RE: JMA Long Marston - 6th and 7th October, 2012    Gallery
Logged in as Guest
    Search This Thread
Printable Version
MBA Tornado V3
Seller:  Modellbau USA
Details:   $380.00   |  5/11/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: JMA Long Marston - 6th and 7th October, 2012
Page: <<   < prev  1 2 3 [4] 5 6 7   next >   >>
Login
RE: JMA Long Marston - 6th and 7th October, 2012 - 10/5/2012 3:15 PM
John Tancock
Score: 100
Last Login: 5/17/2013
Status: offline
Alex
I thought you were only coming on Sunday?
Would be great if you and Peter could make both days!
JT
Hide Signatures
(in reply to Bed time)
       Post #: 76
RE: JMA Long Marston - 6th and 7th October, 2012 - 10/5/2012 4:10 PM
Bed time
Score: 100
Last Login: 3/30/2013
Status: offline
Saw the weather on Sunday and thought better of it
Won't be able to make it all weekend mate, it's still looking doubtful that we will be up tomorrow as it stands with all the issue's we're having with the 120.
Alex
_____________________________
KaoS-RC - www.kaos-rc.co.uk
Hide Signatures
(in reply to John Tancock)
       Post #: 77
RE: JMA Long Marston - 6th and 7th October, 2012 - 10/5/2012 5:58 PM
ModellbauUK
Score: 101
Last Login: 5/19/2013
Status: online
 Have a great weekend guys. Weather looks perfect.
www.modellbauuk.com
The Aurora Project
The Kestrel Project
FCT Kevlar & Hopper Tanks
Hide Signatures
       Post #: 78
RE: JMA Long Marston - 6th and 7th October, 2012 - 10/5/2012 6:10 PM
miniman
Score: 100
Last Login: 2/11/2013
Status: offline
Alex and I have finally thrown in the towel as we can not get the motor the initialise. It keeps flashing the red LED and Glowplug symbol but we have changed the Kerostart plug with no change.
Seems like there is something wrong with the ecu, and I can not get hold of JetCat till Monday morning.
Peter
< Message edited by miniman -- 10/5/2012 8:03 PM >
Hide Signatures
       Post #: 79
RE: JMA Long Marston - 6th and 7th October, 2012 - 10/5/2012 6:15 PM
ModellbauUK
Score: 101
Status: online
 Seems to be a lot of Jetcat ECU's causing issues lately. That's the 3rd one I've heard of this week.
www.modellbauuk.com
The Aurora Project
The Kestrel Project
Hide Signatures
(in reply to miniman)
       Post #: 80
RE: JMA Long Marston - 6th and 7th October, 2012 - 10/5/2012 7:12 PM
Geoff White
Score: 100
Status: online
Peter,
Is the ECU set to Kero start? Look here for a manual that explains how to check and set it to Kero is necessary http://www.jetcatusa.com/PDFFiles/Instruction%20manual%20V6.0J2.pdf
Geoff.
Hide Signatures
(in reply to ModellbauUK)
       Post #: 81
RE: JMA Long Marston - 6th and 7th October, 2012 - 10/5/2012 8:09 PM
miniman
Score: 100
Status: offline
Hi Geoff
Yes the CPU is set correctly, to ensure it was correct I reprogramed it to Kerostart.
I have checked each wire with an Ohm meter to ensure continnuity and all seems well.
This motor has just come back from the factory and was check run before it left, the only thing that was not checked was the cabling.
Peter
Hide Signatures
(in reply to Geoff White)
       Post #: 82
RE: JMA Long Marston - 6th and 7th October, 2012 - 10/5/2012 8:29 PM
Jamie C
Score: 115
Status: online
Looks like we are going to have brilliant weather for the weekend! all my gear is ready and just needs to be loaded tomorrow morning, will be taking my E-flite Mig for combat in the mornings, Will hopefully get there as dawn breaks and set up ready for action!
As Dick has said, we will hopefully be having three meetings at Long Marston next year which will be costly but once booked they will be guaranteed to happen.
