatures
(in reply to SrTelemaster150)
       Post #: 4
RE: Saito 90TS - 8/2/2012 10:45 PM
Hobbsy
Score: 650
Last Login: 5/26/2013
Status: offline
Low Speed needle too rich.
A young man knows the rules and an old man knows the exceptions.
Club Saito member #5
Hide Signatures
(in reply to farmerric)
       Post #: 5
RE: Saito 90TS - 8/3/2012 1:15 AM
mike109
Score: 148
Status: offline
G'day
I have a 90TS and it runs like the proverbial Swiss Watch. I use fuel with 10% nitro in it. I do not use on board glow as it is in a Cub and it is quite accessible so I just use two pocket glow drivers. I did have to adjust the low speed needle quite a bit during the running in process.
Saito engines generally come out of the box with the low speed needle set quite rich. OS engines come out nearer to the final setting. Because of this, many OS owners never adjust their low speed needles and put up with an engine that runs OK but which could run better. I had this argument with a friend at the field last week. He never touches the LSN on his OS engines and proudly told me so. He also told me that it was normal for his engines to "load up" and need to be "cleared out". If I could just get him to adjust the LSN I am sure these little problems would be behind him.
Cheers
Mike in Oz
"I just had no control. Must be the radio." Club Saito #597 Kadet Brotherhood #66
Hide Signatures
(in reply to Hobbsy)
       Post #: 6
RE: Saito 90TS - 8/3/2012 1:22 AM
SrTelemaster150
Score: 229
Status: offline
quote:
ORIGINAL: mike109
G'day
Saito engines generally come out of the box with the low speed needle set quite rich. OS engines come out nearer to the final setting. Because of this, many OS owners never adjust their low speed needles and put up with an engine that runs OK but which could run better. I had this argument with a friend at the field last week. He never touches the LSN on his OS engines and proudly told me so. He also told me that it was normal for his engines to ''load up'' and need to be ''cleared out''. If I could just get him to adjust the LSN I am sure these little problems would be behind him.
Cheers
Mike in Oz
You can lead a man to knowledge but you can't make him think.
Hide Signatures
(in reply to mike109)
       Post #: 7
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> Saito 90TS
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.438RCU1
