Charging and balancing Life Batt with taking plane apart at Field?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Charging and balancing Life Batt with taking plane apart at Field? Page: [1]
Login
Charging and balancing Life Batt with taking plane apar... - 8/2/2012 7:46 PM
rcpilotaviator
Score: 100
Last Login: 5/7/2013
Status: offline
Ok guys, love these Life Batteries, but what a pain to balance and charge at the field without taking plane apart at the field. What are the tricks? Im talking about 60 size and larger nitro and gas, not small electrics.
Hide Signatures
       Post #: 1
RE: Charging and balancing Life Batt with taking plane ... - 8/2/2012 8:03 PM
4*60
Score: 111
Last Login: 5/23/2013
Status: offline
 No need to balance every time.  I have used and sold A123 packs without balance leads for over a year and still 100%.  Now using the non A123 life packs.  I understand if you are charging at 1 c or less and discharging at a low rate, balanced cells is not a problem.  If you are still concerned, there are balance lead extensions for under a $. And put them under a hatch.
< Message edited by 4*60 -- 8/2/2012 8:55 PM >
_____________________________
"Of course, that''''s just my opinion. I could be wrong." the other Dennis Miller
Hide Signatures
(in reply to rcpilotaviator)
       Post #: 2
RE: Charging and balancing Life Batt with taking plane ... - 8/2/2012 8:52 PM
Goldenduff
Score: 114
Status: offline
It's easy to make balance extension wires- I have some old servo type leads that once the ends are removed the wire terminates in a pin- perfect!
Hello, the IMAX b6 quattro fits the bill?
Hide Signatures
(in reply to 4*60)
       Post #: 3
RE: Charging and balancing Life Batt with taking plane ... - 8/2/2012 8:59 PM
4*60
Score: 111
Status: offline
Another question.  Why charge at the field?  I have flown 3 flights on 1100 life packs and then put back in under 100 ma, so I could easily fly 15-20 flights in a day without charging.
Hide Signatures
(in reply to Goldenduff)
       Post #: 4
RE: Charging and balancing Life Batt with taking plane ... - 8/2/2012 9:24 PM
rcpilotaviator
Score: 100
Status: offline
Thanks for the comments guys. After using the nicd and nimh for the last couple years I just have become use to charging and checking the voltage. But I think to take full advantage of the Hobbico Life battery it should be balanced. Sure I could just charge it, but Im I getting the most out of them with out balancing them. I almost always charge at home, but still want to be able to balance at the field/charge at field.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to 4*60)
       Post #: 5
RE: Charging and balancing Life Batt with taking plane ... - 8/2/2012 10:04 PM
ALWAYSPDG
Score: 101
Last Login: 5/1/2013
Status: offline
Try Radical RC on the net, I think they have the extension balance cables for the LiFe battery you have listed here in 6", 12", and 24" lengths. I know that I got some just for the same reason and I think I got them from Radical RC. Try this; http://www.radicalrc.com/category/LIPOLIFE-Balance-ExtendAdapt-435
Mike
Hide Signatures
       Post #: 6
RE: Charging and balancing Life Batt with taking plane ... - 8/3/2012 1:04 AM
guver
Score: 174
Status: offline
A pack that was balanced previously will tend to stay that way for a long time. Maybe you can balance it perfectly at home and then after many re-charges re-check the balance to see if it is true.
and airplanes were in
Hide Signatures
(in reply to ALWAYSPDG)
       Post #: 7
RE: Charging and balancing Life Batt with taking plane ... - 8/3/2012 2:11 AM
BarracudaHockey
Score: 280
Status: offline
www.wrongwayrc.com sells external charge jacks that are set up to balance charge externally
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to guver)
       Post #: 8
RE: Charging and balancing Life Batt with taking plane ... - 8/5/2012 10:07 AM
Gtarling
Score: 100
Last Login: 5/13/2013
Status: offline
I have three larger models that have A123 packs permanently fitted. What I do is fast charge on the field without balancing. After the last flight of the day, I balance charge the packs at home. After more than two years of this treatment, I have none that are out of balance by more than a couple of millivolts.
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 9
RE: Charging and balancing Life Batt with taking plane ... - 8/5/2012 9:09 PM
pilotpete2
Score: 120
Status: online
If you use any one of the 3 wire (DSC) heavy duty switch harnesses, you can balance charge directly though the charge jack. You just need the battery pack to be wired up with a full 3 wire servo lead with the signal lead connected to the node of the two cells. Radical RC has this option on their website. When you do this setup, you do need to remember to cut the signal wire in the switches output lead to the receiver. All my gassers and slimers have this setup.
Pete
"If the woman don''''''''t find you handsome, they should at least find you handy"
Hide Signatures
       Post #: 10
RE: Charging and balancing Life Batt with taking plane ... - 8/7/2012 2:27 AM
tacx
Score: 109
Last Login: 5/21/2013
Status: offline
With a fully charged Life you can get allot of flights. You can charge them in your plane and if you want to balance without taking your plane apart just install the balance jack into the side of your plane. Just add a balance extension to the battery balance plug and find a suitable mounting plate and mount it next to the main charge jack.
Here is a pic of my Sig Hog Bipe that I never take apart. The balance jack has a rubber cap over it to keep out the dirt and oil.
Click for fullsize
Hide Signatures
(in reply to pilotpete2)
       Post #: 11
RE: Charging and balancing Life Batt with taking plane ... - 8/11/2012 5:17 PM
rcpilotaviator
Score: 100
Status: offline
Thanks for all those sugestions. Love that hog bipe.
Hide Signatures
(in reply to tacx)
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.391RCU1