Hide Signatures
       Post #: 83
RE: JMA Long Marston - 6th and 7th October, 2012 - 10/5/2012 8:31 PM
Dave Wilshere
Score: 108
Status: offline
Peter
I guess when you clamped the first keroburner down on the wing something fused. Will email JC and see what they think.
Ian, typical internet forum statement. I won't start on about your kits...OK? JetCat have sold a lot more turbines than anyone else, so I'd expect a lot more issues...In this case the turbine/ECU was fine until Peter made the mistake on the Kero start position and tried to clamp it into the wing...
Peter, any "smell" to the ECU?
Dw
Motors & Rotors. JetCat, Powerbox, Intairco, Behotec, Graupner. CARF-models Rep. JR Propo for ever!, Jet 1A, MAP, Evojet, BV
Hide Signatures
       Post #: 84
RE: JMA Long Marston - 6th and 7th October, 2012 - 10/5/2012 8:32 PM
Jamie C
Score: 115
Status: online
quote:
ORIGINAL: miniman
Hi Geoff
Peter
Just an idea but have you tried changing it to gas operation to see if it is an issue with the kero start side of the ECU?
Hide Signatures
       Post #: 85
RE: JMA Long Marston - 6th and 7th October, 2012 - 10/5/2012 8:37 PM
Jamie C
Score: 115
Status: online
quote:
ORIGINAL: Dave Wilshere
Peter
Peter, any ''smell'' to the ECU?
Dw
Ah! did not know this!
Hide Signatures
(in reply to Dave Wilshere)
       Post #: 86
RE: JMA Long Marston - 6th and 7th October, 2012 - 10/5/2012 9:05 PM
miniman
Score: 100
Status: offline
Hi Guys
I am still working through the system, but still a blank.
I have tried changing the CPU to gas start ad put a "standard" glowplug into the motor and it still says the glow plug is faulty. Have switched it back to Kerostart still no go.
DAve there is no smell from the CPU, but the only thing that is left is the CPU not liking the keroplug getting traped by the wing.
I will speak on Monday morning to decide whats the next step.
Peter
Hide Signatures
(in reply to Jamie C)
       Post #: 87
RE: JMA Long Marston - 6th and 7th October, 2012 - 10/5/2012 9:12 PM
Geoff White
Score: 100
Status: online
Just made sure everything is set for the weekend. Bringing both of my little EDF Migs as one of them has seen a bit of 'action' and the other is brand new, unflown.
Hide Signatures
       Post #: 88
RE: JMA Long Marston - 6th and 7th October, 2012 - 10/5/2012 9:21 PM
jason
Score: 111
Status: offline
Guess I better put my Mig in the van then. Better repair it first though
Hide Signatures
       Post #: 89
RE: JMA Long Marston - 6th and 7th October, 2012 - 10/5/2012 9:27 PM
ModellbauUK
Score: 101
Status: online
 Geoff
Flying both at the same time?  Now that will be a neat trick.
Ian
www.modellbauuk.com
The Aurora Project
The Kestrel Project
Hide Signatures
       Post #: 90
RE: JMA Long Marston - 6th and 7th October, 2012 - 10/5/2012 9:31 PM
ModellbauUK
Score: 101
Status: online
quote:
ORIGINAL: Jamie C
Hope you get to fly your models this weekend Jamie as you're normally helping others out. Me included.
Enjoy the weather. Gutted I can't be there.
www.modellbauuk.com
The Aurora Project
The Kestrel Project
Hide Signatures
       Post #: 91
RE: JMA Long Marston - 6th and 7th October, 2012 - 10/5/2012 9:48 PM
ModellbauUK
Score: 101
Status: online
Peter
Dw
DUCK!!!!
Missed!!!!
Lol
www.modellbauuk.com
The Aurora Project
The Kestrel Project
Hide Signatures
       Post #: 92
RE: JMA Long Marston - 6th and 7th October, 2012 - 10/5/2012 11:54 PM
CJ2002
Score: 100
Status: offline
Just finished loading food, etc into the van (good old 24 hr Tesco!) and it's hammering down outside (has been all evening). Forecast is for it to clear at abt 0100 and a nice sunny day tomorrow!
Should be good...got my daughter Rachael coming to help, so I might get chance to get out and take some pics! Certainly looking fwd to Migs at dawn
Hang loose and see you tomorrow.
Cheers,
Dick
Hide Signatures
       Post #: 93
RE: JMA Long Marston - 6th and 7th October, 2012 - 10/6/2012 4:57 PM
lozza1965
Score: 105
Last Login: 5/18/2013
Status: offline
Hope everyone is having a great time, gutted I couldn't attend, but long drive through tonight and tomorrow, so chilled out all day.
lozza
http://www.flickr.com/photos/laurie-hughes/
Hide Signatures
(in reply to CJ2002)
       Post #: 94
RE: JMA Long Marston - 6th and 7th October, 2012 - 10/6/2012 7:26 PM
David Gladwin
Score: 110
Status: offline
A truly fabulous day's flying, superb vis., scattered Cu , wind 1 to 3 knots if that, and much beautiful sunshine, convivial company, and great flying ! Doesn't get any better, thanks to all and particularly to Roger and Dick with catering !! Hope Sunday goes as well as today !
Regards,
David.
Hide Signatures
(in reply to lozza1965)
       Post #: 95
RE: JMA Long Marston - 6th and 7th October, 2012 - 10/7/2012 8:57 AM
madmodelman
Score: 110
Status: offline
Can't make it today unfortunately but managed to get rid of almost 25 ltrs of kero yesterday, still can't believe how good the weather was, thanks to Dick and Roger for a nice relaxed day's flying, great day,
Gary.
< Message edited by madmodelman -- 10/7/2012 6:10 PM >
Stuka, P51, Super Chipmunk, Super Stearman R170, BE2e, Javelin, Hawk, F16, L39, F86, Viperjet. Need an F4!!
Hide Signatures
(in reply to David Gladwin)
       Post #: 96
RE: JMA Long Marston - 6th and 7th October, 2012 - 10/7/2012 9:17 AM
Dizz
Score: 100
Last Login: 5/16/2013
Status: online
Here are a few photos from yesterday.  Not as sunny today, but still lights winds and another excellent day in prospect.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Keep calm and eat more pies.
Hide Signatures
       Post #: 97
RE: JMA Long Marston - 6th and 7th October, 2012 - 10/7/2012 11:02 AM
Pat Barnes
Score: 100
Status: offline
Enjoyed yesterday immensely! Good banter with the boys, as ever - just a shame my Bandit suffered some minor undercarriage damage, so only got 2 flights in! Had great fun hiding behind the hay bale trying to radar gun Geoff's Super and the superb Firebird - I want that paint scheme! Both too fast for the gun (which has measured 219mph), so comfortably 220mph+, but it was fun anyway! In the Geoff vs Jason Mega Death speed competition, I think Geoff has the edge! On second thoughts, Jason is getting me a new bottom end for my BVM strut... so - definitely Jason!
Hope the weather is good today too! Thanks again to Dick and Roger! Dick - with the catering in such good hands, next time you'll have to bring a model and fly!
Hide Signatures
(in reply to Dizz)
       Post #: 98
RE: JMA Long Marston - 6th and 7th October, 2012 - 10/7/2012 6:56 PM
GrayUK
Score: 102
Status: offline
Amazing day today, great weather, (no wind and sunshine!)
I would like to thank all who helped with setting this up.
Great to the the 'Cock' this morning.....not a well man!
Looking forward to the next one!
Paul G
no one told you when to run...
Hide Signatures
(in reply to Pat Barnes)
       Post #: 99
RE: JMA Long Marston - 6th and 7th October, 2012 - 10/7/2012 7:25 PM
Dizz
Score: 100
Status: online
 Vis was a bit impaired to start with, but soon burnt off to another lovely day...........and I flew my Attacker
One for Pat
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to GrayUK)
       Post #: 100
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.824RCU1
